Renovating my 2003 Marin Eldridge Grade
Hi
I’m considering renovating my 2003 Marin Eldridge Grade. It’s been in storage for the last 7 years, and I feel like it deserves some tlc.
currently it has the standard 9x3 Deore system. So for a start, I’d like to convert it to a modern 11(?)x1, at a similar level to deore
would appreciate if someone here who has done something similar before could help me with the shopping list and process
thank you!!
thank you!!
Likes For avion22:
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
I did this to my similar vintage Santa Cruz Heckler
It had a Deore crankset So all I did was buy a narrow/wide Race Face chainring, And installed a new shifter, rear derailleur and cassette (and chain)
In my case I did 10 speed because I already had a 10 speed cassette laying around and used Shimano Zee shifter
and derailleur
But 11 speed is just as easy because it fits on the same cassette body
Not sure if Z is available anymore but then it was affordable downhill grade stuff which is the direction I was going with the heckler. But performance is on the line of Dioury or SLX
If it’s a 26 inch wheel bike you may not need the super low range of a 12 speed, but there are 12 speed cassettes out there that are compatible with your HG hub body also, Then you can run a SRAM GX derailer and shifter in, but if you went with a pie plate cassette you might bump the front ring up to 34 or 36 On a 26 inch bike
and derailleur
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
Hi
thank you!!
thank you!!
Likes For Schweinhund:
assuming that I stick to 11x1 :
which type and size of raceface chainring is recommended (for cross country)?
which type and size of a cassette is recommended?
will any model of 11 gears shifter and dreuiller would fit?
thanks a lot
Quoted: 882 Post(s)
Liked 821 Times
I think that Wolf Tooth (probably others too) makes a product that will allow your derailleur to accommodate 11 speed and a "pie plate" in the cassette. My friends with Trek Marlins are running Shimano 10 speed with a 10 - 46 rear cassette. You could operate that with a 32 tooth ring depending on how steep the hills are that you'll ride.
