WHEN do you put the studs on
Quoted: 5224 Post(s)
Liked 3,581 Times
WHEN do you put the studs on?
a little early this year. hope I don't regret it too much. heated them up w/ a space heater, rubbed some Armor All on the beads & wiped the insides w/ paper towel. sidewall says 35-70psi. I put 40psi in the front & 50 psi in the back, as a starting point
lots of moisture in the wheels, from the recent water rides I guess
dried off the tubes
checked the 2 patches, as I do, twice a year
forgot the official size they were
noticed 1 had slightly better studs, so I put it up front. I've read that's the best place for the better tire, studs especially.
one is a little deformed from shipping several years ago. they mount up fine under pressure tho
after a test ride in the parking lot, put the bike on the car, then remembered to take the bar ends off & put the barmitts on!
now I gotta go look for trouble, right?
dried off the tubes
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4389 Post(s)
Liked 3,016 Times
They went on after my ride on Sunday, 12/5. I should put them on *before* that ride, as it was hella icy.
Putting them on was difficult but not as bad as some other times. I did use a tire lever and also some hand soap on the rim. In this case, success cam when I ended the job at the valve, while pushing the valve stem in to get the tube away from the rim.
Schwalbe Marathon Winter 35s on Stans ZTR rims.
Likes For MinnMan:
Liked 3,016 Times
dried off the tubes
dried off the tubes
Also, Schrader, huh? ,
Likes For MinnMan:
Liked 3,581 Times
tubes are holding up, a cpl years now. but I hear ya. & yeah Schrader on all our family bikes. 7 in all. it's just easier that way & I dislike Presta. no good reason for them anyway. a few of the bikes came w/ Presta & I just drilled them out. no big deal. easy to top off w/ the car compressor too
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
I win, I put mine on months ago
We only get a couple weeks a year when they are needed so I have extra rims for them. Otherwise I would just sit out those couple weeks, too much drag to ride studs all winter here.
Likes For scottfsmith:
Likes For sloppy12:
Bikes: Cannondale '92 T600 '95 H600 '01 RT1000
Quoted: 92 Post(s)
Liked 109 Times
They have stayed on my hybrid for 11 years or so now. I keep thinking of putting slicks on for the summer as it's my only bike with fenders, but it hasn't happened. Maybe next summer...or not!
Likes For MNBikeCommuter:
Liked 3,581 Times
had a great test ride last night. probably filled them at 50 degrees in my basement & the test ride was at about 30 degrees. the front felt fine, the back may have a felt a little soft. might try another 10 psi in the rear. I must have figured out what pressure I like, at some point in the past. I should write a note & tape the note to the tires, when they come off, to save some trial & error next December
Liked 3,581 Times
Liked 3,581 Times
In addition to putting studs on I sometimes sharpen them, though I wait until the pavement is covered. I'll put the bike in the repair stand outdoors (carbide dust is bad for you) and give the top of each stud a few swipes with a diamond file to de-mushroom them. It creates a nice sharp edge. Generally its just the center ones that need work.
Part of me wants to sharpen them to a point, but that would be a lot of effort and needlessly remove too much material.
Liked 3,581 Times
Likes For gecho:
Quoted: 92 Post(s)
Liked 109 Times
So, I've now installed a Mr. Tuffy liner to see if that takes care of the studs-wearing-through-the-tire-issue-without-causing-flats-itself, and stud sharpening.
Meanwhile, our 8" of snow from Fri's storm is quickly disappearing as here in the Twin Cities we're having a Dec heat wave, including a record high today of maybe 54F, and unprecedented severe storms possible this evening, and a wind warning with winds gusting to 80 mph tonight. I think the road bike will be coming out tomorrow for the next week, giving me plenty of time to put a new front derailleur on the winter bike, touch up some paint, sharpen some studs, probably clean and oil the new chain after only 200 miles and lots of briny slop, and...
Why do we do this?
Liked 3,581 Times
