bottom bracket
bottom bracket
Can someone tell me what this plastic part with the arrow and "+" sign is for on this bottom bracket?
Yes, it is an eccentric - but I'm not sure what that plastic part is for. Do you happen to know who makes it? I'd like to find a spec sheet or other written information about it.
edit: too bad about comment below. the bike is a tandem and it is an eccentric, of course.
Likes For Germany_chris:
Quoted: 327 Post(s)
Liked 736 Times
This is correct.
https://www.parktool.com/blog/repair...g-preload-ring
Thanks! So doesn't matter that it's floating; not touching on either side.
Quoted: 4201 Post(s)
Liked 3,857 Times
As long as the bearing preload is correct and if dependent on the adjuster and if the adjuster doesn't move about all is fine. Somehow I doubt all these aspects are in agreement if the preload ring isn't contacting anything WRT the bearings. Andy
AndrewRStewart
AndrewRStewart
USAF Veteran
You'll likely have some lateral play in the crank. Watch the video above to properly adjust it.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Correct.
C'mon guys, if you don't know don't comment. And of course...RTFM.
Likes For cxwrench:
Likes For frogman:
Thanks for this video; I've never worked with this before. Been assembling my new tandem all day so this was reassuring and I will adjust as video says.
This is correct.
