Pedals to Crank arm sizing
Quoted: 15 Post(s)
Liked 7 Times
Are there different thread pitches and shaft sizes to pedals and crank arms, or is it universal? I'm winding up with crossed/stripped threads. When I search on google for crank arms and pedals, they always come separate. My pedal fell off, the threads were all stripped inside the crank arm. I put a new crank arm on with the same pedal, and I coiuldn't get the pedal on the crank arm without crossing the threads. How do I stop this from happening?
Quoted: 6193 Post(s)
Liked 4,808 Times
Right crank/pedal is normally right threaded. Left crank/pedal is normally left threaded.
Most common today are 9/16" x 20 tpi. On old one piece cranks and some other bikes 1/2" x 20 tpi is found. At various times, mostly with vintage bikes pre 1970, you'll find some different thread types and directions.
If you mixed up the crank arms, it makes me think you may have one of those very old bikes that might have different threading's and directions. And maybe won't be compatible with any new pedals.
Put a pic in the gallery here and someone might try to find it. Though you only need 1 more post and maybe a full day to be able to post pics.
Likes For Iride01:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Quoted: 3510 Post(s)
Liked 2,924 Times
Likes For smd4:
Liked 2,924 Times
I've never tried, so I don't know...but could you even start left hand threads into a right hand crank, or vice-versa?
Quoted: 15 Post(s)
Liked 7 Times
I might have mixed up the pedals too I didn't know everything was different left and right.
Liked 2,924 Times
Look for the "L" and "R" stampings on the pedal axles, near (or on?) the wrench flats. The threads are different on the left so the pedal doesn't unscrew itself while you're pedaling.
Quoted: 2338 Post(s)
Liked 2,822 Times
it has been done more often than you would think, hard steel, softer aluminum, no finesse (ready gorilla like force)
Likes For squirtdad:
Liked 4,808 Times
If the threads aren't buggered up too bad, you might can run something through from the other side and straighten the threads enough to install the pedals properly. A pedal might do that if the treads are long enough to go all the way. If not you'll have a hard time finding something long enough that is left threaded.
However if you did not notice that things where right and left threaded or that you were cross-threading, then maybe you should go to a bike mechanic with this.
DIY is better learned when everything is correct. Otherwise, you'll probably get some misconceptions right from the start that will be hard to rid yourself of.
And still, we are a little confused about you saying you can swap left and right cranks. Are there any part numbers or brand and model stamped on the cranks? Again, how about putting a pic in the gallery and we'll look for it if you can't now directly post them in your replies here.
Likes For Iride01:
Liked 2,924 Times
Bikes: lots
Liked 2,932 Times
Liked 4,808 Times
But I guess if the OP needs to pay the tuition to DIY school, this is as good as any to incur those fees.
Likes For Iride01:
Quoted: 18373 Post(s)
Liked 4,508 Times
If you manage to get old French pedals or cranks from the 60's or 70's, they're very close to the standard 9/16 pedals, and will cause all sorts of headaches.
As mentioned above, remember for pedals it is right side, right thread, left side, left thread.
For bottom brackets it is just the opposite, right side, left thread, and left side, right thread (with a few more specialty variations than the pedals).
I presume one of the reasons the threads get bungled is that people overtighten the left side trying to remove the pedals.
Always hand tighten screws until you get several turns before grabbing for the wrenches. Sometimes turning backwards a couple of turns will help you orient the shaft before threading it in.
If pedals have stripped the threads, then make sure the threads are super-clean before reusing.
A good shop may be able to helicoil stripped crank threads, but for a cheap bike, doing so may be more expensive than just replacing the crank. Nonetheless, a good helicoil job should be permanent, and might be better than new.
Quoted: 4806 Post(s)
Liked 3,928 Times
Liked 2,822 Times
based on pic in the other thread the bike is lower end diamondback, with square taper bottom bracket. It is would be amazing if it was anything other than standard 9/16 size pedals.
OP needs to
OP needs to
- replace cranks or
- get helicoil job done
- find a bike mechanics class to to take or watch in detail how to videos before touching another thing on the bike
- find a way to work with bike not upside down, can just hang from a pair of ropes. this will make all things easier
Quoted: 581 Post(s)
Liked 921 Times
It's likely that the threads on the pedal spindle are filled with leftover aluminum from the first damaged crank and this is preventing the threads from properly engaging with the crank threads. Use a file or needlenose pliers or the like to get all that crap out of the threads before you try to thread it in again.
Likes For ClydeClydeson:
Friendship is Magic
Bikes: old ones
Quoted: 26411 Post(s)
Liked 10,376 Times
...I like your username, but this is clearly user error.
Quoted: 581 Post(s)
Liked 921 Times
My go-to strategy when I don't have a proper bike stand is to hook the nose of the saddle over a tree branch or rafter or whatever overhead item I have handy. As long as the front wheel is on, the bike will be balanced with the front down and this will keep it from falling. You can also wrap some rope or other tying material around the seatpost and whatever the saddle is hanging on to further stabilize it.
Bikes: lots
Liked 2,932 Times
Back in the days of the TdG and the early years of ToC, and a lot of the other big races there would be a 'talker' in the Commissaire's car that told everyone in the team cars what was coming up over Radio Tour. Hour after hour of 'Virage a Droit' or 'Virage a Gauche'.
Liked 4,508 Times
If the pedals are Italian, you may get "D" for Destra and "S" for Sinistra. However, I believe they all have the 9/16 x 20tpi, even though other parts had bizarre thread combinations.
Likes For CliffordK:
Liked 2,924 Times
His bike's a Diamondback. I'd bet 5 dollars he doesn't have Italian or French pedals.
Quoted: 15 Post(s)
Liked 7 Times
pedals had no markings for left and right, replacement pedals don't either, so I guess i'll just right-thread the one on the right very carefully, and if i don't feel resistance, then I guess i did it correctly
Quoted: 15 Post(s)
Liked 7 Times
Vilano Tuono 2.0 Aluminum Road Bike 21 Speed Disc Brakes, 700c
Vilano
Link doesn''t work, they don't sell it anymore
