Addiction 2021.4
#5076
So it is
Quoted: 11393 Post(s)
Liked 4,734 Times
In my best coach voice...
WTF are you doing?
#5077
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12736 Post(s)
Liked 7,647 Times
Oof, the sweet motorhome may not be available ATM:
They have an Instagram it’s @quirkycanary
So it looks like they may have taken the Airbnb down for now. I know they wanted to use the money they make from renting it to restore it since they originally bought it to be used as a family RV, and it broke down on the drive home. So they might be doing some maintenance on it right now or something.
#5078
So it is
Liked 4,734 Times
#5079
Quoted: 10235 Post(s)
Liked 5,180 Times
#5080
Mostly Harmless
Bikes: Have two wheels
Quoted: 13694 Post(s)
Liked 4,520 Times
#5081
Bikes: everywhere
Liked 7,647 Times
#5082
Liked 5,180 Times
#5083
Bikes: Shmikes
Quoted: 10150 Post(s)
Liked 5,841 Times
#5084
VFL For Life
Bikes: Velo Volmobile
Quoted: 28577 Post(s)
Liked 1,849 Times
#5085
Liked 5,180 Times
I did it on my first zwift ride. Garmin estimated my ftp at like 232 I think. I never got to do one with the madone before I left, so I really have not idea what my ftp is.
I will say my mouth hurt after the second 3- - watt interval. I could feel my pulse in my tongue.
#5086
So it is
Liked 4,734 Times
At this point in time, there's no reason to be spiking anything like that. It is going to grind you down so quickly, that any steady state ride longer than an hour, is going to kick you into the dirt. You flat do not recover from stuff like that in a couple of days, simply because your body isn't ready for that stress. Stress is an evil mother, and you have no idea you're upside down until it's too late.
Likes For LAJ:
#5087
Quoted: 9651 Post(s)
Liked 6,363 Times
Having these coming to the house. The store in fort worth got bought out. Going to keep selling specialized and bmc, but going to start carry trek and giant as well. Mellow Johnies gear will be gone.
It was a neat store and the bike paths looked nice. Debating to to take my bike when I go pick up the rock hopper tomorrow.
There are two stores, that one and Austin. Austin was started by Lance, and FW was owned by someone else. The Austin store carried Trek as well. I wonder if Lance's group now controls FW.
Take the bike and ride the trail. Head west and go to Benbrook Lake.
#5088
So it is
Liked 4,734 Times
Likes For LAJ:
#5089
Liked 6,363 Times
#5090
Liked 6,363 Times
#5091
Liked 5,180 Times
So if I wanted to do intervals, using a power and time should I keep under 400? 500?
example 3 mins at 150 followed by 30 seconds of 350?
Im new to the interval thing. Obviously I have no idea what I am doing.
#5092
Liked 5,180 Times
Hadn't heard that.
#5093
Quoted: 8261 Post(s)
Liked 8,998 Times
It seems like it was Peter Boyle but that's all I can recall.
#5094
Liked 8,998 Times
I worked with a guy who had a Cortez motorhome. They came out in 1963 and had a Clark forklift drivetrain. Front drive stickshift!
#5095
Quoted: 20808 Post(s)
Liked 9,450 Times
#5096
Liked 9,450 Times
If you're going to do some workouts on Zwift, do an FTP test first, you can start with the Ramp Test, and then don't go jumping in to the deep end. Maybe try some of the base-building plans until you get a better feel for things.
#5097
So it is
Liked 4,734 Times
tonight was easy 6x4' Over Under 90-100 rpm 15 second 300, 45 seconds 225 80-90 rpm. 4 minutes rest.
Tomorrow more of Tuesday night.
Saturday a fast 45. So a couple hours at tempo, usually 45-46 miles. This after the same weights as Tuesday, except add 5 pounds.
Sunday 3.5 hours Zone 2.
That said, I'm over my ftp here and there, but not for long. All I'm trying to do is do better on weights, and the bike is basically in the way of that. The bike will come later. I do this to hit the podium here and there. Not often, but anytime one hits it in the open classes, it's a good day. I work hard to be a mediocre bike racer. I rarely let on what I'm up to on the bike, simply out of respect for my coach, but one week out of many years should be OK.
You need to first find your FTP, true FTP. Train off of that, and train off of power. You also need to set base. You don't need to start breathing hard until January and February. You need base. You need cadence work. You need to be comfortable in the drops. I spend a 45 minute crit in the drops, and am pretty much OK with that. You need base. You need structure.
#5098
So it is
Liked 4,734 Times
#5099
VFL For Life
Liked 1,849 Times
Consult your doctor.
You're going to be disappointed with your hillbilly preconceptions if you don't venture into the boondocks.
#5100
Liked 5,180 Times
Right now, my intervals consist of: 12 minutes-4 minutes low cadence 47rpm@ 265-270w 1 minute drops, 1 minute hoods, 1 minute tops, 1 minute standing. 4 minutes hc 100-110 around 225w 1 minute drops, hoods, tops, drops, then return to low cadence position changes. 6 minutes rest, then 12' HC, Low cadence, HC with those same position changes. These were last night after doing squats, deads, and lunges starting at 4am. 3x5 heavy, (well over body weight) 3x10 70% Deads 2x5 heavy, 2x10 stiff legs dead lift 70% Lunges 1x10 each leg front, 40 pounds, 1x10 each leg rear 40 pounds, Farmers walk lunges 45 in each hand, 2x10.
So after I let my legs rest a bit i’ll do the ramp test and what not, until then I’ll just take it easy on zwift and cruise around.
Avoid mountains they have been killing me these past days.
