DIY conversion to SS/Fix and your skill level
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 762 Post(s)
Liked 555 Times
Wanting a SS/Fixie bike and have been looking
anyone do their own conversion and if so, what's your bike mechanic skill level on a scale of 1-10. Essential tools for the job?
I would rate my skill level as 3-5, but mainly just change the tires/tubes and do minor adjustments. Thanks for any comments!
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Most conversions are pretty simple, but achieving proper chainline is where problems often present themselves. It’s partly about mechanical skill, but also a matter of your measurement and calculation abilities. Do some careful reading before you reach for a wrench.
Space Ghost
Bikes: Bridgestone, Fuji, Iro, Jamis, Gary Fisher, GT, Scott, Specialized and more
Quoted: 292 Post(s)
Liked 412 Times
Did my first conversion way back in seventh or eighth grade.
Think it was a Taiwanese 80s boom bike my uncle gave me. He helped me strip and paint it but I did the rest myself with the guidance of some books on the subject. He also supplied the parts and tools.
My skill level was probably no greater’n what you describe yours as now.
Took a lot of time and work and it didn’t come out that great but it started the ball rolling.
Quoted: 823 Post(s)
Liked 1,395 Times
You've read St. Sheldon, right? If not, start here and get a good background before you do anything more.
Quoted: 762 Post(s)
Liked 555 Times
hello
I can’t (never attempted to) build frames, but I can do practically everything else, including lacing spokes, and modifying Brooks saddles…
Quoted: 964 Post(s)
Liked 1,628 Times
Chain line.... Oh... Did I say CHAIN LINE???
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
If you are doing a freewheel, you will probably have to pick the better chainring option and then adjust the rear alignment by swapping spacers on the rear axle, after which you will need to redish (presumably undish) the rear wheel a bit for proper alignment with the frame. Fixed gear will be about the same type of project.
Otto
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
When I built my first FG, I was a skilled mechanic but pretty inexperienced with bike stuff. Took a little trial and error to get everything just so, but not very difficult.
If you like tinkering with mechanical things, have a few tools and are willing to buy a few more, and are not in a hurry to get riding on your FG or SS conversion, you should go for it. If you really just want the bike right away and don't like to fuss with things, you'll be better off buying one complete.
Likes For Broctoon:
Clark W. Griswold
Quoted: 4349 Post(s)
Liked 3,986 Times
Depending on the task I am generally 5-7 but some stuff I am better and some I am much worse. Certain odd stuff I am like an 11. I soak up a lot of knowledge and sometimes it translates to really handy stuff that other mechanics don't pick up on.
Sheldon does a good job as does looking at Park Tool videos. But having good tools is going to help a lot and some basic knowledge will also help. However I wouldn't go butchering a nice frame to convert it to fixed you may want to convert it back to a nice road bike.
I haven't done a fixed gear conversion yet though but did build up my last fixed gear but it was not converted it was designed as a fixed gear and have also built a few other bikes not fixed.
Likes For veganbikes:
Quoted: 964 Post(s)
Liked 1,628 Times
Off OP subject:
So true... I remember my "Sutherland's Handbook for bicycle mechanics". I got that book when returning from my first overseas tour in 78. Man what a game changer. As a guy who could not afford bike shop fees it saved me. Then years ago when ordering something off of Harris Cyclery I found Sheldon's Archive. I am still to this day, impressed!
I have only built one Fixy from a ChroMo FUJI. Took me just a few hours to strip it down. I kept the front brake. But it took me about two weeks to get the chain line set right. Ha... I shuold'a started with Sheldon...
Quoted: 823 Post(s)
Liked 1,395 Times
I would also add - do NOT cut or file or otherwise remove any brazed-on frame fittings, hangers, etc., from a frame being converted to fixed-gear. If you are fortunate, you will be able to score something early enough from the era of minimal braze-ons. My current conversions include a '73 Raleigh Competition, which has a pip to keep clamp on shifters from sliding and cable housing stops for the rear brake on the top tube and a chain stay cable stop for the rear derailleur. My other conversion is a '71 Gitane TdF, which has a pip on the downtube and nothing else.
Likes For rustystrings61:
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Do what you can with the skills and tools available, including reference materials like Sheldon Brown and Park Tool. If you run into something beyond your skill level or requiring tools you do not have or cannot afford, you can always outsource those tasks to a bike shop or co-op.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
If you have a regular bike with horizontal dropouts, the simplest possible conversion is just to remove the rear derailleur and cut the chain shorter so it wraps around the small chainring and one of the cogs in the middle of the freewheel. All you need for that is a chain-breaker!
RUSA #7498
Originally Posted by noglider
Likes For ThermionicScott:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Good comments provided already. I will echo "chain line", which may be the most technical aspect of the entire process. Otherwise, to answer the original question, about the difficulty rating. Where 2 = building a new box shipped bike; 5 = specifying, accumulating and assembling all parts of a modern geared bike; 7 = lacing, tensioning and truing a dished wheel; and 9 = modifying/repairing a high-end steel frame, I'd say that converting a suitable existing bike to fixed from geared would rate at a 3-4, depending on the bottom bracket/crankset re-use or not.
