My sprocket size and ratio research.
Quoted: 790 Post(s)
Liked 348 Times
So one day I thought about how the smaller the front chain-wheel is in relation to the pedal-crank arm, the greater leverage the pedal crank arm has on pulling the chain against the resistance of the rear sprocket. Of course I knew that if you kept the same ratio, then the rear sprocket would get smaller at the same time the front chain-wheel did and counter the added leverage the smaller front chain-wheel enjoyed. But I thought, was the gain or loss with a smaller or larger front chain-wheel directly proportional to the gain or loss with the larger or smaller rear sprocket needed to maintain the same ratio ??? Or was there some small but useful gain of leverage with using the combination with the smaller front chain-wheel?
To answer this I dragged two combinations of parts from my junk-pile from which to take measurements from. One a 52/19 , the other a 43/16 combination of wheels and sprockets. I used a 170mm length for the crank-arm and a 13.5" radius for the complete rear wheel and tire assembly. Then I measured the distance from the center of each sprocket and chain-wheel to half the height of their sprocket-teeth where I thought the roller of the chain would bear.
In the end after using all of the measurements to calculate the gain/loss of the leverages of the front crank/chain-wheel combinations and the change in leverage between the different rear sprockets and the radius of the rear wheel, I found that yes it was absolutely proportional and there was no advantage in leverage or power to be had by using either combination. A friend of mine pointed out that there were fewer chain rollers in contact with the smaller sprockets so there may be less friction, but I countered that the fewer rollers on the smaller sprockets would be under more leverage, strain and pressure than the chain rollers on the larger sprockets and that would make the overall change in total friction also zero.
As long as you are having fun nothing is a waste of time......
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Quoted: 179 Post(s)
Liked 167 Times
Maybe an easier way.
Sir Mark, Knight of Sufferlandria
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,856 Times
Likes For genejockey:
Quoted: 790 Post(s)
Liked 348 Times
There is a lot of useful information in the Sheldon Brown pages and he did a lot of thinking, but I have found instances where his information is bad and this is one of those. Just because something is popular or old does not make it right, and this is why it is better to be able to think for yourself, critically and independently than to rely completely on a "smart" phone or on others for information.
Quoted: 2479 Post(s)
Liked 2,947 Times
Sheldon Brown is wrong. He states that the crank length changes the gear ratio, which is nonsense. No matter what the crank length of a bike is, it will still go the same distance with one revolution of the crank. All that changes with a longer or shorter crank arm is the torque that the rider's weight produces in foot/pounds. With his thinking if you put shorter cranks on a bike with sprocket ratios that have greater mechanical advantage it is equal to having longer cranks with a gear ratio that has less mechanical advantage, which is absolutely wrong because the rider will have to pedal the bike with the "shorter" gears, the ones with more mechanical advantage, at a higher rpm than they would the bike with the longer cranks to achieve the same top speed, but because any rider has a maximum cadence, with the one setup they will not be able to go as fast, so his theory is garbage and misleading.
But a better word would have been "leverage." The crank, after all, is a lever, and the chain ring and sprocket serve to change the effective length of that lever with respect to the work done. The choice of a lower gear results in a longer effective lever, for instance.
And thanks again for your post, because otherwise I might never have discovered that, spurred by his irritation at the fact that conventional methods of calculating gear ratios completely ignore crank length, he had invented a radically different calculation method.
Note that he jokingly gives the page where he explains his new method the byline "Sheldon (Quixote) Brown," tacitly (and correctly) acknowledging that his new and improved method would be universally ignored.
Here's the page, and here's an excerpt (where he uses the word "gear" in the last line of the first paragraph below, I suggest reading "leverage," for reasons I explained earlier):
What About Crank Length?
All of these systems share a common inadequacy: none of them takes crank length into account! The fact is that a mountain bike with a 46/16 has the same gear as a road bike with a 53/19 only if they have the same length cranks. If the mountain bike has 175's and the road bike 170's, the gear on the mountain bike is really about 3% lower!A New Standard Proposed
I would like to propose a new system, which does take crank length into account. This system is independent of units, being expressed as a pure ratio.This ratio would be calculated as follows: divide the wheel radius by the crank length; this will yield a single radius ratio applicable to all of the gears of a given bike. The individual gear ratios are calculated as with gear inches, using this radius ratio instead of the wheel size.
Quoted: 4340 Post(s)
Liked 1,526 Times
Quoted: 4386 Post(s)
Liked 4,827 Times
Am I right in saying that you were trying to prove that a gear ratio of 52/19 is more or less the same as 43/16?
Likes For PeteHski:
Quoted: 6177 Post(s)
Liked 4,794 Times
So you aren't happy with the gearing on your bike?
What is it not giving you that something else might do way better?
Quoted: 504 Post(s)
Liked 637 Times
Over many decades (some) people have argued that "leverage" is somehow a magical number to be superimposed on gear ratio. It's not. Crank length studies abound and none have shown anything other than it is easier to spin higher rpm with shorter cranks. From that, if you want to spin, use lower gears and shorter cranks, and if you want to mash use taller gears and longer cranks. And if you do the latter expect to have more knee problems and have more difficulty holding speed for long distances. Note that every hour record set in the modern era has been at 100-110 rpm.
Quoted: 790 Post(s)
Liked 348 Times
Sheldon Brown is wrong period. Nobody including him mentions different size riders. For a short rider 165mm cranks would feel more friendly than the 180mm cranks that a tall rider like me likes, both size cranks feel the same to appropriately sized riders. All riders seem to like a cadence between 80rpm-90rpm, backed up by a poll on this very forum not long ago.
All I was trying to do was research if there was that if a 1:2.7 drivetrain ratio was good for me to use, if there was any advantage to using smaller sprockets or larger sprockets because their different diameters might offer more torque, and my measurements said there was no advantage. And that thought and research has nothing to do at all with anything Sheldon Brown talks about at all, zero. Finding flaws in his thinking was just a bonus because the forum member linked to his site when they mistakenly thought the page had something to do with my research, which it did not.
Quoted: 3942 Post(s)
Liked 7,284 Times
Likes For tomato coupe:
Quoted: 1579 Post(s)
Liked 1,187 Times
Seems a harmless enough little pastime??
Liked 2,947 Times
Repeating what I explained in my earlier post, in other and simpler words:
Sheldon B. was wrong. Trivially wrong. On a technicality.
The technicality: in some instances where he wrote "gear," he should have written "leverage."
Here's that quote again, from the page I linked to in my earlier post. He's discussing systems that use equations to calculate gear inches and systems that use equations to calculate gear development. All equations in both systems use wheel diameter, chainring size, and sprocket size. All ignore crank length. I've bolded the relevant instance of "gear," where "leverage" is meant.
----All of these systems share a common inadequacy: none of them takes crank length into account! The fact is that a mountain bike with a 46/16 has the same gear as a road bike with a 53/19 only if they have the same length cranks. If the mountain bike has 175's and the road bike 170's, the gear on the mountain bike is really about 3% lower!
Sheldon then went on to provide a method of calculation that incorporates crank length and is irrefutable (to everyone but the unfortunately innumerate). See the link in my earlier post for the formula.
Now that the question of whether Sheldon was "wrong" in some sense that merits dismissal of his ideas on the subject has been shown to be a non-issue:
The 3% change in leverage in his example comparing 170-mm and 175-mm cranks would likely be all but undetectable to most cyclists in terms of expended effort---probably on the order of the effect of balanced versus unbalanced wheels on how a bike rides. That being the case, it's no surprise that the cycling world long ago settled on gear calculation systems that ignore crank arm length.
beng1 noted in a recent post that he had satisfied himself that there would be no effective difference between a combination of a smaller chainring with a smaller sprocket representing a particular ratio and a combination of a bigger ring and bigger sprocket representing the same ratio. That's certainly true mathematically. The only other pertinent consideration would be the fact that mechanical: frictional losses within the chain increase as the sprocket size decreases. Unless frictional losses also accrue from the use of a combination with a large offset in chain line between the chainring and sprocket, and those losses are greater.
Liked 1,526 Times
Quoted: 499 Post(s)
Liked 624 Times
Why do we need anything other than the ratio between the the chainring and the cassette sprocket here? And more importantly, can I score some of ya'lls stash...
I will say that there is a difference in friction (and wear), all be it small, and bigger is better in both cases.
Likes For wheelreason:
Liked 4,827 Times
Minute differences in friction due to tighter chain-wrap etc on smaller sprockets are not worth considering.
Likes For PeteHski:
Liked 4,827 Times
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,095 Times
https://www.cyclingnews.com/news/ell...speed-concept/
"Van Dijk is reported to be running a 58-14 ratio to allow a cadence of between 93-97 RPM over the duration of her attempt."
Likes For Steel Charlie:
Tragically Ignorant
Liked 9,095 Times
Let's go all in--do different lubes work better at different temperatures? Does sunspot activity affect the efficiency of electronic shifting?
Liked 4,794 Times
I never believed the myth of proportional crank sizing. About all it might do is suggest the longest crank length you might can use. Not the crank length you must use.
Quoted: 790 Post(s)
Liked 348 Times
That's just an assumption you are making. I'm 71" (180 cm) tall with 34.5" (87.6 cm) legs. I ride 165 mm cranks. Tried longer and never liked them.
A larger, heavier leg will take more energy than a shorter lighter leg to move at the same rate and same distance, that is physics and engineering 101. So if the large and small rider are in condition to generate the same watts of power, the only way physics will let the larger rider go as fast and as long as the smaller rider, is if they can have a longer pedal-crank arm which they can turn at a lower rate, a lower rpm, but still get the same power to the rear wheel. Power equals rpm x torque, so you can have less rpm if you are a large rider and get the same power for the same amount of time only if you are given a larger lever or crank arm, which you can pedal more slowly.
In the last year I have ridden road bikes I own with pedal cranks of 165mm, 170mm, 172.5mm, 175mm and 180mm. I have tested all of these bikes over the same 12.1 mile, mostly level circuit a number of times, some of them dozens of times, in the last year.. The bike with 170mm cranks, which I rode most often, had 165mm cranks the first half of the riding season, and changing them for the 170mm units gave me the fastest time around the circuit to that date. Toward the end of last riding season, when I got a bike with 180mm cranks rideable again, I chopped two entire minutes off the time it took me to go around the circuit with the 170mm crank-equipped bike, dropping the time from 37.5 minutes to 35.5 minutes, and raising the average mph from 19.5 to 20.4. I could run a faster gear ratio around the entire circuit with the long cranks, something I could not do with the same bike with shorter cranks, nor any of the other bikes with their shorter cranks.
26 years ago when I was younger and ran a lot of TT events, I was always fastest with 180mm cranks too.
Liked 4,794 Times
I never said any one "must" use any crank length. You are under six-feet tall, not that tall. I was 6'3" a lot of my adult life, might have shrunk a bit as am in my 60s now.
As for leg length I feel I have the leg length of most persons 6' 2". I run across many that height have quite shorter legs. So I think my experiences should be comparable as my leg should be of the same weight range as a 6' 2" person with 34.5" inseam for leg length.
While some of your engineering and physics suggestions seem reasonable, they also seem a little askew. You only talk about length of crank to correct for more power needed. However rpm and gear ratios also account for power too. Some people have a wide range of rpm's they can pedal, and some people have a narrow range of rpm's they can or will attempt to pedal.
Also a larger heavier rider will need more power to match the acceleration and speed of a lighter rider. So you baffle me when you say
I'll just add my $0.02 concerning crank arm length here.
In a way, Sheldon was right, shorter cranks do affect gearing - from a certain point of view. Instead of thinking of gear inches, consider how far down the road you go per inch of foot travel. Shorter cranks result in a smaller pedal circle, so a crank revolution represents the feet moving a shorter distance with a shorter crank. Less foot travel per unit of distance moved means you must expend more energy per foot travel. Things equal out since you move your feet less - and isn't that what gearing does?
