Left Side Drive ? (!)
my nice bike is at home
Anyone ever come across a true Left Side Drive: crank, chain & cog on the left side.. is it possible? Why would anyone do it ? & how did it work? Just curious.
Pretty sure there are logical reasons for the application, and it IS possible..
ps. Sorry if there is already been a WHOLE thread about this,
I couldn't find it if there is one..
BMC Race Machine / BMC Team Machine / Rossin Record / 80's Pinarello Traviso / Merlin MTB / Raleigh "Folding 20" / Ti-Swift (!)
Erikson w/C&C couplers / Trek's: 2300, 1200, 990 / Jamis 'Sputnik'
Mad bike riding scientist
Quoted: 6147 Post(s)
Liked 4,093 Times
Stuart Black
Stuart Black
Palmer
Bikes: Mike Melton custom, 1982 Stumpjumper, Alex Moulton AM, 2010 Dawes Briercliffe, 2017 Dahon Curl i8, 2021 Motobecane Turino 1x12
Quoted: 1646 Post(s)
Liked 1,785 Times
Ah, of course Sheldon "Why be normal?" Brown has been there!
Spoke to him on the phone once, nice guy, was going to buy a 'special' fork from him, but it was towards the end sadly,
for him. (...& for ALL of us!) ..so don't know what happened to all his wonderful creations. Anyone know?
I suppose it would be a necessity for someone with one leg, the left leg..right?
Why do BMX-ers do it? Does it have to do with the direction of the track> ?
Or to Psyche others out?
Guest
Quoted: 1346 Post(s)
Liked 3,269 Times
BMXers who grind on the right side have used LHD bikes for years. You can buy them stock.
Old fart
Quoted: 3571 Post(s)
Liked 3,367 Times
Quoted: 281 Post(s)
Liked 641 Times
“I suppose it would be a necessity for someone with one leg, the left leg..right?”
People with one (left) leg still can ride with drivetrain on the right, as long as they have the left crank and pedal.
Bikes: 1974 PX-10E sold, 1977 Witcomb stolen, 1980 Roberts 1 speed, 1987 Cyclops 3 x 6 friction triple crank, 2010 Masi Commuter 1 speed, 2017 Ribble 525 2 x 10 with Ergos
Quoted: 58 Post(s)
Liked 25 Times
Unless you can fabricate your own freewheeling mechanism, the left side drive bike has to be a fixed gear. There must have been left hand freewheels for the BMX bikes mentioned. Sheldon's fixed SA hub could have had a lugged drive sprocket. If it was threaded, there was no doubt a lockring thread as well.
As to why? Because you can.
oldschoolbike
oldschoolbike
Quoted: 58 Post(s)
Liked 25 Times
More on left side drive
Left hand BMX freewheels are widely listed on eBay. Presumably there are hubs to match. Here's something else though:
I found a picture, but not the explanation that is (or was) out there somewhere.
The great Canadian rider and innovator in a conservative time, Jocelyn Lovell, built and rode a track bike with drive on both sides, to give a two-speed automatic for the kilo ride. As near as I can recall and work out again, this is how it worked: The right side had the lower ratio, implemented with a single freewheel snug on the free side of a fixed/free hub. The left side had the higher ratio, and started each run with a threaded cog set loosely on the hub. As the bike was pedalled, the threaded cog would overrun the hub, pushing it outward (thread is “wrong” on the left) until it hit a reverse-threaded (and maybe jambed?) lockring. Then the higher ratio would simply over-run the freewheel, and drive for the rest of the ride would be on the left. The bigger the ratio difference, the shorter the run in low gear. He had to back-pedal the bike to re-set the gears. Implementation would have been reversed and cleaner if he had a left hand threaded hub. I will gladly stand corrected on any of this if somebody knows otherwise.
In several ways, Jocelyn Lovell was Canada’s own Graham Obree.
oldschoolbike
oldschoolbike
Likes For oldschoolbike:
Quoted: 4172 Post(s)
Liked 3,792 Times
Track racers tried LH drive decades ago to move the RH crank arm/pedal inwards to reduce banking strike when jockeying in a marched spring. Andy
AndrewRStewart
AndrewRStewart
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
oldschoolbike
oldschoolbike
Genesis 49:16-17
Genesis 49:16-17
Likes For asgelle:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
The US Women's pursuit team has been on LH drive Felt bikes for years, since the Rio Olympics.
Likes For cxwrench:
Liked 3,792 Times
AndrewRStewart
AndrewRStewart
Liked 3,792 Times
I fail to believe that having the drive on the LH side would be any more aero than its being on the RH side. If anything having only left turns on a track it seems to me that a RH drive would be more in the aero shadow than on the LH side. Andy
AndrewRStewart
AndrewRStewart
That's certainly more convincing than all the CFD and track testing Felt and USAC have done on this design.
Likes For asgelle:
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 834 Post(s)
Liked 332 Times
For most people, the right leg is dominant, just like the right hand. There is presumably a slight benefit in the transfer of the force to the chain being shorter for the dominant leg. The actual choice of the side could have been, though, very much an accident of history.
Jocelyn Lovell ... dual drive ...& interestingly set up: switchable(!). Speaking of which, how did Sheldon get the 3-speed hub to have 3 gears once it was flipped over? There is no information on that, just on the thumb-shifter he adapted a bit.
Quoted: 58 Post(s)
Liked 25 Times
At least one of the gears of a normal freewheeling AW three-speed hub works by over-running a directional clutch (you can hear the pawls as you pedal), so there is some directionality in the planetary gear set. It's hard to imagine that that would function as a fixed gear, so maybe the fixed 3-speed hub had a different implementation that eliminated any directioanality. Or maybe not, and Sheldon's modification was to block out the gear that didn't like being driven backward.
I had enough trouble getting my head around Lovell's transmission with nothing but a poor photo and single-sided freewheel hub in my hands. I don't think I can do the thought experiment well enough to work out how a three-speed fixed gear hub must work without any artefact or documentary evidence to work with.
oldschoolbike
oldschoolbike
Old fart
Liked 3,367 Times
Quoted: 58 Post(s)
Liked 25 Times
That makes sense. Sheldon refers to the ACS as having very different gear ratios from the typical AW freewheeling 3-speed and no "overdrive" ratio. There may have been some common parts, but to first order anyway, it was a different hub.
So the question remains, what did Sheldon have to do to the gear shifter? If it was a true fixed gear in all ratios, what would be the problem be with running it backwards?
oldschoolbike
oldschoolbike
Senior member
Quoted: 937 Post(s)
Liked 652 Times
oldschoolbike
oldschoolbike
I did this video nearly 10 years ago to demonstrate hot the S3X works.
Made in Taiwan
Bikes: Camerotti ti roadbike, Old Sears Free Spirit Tange Hi-Ten Single Speed built from a 12 speed, 1997 Cannondale CAD3 r500 with Shimano 6400 groupset
Quoted: 35 Post(s)
Liked 11 Times
My main commuter is a left hand drive fixed gear single speed.
I use SPD pedals, which have poles. So, to make the crankset work, I installed helicoils in the cranks so that I can have my pedals oriented correctly. Rides exactly the same really. The rear hub is set up with a Shimano Deore XT, HB-M756 hub (6 bolt disc front hub), that has the original axle replaced. The fixed cog is bolted to the hub where a disc rotor would go.
Fun bike and to be honest, most people don't even notice that my bike is not "normal".
All dogs want to be lap dogs doesn't matter the size
-Animal loving friend
