Fast 35-42mm road tires
Quoted: 1392 Post(s)
Liked 1,852 Times
I really liked my Compass Barlow Pass 38mm Ultra lights. Thin and flexible, like a road tire, and no tread, good. The ride was amazing on new, rough chipseal roads, and fast on smooth roads. Cornering was really grippy.
But one tire developed a bulge, it appears the fabric casing is failing. I didn't hit any curbs or deep potholes.
casing and the tread thickness might actually be less than optimum - and puncture resistance and durability below the line
Advanced Slacker
Quoted: 2761 Post(s)
Liked 2,534 Times
Again, this isn't something that has borne out in testing - here's a snippet from an RChung post, feel free to follow the link back for the thread/context -
This is good enough for me. I'm sure that, should further info come to light, guys like Robert are going to know and share the info before a schlub like me does "internet research" to blow the cover off.
One takeaway is that you are not going to find some particular test that verifies the reliability of the drum test method (this was one of the arguments I was engaged in in that thread). The data he is basing his conclusion on is spread out over a year or so of discussion in Slowtwitch. I personally don't feel the need to dig through all that, but the guy is certainly credible, and I am willing to take his word on his findings.
What I also got was the series of verification tests (which verified the drum tests as a reliable predictor of the ranking of different tires) was on road racing tires for that application. What I am still unclear about is if this have been done for larger tires (Touring and Gravel) and/or on rougher or gravel/dirt roads.
But what drum test do seem to show (from what I can see from the non-pro verison) is the the RH Superlight Casing is pretty darn fast. Which does jive with my experience with them.
Advanced Slacker
Liked 2,534 Times
I don't think they went too far, though. If there is another tire that rides like that, I am not aware of it. Its just the price you gotta pay for that. If you don't want to deal with the issues that come with such a high performance tire (and I may not want to again myself), there are a gazillion other options, including some of their other casings.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2571 Post(s)
Liked 5,602 Times
It’s one thing to have fast low rolling resistance tires, but if they are not properly inflated, then you are unnecessarily losing speed/watts. Go to the Silca site and use their tire pressure calculator for all types of tires and road/non-road conditions plus many other factors. Correct pressures do make a significant difference as well - and put the two together…..
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 20808 Post(s)
Liked 9,450 Times
As far as the OP - essentially gravel tires on pavement - I don't see why the drum rankings wouldn't be preserved.
Liked 1,852 Times
I've had many RH/Compass with the EL casings and they have held up fine on rough gravel roads. The tread itself is sufficiently thick. The main drawback IMO is that they have do not have a great track record tubeless. They seem to have fixed the blowing-off-the-rim issue a couple years ago, but I found that mine would not reliably hold air after about a year, even though there was still plenty of tread left. Went back to tubes.
standard casing might be a better choice (for puncture resistance / durability) ?
Advanced Slacker
Liked 2,534 Times
It is the sidewalls that are super thin on the EL casings. If you are hard on sidewalls, then that is a consideration. Tread life is fine on the EL and all of the sidewalls on the EL casings I've used have lasted as long as the treads.
IMO, the whole point of RH tires is the EL casing. That is the secret sauce to the way they perform and feel. If you are going to get the standard casing for the thicker sidewalls, I am not sure there is any advantage over several other tires mentioned in this thread.
Likes For Kapusta:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 411 Post(s)
Liked 897 Times
+1 on 35mm Continental TerraSpeed
They have a 40mm too, but it's a little heavier.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2134 Post(s)
Liked 1,643 Times
Seems I have read several conversations here (mainly in road cycling) where a lot of riders said that tire weight doesn't matter.
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
Likes For vespasianus:
For The Fun of It
Liked 1,643 Times
I just spooned some 700x35 Conti Contact Urban tires on my gravel bike. These are wire bead only tires that are comparatively heavy. There is not much info out there on them. Bicycle Rolling Resistance likes them quite well. They have about as good a combination of rolling resistance and flat protection as I have seen. Given that puncture protection is my #1 consideration, getting reasonable rolling resistance with it is bonus. I'll ride them after dinner and report back.
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
Toss my suggestion for 42mm Soma Shikoros. On my commuter, I swapped the Shikoros in for 38mm Marathons, and the ride difference is night and day. They feel faster, with a cushier ride, just as puncture resistant, with only one flat in 4,800 miles, and still going strong.
It claims to have the same puncture protection layer as Shikoro and a bit more tread for longer wear. Also comes with a regular black sidewall.
I really liked Vittoria Voyager Hypers, but they are discontinued.
Also Conti Speed RIDE.
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1125 Post(s)
Liked 249 Times
On my previous touring bike, I had 27x1 1/4 Schwalbe Marathon GreenGuard (now called just Marathon), those things were also heavy, not as heavy as the Kenda's but not much lighter, about 450 grams lighter per tire is all. They rode like I had attached bricks to my wheels and were slow like the Kenda's but the Kenda's did roll a bit smoother, but they lasted forever and I never got a flat, they were a very durable tire if you don't mind the weight and the harsh ride.
You have to decide if you want comfort over durability, or vice versa; I wanted comfort because on my touring bike I spend 4 to 6 hours a day on the saddle, day after day, so anything I can do to get a better ride I will do. I could have stayed with a fatter 45c tire for a smoother ride due to lower psi, but those do weigh more which means more pedaling effort, and I really didn't see a need for such a wide tire. Now my fenders fit a lot better, the old fatter Kenda's I had to fiddle with the adjustment on the fenders every day because I only had 1/8th of inch clearance, now I have a 1/2 inch of clearance and I don't have to constantly be adjusting the fenders to keep them from hitting the tires.
Likes For rekmeyata:
For The Fun of It
Liked 1,643 Times
I just got back from a test spin on these things. As a point of reference, the replaced Clement Strada LGG 700x32 road tires. As another point of reference, the best tires I have ever run are Conti GP4000 S2 tires in size 700x28.. The ride wasn't a thorough shakedown, as a thunderstorm is approaching. I rode them only on broken concrete streets up to about 20 MPH. They roll as well as the much lighter Clement tires. At 75 PSI (94 is max on these) they were compliant and not dead feeling.
Bottom line: I can see why Bicycle Rolling Resistance liked these. If they live up to their substantial puncture resistance rating, I am going to be thrilled. Interestingly BRR rated these a 5 of five and the Clements a 2 of 5. In terms of performance, these weren't that much better.
As it relates to the OP, I'd call them fast. Not the fastest, but satisfyingly fast.
Likes For Paul Barnard:
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 809 Times
Thanks again to all sharing their experience here. Some great discussion and new-to-me options for tires.
Liked 249 Times
I did the over thinking process myself just these last couple of months trying to find a fishing rod, it was pain, then when I made a decision, the rod wasn't available! ERGH!! A friend of mine who fishes a lot told me what I'm telling you...I was over thinking it. So, I went back to Sportsman Warehouse and spoke to a fishing pro and he directed me to a specific rod, but they were out of stock! However, he found one at another location so he had it sent to my house directly and I paid for it there online using their computer. Wam bam thank you ma'am I got my rod. I checked online reviews for the rod and it did get very high reviews which led me to buy it, plus the decision was helped by the pro had switched to this rod, and so did ALL the employees there that fish. So, I'm confident that this rod will be very good, I used it once since I got it but didn't even get a nimble! Fishing at its finest!!!
Anyway, don't stress over it, if whatever tire you decide on you don't like for one reason or another, look at it this way, in about 3,000 miles those tires will be shot anyways, so you can try the second tire on your list or on the reviews. I rarely buy the same tire brand twice anyways; I just get whatever is on sale! Except on the touring bike, there are not too many options for a really good touring tire, so I will probably stay with Schwalbe Marathon Amotion tires since I really like those tires for that purpose. But on the road bikes? nah, just whatever decent tire that can I find on sale.
ignominious poltroon
Quoted: 2228 Post(s)
Liked 3,412 Times
I've been riding them for several years now with great success on and off road. Both paved and unpaved surfaces here are pretty gnarly, but I've not had any issues. For awhile they were producing some Barlow Pass versions that had more than the specced tread thickness, FWIW. These are robust tires.
For The Fun of It
Liked 1,643 Times
I have now put about 60 miles on the Conti Contact Urban 700x35s and can't say enough good about them. Not quite GP 4000s, but given the much lower cost and the better puncture rating, I may have found tire nirvana for a fast all arounder.
Quoted: 759 Post(s)
Liked 809 Times
I've been running 700x38mm GK slicks on a number of bikes for the last few years and found them to be a very nice, fast all-rounder tire. Friends like them too. Last fall I built/rebuilt a bike and mounted some 700x35mm Schwalbe Marathon Supremes on it. Also, a very nice tire. Fast and great (road/rail trail) tire with a great ride. I'm hoping to get more miles out of them than the GKs. They feel very different than the GK slicks. I like them a lot. They make 40 or 42mm version that I hope fit on the bike. Your Contact Urbans sound similar. I'll have to pick up a pair and try them out.
Bikes: Surly Cross Check, Specialized Enduro Pro, Lemond Tourmalet
Quoted: 105 Post(s)
Liked 192 Times
Running 42c Conti Speed Rides. Been good. Roll better then the original Knards. Good on roads, decent on trails. Comfortable riding.
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
Yeah, not sure why Vittoria seems to have dropped their fast touring tires. I think before the Hypers it was the Randonneur Pro, a 120tpi fast and grippy tire. They don't seem to have anything in this vein any longer.
Liked 249 Times
Having said that there is one major issue that supersedes the torque and horsepower rating, it's called towing capacity. The max towing capacity that a Porsche can tow is ZERO weight; the max towing capacity of the MBZ is 4,629 pounds.
In this race the MBZ wins by a landslide.
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
If you had an AMG E63 wagon, then you probably won't be needing to tow a travel trailer with a 911 Turbo. (I wanted to make a comment about how a Chevy Suburban 7400/8100 would probably be able to tow both German conveyances and the trailer, but I already wasted that one on another thread involving a Prius.)
