Schwalbe One
Car free since 1995
Bikes: M5 Carbon High Racer, Trek Emonda SL6
Quoted: 14 Post(s)
Liked 10 Times
Schwalbe One
Hi all,
We weigh in right at the weight limit for Schwalbe One tires. These are the tires with micro skin that would be used with tubes, not tubeless rims. Any reason why these are a worse idea than Gatorskins?
Thanks!
Thanks!
Bikes: HP Velotechnik Streetmachine GTE, 2015 Devinci Silverstone SL4, 2012 Cannondale Road Tandem 2, Circe Morpheus, 2021 Rose Backroad, 2017 Devinci Hatchet
Quoted: 181 Post(s)
Liked 14 Times
Not as puncture resistant. We have Schwalbe Ones and Gatorskins. The One's feel softer on the road, but have had their more-than-fair share of punctures. Gatorskins have been trouble-free.
Likes For alias5000:
Bikes: '06 Bianchi Pista; '57 Maclean; '10 Scott CR1 Pro; 2005 Trek 2000 Tandem; '09 Comotion Macchiato Tandem; 199? Novara Road; '17 Circe Helios e-tandem:1994 Trek 2300
Quoted: 147 Post(s)
Liked 93 Times
I've always found Gatorskins very difficult to mount and remove from the rim. No experience of Schwalbe One.
Have been using Schwalbe One for years. They ride great and rarely get a flat.
The last one was because I wore the tire down to the cords.
Gatorskins ride like bricks.
Team weight ~260 lbs.
Bikes: Santana Beyond PHD DA/ XTR Di2, Canyon Ultimate CF SLX DA Mech (Canyon refused valid warranty claim), 2021 Specialized Tarmac SL7 12 spd DA, 2022 No.22 Drifter X 12spd DA, Budnitz Alpha- Gates belt-Alfine internal
Were riding 32mm Gatorskins and are considering trying the 32mm Schwalbe Ones. Want something more performance oriented for high speed descents and cornering. I agree with everyone, the GSs ride like a brick but are sturdy and puncture resistant. Our team is 330 lb + 40 lb loaded tandem. The OP didn't say what the weight limit is for Schwalbe Ones.
Should we make the switch ?
Quoted: 2494 Post(s)
Liked 738 Times
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
To save some posters their time, I did the calc and the all up tandem weight limit for Schwalbe Ones would be 308, 70kg/tire.. Our current team weight is 285 + 36 for stripped bike + say 10 for baggage and water = 331 lbs. We ride 28 or 32 mm Conti 5000, at 95 for the 32mm, 105 for the 28mm. At those pressures we no not pinch flat, period. We have done loaded tours on 28mm tires at 115, no pinch flats then either. We have no problem with the 5000 tires. Sure they flat, but it's rare, plenty rare enough that we would never run Gatorskins.
I don't find a weight limit anywhere for the 5000 tire series. I have no idea why Shwalbe would put a limit on their tires. I note that the max pressure listed for tubed Schwalbe tires is similar to that listed for Conti 5000. One would think that max intended load would be a function of max pressure and width.
Results matter
Results matter
Likes For Carbonfiberboy:
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 463 Post(s)
Liked 546 Times
I have used both Conti GP5000TL 700CX25 and Schwalbe Pro One 700C X 25 on my solo bikes. I have run both of these tires tubeless. Both are good. Both seem to have their weaknesses. I have had two GP5000s fail with the bead separating from the tire carcass. I had 3 of the Pro Ones suffer premature failures due to sidewall cuts more than 10mm in length. I currently have GP5000s on 2 bikes and Pro Ones on one. The one with the Pro Ones gets the fewest miles. I consider the Pro Ones to be a bit more fragile than the GP5000, but the catastrophic failures of two nearly worn out GP5000s on the solo bike are a big weight on my mind. When the current GP5000s wear out I will hopefully be able to get the GP5000S TR. If they are not available, I will switch to Pro Ones. But I expect to be riding Jumbo Jims for the next few months.
We have used Schwalbe Marathon and Conti GP5000 on our tandem. The Marathons were 700C X 37 and the GP5000 are 700C X 32. We ran the Marathons at 85 PSI and the GP5000 at 90. The GP5000 are decidedly faster. We had one pinch flat with the Marathons on a fast downhill on a Scottish "B" road with unavoidable potholes. The Marathons seem to last for ever. The rear GP5000 was below the wear indicators at 2000 miles, but the front is just fine. Our maximum all up weight is right around 500 pounds, which rules out the Pro Ones on the tandem. I expect to stay with the GP5000s on the tandem. Hopefully I can get some of the GP5000S TR in 700C X 32 as well.
Likes For DangerousDanR:
I’ve been happy with 32mm GP5000 front and Conti 4 seasons on the rear of the tandem, both at 90 psi with Schwalbe Aerothan tubes. As ridden, total weight is probably about 350 lbs. This combination has been smooth and trouble free so far. I switched to 4 seasons on the rear a few years back when I kept getting rear sidewall cuts on GP4000. Apparently I am not as good at missing hazards that might damage the sidewall with the rear wheel as with the front. I haven’t had that problem with the 4 seasons.
Many years ago I used gatorskins on the tandem and they were reliable, but once I tried more supple tires I decided to move on.
Likes For reburns:
Liked 1,938 Times
Results matter
Results matter
Bikes: 2010 Bob Brown Cycles tandem, 2019 Co-Mo Carrera tandem, 1980 Richardson tandem, 2014 Cervelo R3, 2018 Specialized Roubaix, 1985 Bianchi Campione, 1983 Trek 720, 2020 Trek Fuel EX8, 2021 Salsa Mukluk
Quoted: 72 Post(s)
Liked 116 Times
For the last two or three years I've been running Schwalbe Ones (w/V-guard) as well as GP4000s without any issues at all, but I think we're pretty fortunate to have nice country roads to ride on in our area. I don't think we've had a flat in at least 10 years or so. I'll likely go with GP5000s once I've worn out the remainder of the Gatorskins.
I gather that you find the roadability of the 4 Seasons to be similar to that of the 5000, like wet weather road-holding and the like. I wouldn't mind running more durable tires for winter and unknown roads, though I've never had a sidewall or other issue with the 5000. Put them on as soon as they appeared in the market.
Likes For reburns:
