Bike Suggestions
Bikes: 2020 Giant Escape 1
Bike Suggestions
Not sure if this is the right forum, but since I'm in the >50 category (61 actually), I figured I'd start here. I was a crazy road biker in my 20s into my early 30s until I tore my ACL (not on the bike). I did the full rehab and couldn't get comfortable on the bike and gave it up. I started riding again in 2020 to see if I could handle it without any pain. I was leery of road bikes, so I got a Giant Escape 1 hybrid bike and have been loving it ever since. I've really been expanding my rides into the countryside more and more (30-50 miles), and have added clipless pedals. I'm definitely feeling the slog of the bike and am not sure if I should go with another hybrid/fitness model in carbon or if I should make the transition back to a road bike. I'm relatively new to the area and the local shop really hasn't been able to give me a lot of insight, so I'm looking for any suggestions.
I do use some of the local bike paths to get to the outlying roads in my area, so whatever I get has to be able to maneuver those too.
My fitness choices are a Giant Fastroad Advanced 1, Trek FX Sports 6, or a Specialized Sirrus X6.0. For road bikes, I've been looking at a Trek Domane SL5 or Specialized Roubaix.
Any suggestions are appreciated. Thanks.
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
I am decidedly biased, but have you considered either an older road touring bike or something newer with similar frame geometry and configuration?
Thanks...I had not considered that as an option...I have a spreadsheet with all of the geometry from each of those bikes, but this is something I will take a look at...my 30 year-old self keeps pushing me toward a road bike, but a touring bike is a good option too. Thanks again!
In my area there are dozens of road bikes with carbon frames and Dura Ace 105 or Ultregra group sets that are selling for less than $2,000. These have modern geometry and 9 speed cassettes and these sold originally for 3-4 times the current asking price. Even if you put on new tires you will still be way ahead. You can also decide exactly what type of handlebar and what saddle and what pedals you want on the bike. With every bike I have owned I always replaced the factory handlebar with a Cinelli one and put on a new saddle and often replaced the brake pedals as well.
Even changing out the cassette for different gears that work better for you and where you ride or changing the chainrings for the same reason is a relatively minor upgrade and the cost is more than covered by what you save with the purchase of a new bike.
Mountain bikes have changed a great deal over the years but the main changes with road bikes has been combo brake lever gear shifters, more speeds at the rear, and hydraulic brakes. Only going to the brake lever shifters actually made a difference for my own riding with my road bikes.
Quoted: 8279 Post(s)
Liked 9,034 Times
Some of the nicer gravel bikes would make a versatile road bike, too.
Likes For big john:
Bikes: 2023 S-Works Tarmac SL7 Dura-Ace Di2, 2022 Cervelo Caledonia-5 SRAM Rival etap AXS, 2019 Specialized Sirrus Elite Alloy, 1977 Schwinn Super LeTour 12.2, 85 Bianchi Limited Shimano New 600EX
Quoted: 25 Post(s)
Liked 50 Times
I recently made the transition from a Specialized Sirrus Elite Alloy Disc to an "endurance" style road bike. I looked at the Domane and Roubaix and ended up with a Cervelo Caledonia 5. I'm sure I would have been happy with any of the top brands, but the LBS had the Cervelo in my price range with the options I wanted.
I'm 57. For me, the "endurance" geometry provides a good balance of comfort and performance. The carbon frame and 30mm tires provide a much smoother ride than the aluminum frame Sirrus. My rides range from 40 to 65 miles, 4 to 5 times a week. My goal is 200 miles per week.
I still use my hybrid for puttin' around and towing my daughter in the trailer.
Quoted: 4405 Post(s)
Liked 4,856 Times
There are a lot of options. First decision you have to make is road vs hybrid. If you can't decide, then a gravel bike would pretty much cover both bases. Something like a Specialized Diverge.
Likes For PeteHski:
I started riding last year, my first bike was a Giant Escape disc 1. I lost the 25lbs I needed & decided to treat myself to a Giant Revolt Advanced 2, had a bump with it on my first ride, took advantage of Giants trade up program & bought the Revolt Pro 1.
This was a great purchase, I love the feel of the gravel bike on the bad roads in NJ, Trying to hit over 3000 miles this year.
Quoted: 1944 Post(s)
Liked 2,164 Times
First criteria on my mind is how flexible you are. Can you ride on the hoods or drops on a road bike? Will you need to bring the bars up if you can’t bend over enough.
If you are able to use a road bike, I would advise against getting a 30 year old bike. I still ride one, but I’ve ridden it for decades so gearing upgrades were no big deal on an already sunk investment.
Modern bars and brake hoods are more comfortable, (I finally swapped out my old non-aero 7400 brake levers and my left thumb no longer aches after rides).
A road bike on a MUP will handle better than your hybrid.
John
John
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
I agree about looking at gravel bikes. They run the gamut from more aggressive road-ish geo to practically MTB geo, so you have lots of options for how upright you want to be, and even if you want drops vs flat bars. Probably the most versatile option for sure. And a tire swap is all you need to make them more/less road or dirt oriented.
Quoted: 980 Post(s)
Liked 776 Times
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
I also got back into cycling relatively recently after 15 years of not much riding and am 60. I got a Specialized Roubaix and it has worked out very well.. no problems at all with comfort and plenty fast. It is a good in between option if you don’t want to risk the full-on race geometry. Endurance bikes also are great for bike paths and light gravel, I run 35mm tires for gravel and 30mm on the road or for fine gravel bike paths.
Quoted: 896 Post(s)
Liked 2,063 Times
I recently came back to drop bar bikes at 60, after about 20 years away. In my case I've been riding a recumbent for 20 years due to low back issues. My back is better than it's ever been, and I felt there was a chance I could find a drop bar fit that would work.
My initial thought was, I don't care about anyone's ideas of what a bike is called (road, gravel, cross, touring, adventure), but rather I care about fit and features. The good news is, with all that proliferation there are tons of options.
For fit, since I really had little idea on what would work, I started by buying an old road bike as a test bed. I iterated through fit changes, which involved changing stems, and moving saddle height and fore-aft. I put a quill-to-threadless adapter on, so I could try different stems from the local co-op. At the end of this experiment, I had a target frame size, with ideal stack and reach. You could probably do the same with a bike fitter; I wanted to do it myself.
Feature-wise, I let my intended riding drive my feature list. For me that was for long-distance, all -weather riding. Fenders, multiple bottle mounts, room for wide tires, slacker geometry. Based on other experience, I wanted disc brakes. I had a price-point in mind, which put me in a bracket component-wise. Finally, I preferred classic lines, which favored a steel frame. Your own list will be different, but the point is come up with your desired feature list based on how you want to ride. A bike for shorter, faster, high energy rides in fair weather on smooth roads would be very different.
From there, I started looking at specs for off-the-shelf bikes. The list was pretty short. I came super close to pulling the trigger on a All City Space Horse, but ended up buying a Soma frameset and building up a bike myself.
Basically what I'm saying is, your choice should be driven by what fits you and how you're going to ride.
Likes For downtube42:
I just got a new road bike (Domane al 5) after riding a hybrid for several years.
No problem with the transition at all. Love the fit of the Domane. It's a very comfortable ride.
The aluminum frame is just fine for me. Don't find it heavy at all. I considered getting the carbon model but the LBS I got my bike at wasn't sure when they would get one in. I ordered in late May and got the bike in late October.
I think a endurance style road bike would be a great choice for you.
Bikes: Bianchi Infinito CV disk, and rim brake
Quoted: 29 Post(s)
Liked 97 Times
Fit and comfort is key with your choice. The Roubaix is an excellent bike. Good luck, and ride safe.
yes, I am a nerd...I want to do side-by-side to my current bike that fits perfectly with no nagging knee, butt or arm problems...you should see the pivot tables!
Likes For jahzed1:
Likes For ofajen:
Quoted: 284 Post(s)
Liked 313 Times
Interesting how a trend in gravel bikes right now is for flat bars (I only really pay attention to gravel and "adventure" type of bikes, admittedly). The idea being it's for better offroad control--I get that to a degree - but also for comfort. To me, a drop bar with the hands on the hoods is waaaay more natural a position for the hands/wrists/arms. I take more of a beating through my arms on rough stuff or on long hard rides with flat bars, than with drops.
Likes For pbass:
Don't overlook the difference that tires can make to ride comfort. In the past it was 23mm road tires on everything. Even pro riders have move to 25mm or 28mm tires which can be run at much lower pressure with no real increase in rolling resistance. A 700c25mm tire provides 15% more volume than a 700x23 tire and can be run at 15% lower PSI and provide the same amount of support for the bike and its rider. Going to a 28mm tire the air pressure can be 30% less than with the 23mm tire and with same amount of load support.
Even going to new wheels is less expensive than buying a new bike and a used bike is going to have narrow rims and limit one to narrower tires.
Likes For Calsun:
Quoted: 284 Post(s)
Liked 313 Times
Quoted: 12192 Post(s)
Liked 1,496 Times
My favorite bike is a Gunnar Sport, changed my life. One of the bikes they make is the Fastlane, which might be worth taking a look at.
https://gunnarbikes.com/site/bikes/fast-lane/#
Liked 4,856 Times
Likes For PeteHski:
Let's do a Century
Quoted: 651 Post(s)
Liked 879 Times
Like a few others have said, look at some road bike frames with geometries very similar to what you’re currently riding. As you know there is a lot of adjustments that can made with stems and stem heights that should keep you comfortable. You might look for some frames with taller head tubes as well. It sounds like you have the saddle height currently dialed in to best suit you right now so it’s more a question of keeping the reach comfortable for you. I’m always about lighter is better so you might also compare weights on different bikes. Stock wheelsets are typically 1800-1900 grams so you could save close to a pound with getting a wheelset in the 1400-1500 gram range and with wider widths for using wider tires. You’ll really notice lighter wheels on the hills and accelerations.
Ride your Ride!!
Ride your Ride!!
I discovered 650B tires about ten years ago. For me a light touring or randonneur bike, equipped with 38mm or 42mm wide tires is fast enough on pavement and capable on trails and dirt; and above all, they are comfortable.
Look at some of the offerings from Crust, crustbikes.com. or Rivendell,
Likes For ironwood:
