Pinarello Gan 105 or Domane SL5
Quoted: 119 Post(s)
Liked 23 Times
Have a Domane ALR4 now - Aluminum with Tiagra. Looking at an upgrade.
Was looking at a Domane SL 5 Gen 3, but just came across the Pinarello Gan 105. The geometry is a bit different, but the Pinarello is way cooler looking and about $800 cheaper. Don't care much about disc brakes.
Trying to figure out if anything I'm missing anything here???
Likes For Caliwild:
Achtung!
Bikes: 60.1, Marvel
Quoted: 515 Post(s)
Liked 268 Times
I have the Pinarello Marvel, which was replaced by the Gan. It replaced my old Domane. The Marvel has rim brakes, not discs. Incredibly different rides, but I am so happy that I went with the Marvel. There’s just a certain joy in riding that bike (and my 60.1) that I never got from my Treks and Specialized bikes.
Likes For thin_concrete:
Clark W. Griswold
Quoted: 4328 Post(s)
Liked 3,949 Times
I don't want or need anyone screaming at me. I would test ride some bikes and see which one you like the best. I am not a big modern Pinarello fan and Treks aren't my thing but you have to test ride them and maybe try some other stuff as well and make your decision after test riding.
Likes For veganbikes:
The Gan is a great bike. Not the fastest thing out there, but very balanced and with plenty of zip for an endurance bike. Just keep in mind that it runs a little large, so definitely test ride extensively before settling on a frame size. If you typically ride a 56, you might be more comfortable on a 54 Gan.
Likes For Baron Blubba:
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
Likes For Sy Reene:
got the climbing bug
Bikes: one for everything
Quoted: 632 Post(s)
Liked 908 Times
love my Gan S, even done a double century on it. Great bike and looks sharp to me. Geo is race fit, unlike the Domane. So depends how you like your bike fits, but I think there are 9 different sizes to pick from. Well at least in my model yr.
Rule #10 // It never gets easier, you just go faster.
Likes For jsigone:
I wouldn't invest in a rim brake frame. The biggest improvement in the ride of any bike comes from using wider tubeless tires at lower pressures on wider hookless rims. With 25mm internal width hookless rims, 28-32mm tires can be run at low pressures without increased rolling resistance. I run 28mm tires at 52/56 psi based on the zipp pressure calculator. Rim brake calipers usually won't allow a 28mm tire that measures 31mm on a 25mm IW rim. Component manufacturers are all supporting disc brake frames now.
The Paris is the current endurance model. It has typical tall stack and short reach geometry and like most brands, the frame size numbers mean nothing.
https://pinarello.com/usa/en/bikes/r...ometrie_anchor
Quoted: 6168 Post(s)
Liked 4,784 Times
And if you are desiring a more relaxed fit, there are other bikes that will do that better than the Domane. However either is a good bike for the average person wanting a fit somewhere between relaxed and very aggressive. Don't fear the disc brakes.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
I agree about test ride before you buy.
Likes For Lombard:
