47C tires on 650B wheels!
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Everything is explained here:
https://www.sheldonbrown.com/tire-sizing.html
Bike tire sizes are even more confusing than car tire sizes.
Likes For Lombard:
Quoted: 581 Post(s)
Liked 921 Times
ANyhoo, the claim that the C stands for 'crochet' seems to be apocryphal. There were 700C rims without hook beads (or 'crochets') for many years, and rims with a 584 BSD are called 650B - what does the "B" stands for? The 'bump' on the sidewall of the rim? How about the old city bike standard 650A? "A" for 'attach tire to rim'?
Quoted: 1109 Post(s)
Liked 1,200 Times
I recently got some Vittoria Terreno Dry tires. They are labeled both 700X35C AND 37-622. Haven't measured them yet.
I also have some of the same tires labeled both 700X38C and 40-622. They measure 39-40.
I know that width designations are somewhat inaccurate, but why two on the same tire?
It was explained to me as somehow relating to how rim widths used to estimate final actual width are trending wider. I get that. But that still makes no sense why the two width designations aren't the same.
Liked 1,200 Times
And remember, there's an (uncommon but not rare) 650A wheel size. Seen a lot on old TT bikes front wheels with 700C in back, and also get 5 small road bikes. Making the 650-47C error even more stupid
Mad bike riding scientist
Quoted: 6215 Post(s)
Liked 4,213 Times
An interesting tidbit:
Stuart Black
Stuart Black
Likes For cyccommute:
Sunshine
Quoted: 10954 Post(s)
Liked 7,482 Times
Its just a mess of numbers and confusion. I let it go because the tires roll so fast.
Quoted: 6191 Post(s)
Liked 4,806 Times
And yet... Continental sells hookless compatible tires that are labeled as 700x32c.
Grand Prix 5000 S TR (continental-tires.com)
Not even going to muddy this with 28" vs 27.5" discussion.
Quoted: 7649 Post(s)
Liked 3,469 Times
My 2007 Cannondale Rize has 650b rims and when I last shopped for tires ... I looked under "26-inch" and that is where I found the tires that are currently on the bike.
700cx32c .... I doubt the "c" means the same thing, or else it is just mis-labeled .... I know 700c is the road wheel standard and also the same inner diameter as 29" off-road tires .... so 32c? Maybe just a labeling error? But I bet every one of us figured a 32-mm road tire.
Par t of my point about communication I mentioned above .... I have read history synopses, looked at charts, and slogs through paragraphs of bloviating about the various tire-sizing standards ... and still somehow I have been unable to learn (why bother?) the actual dimensions, and yet have been able to buy, the right tires for all my bikes, including two sizes of supposed "26 -inch" tires which are different. I still have a bike with 27" wheels ... which, I guess are actually 30"? I never measured because, why bother? Somehow I always got the right tires.
Seriously .... if you were looking for 32-mm ties for your road bike and saw tires marked "700cx32c" would you assume they were or were not approximately the size you wantde?
Quoted: 1456 Post(s)
Liked 1,477 Times
Yes, and if you'd scrolled down a little you'd get the idea that Continental is saying that it's okay to use this tire on either hookless or hooked rims. The caveat being that if the rim is hookless you have to use 5 bar or 73 PSI for all the sizes of this tire as max. Whereas some sizes have a much higher max psi if mounted on a hooked rim.
So, do both "B" and "C" stand for "Crochet"? Or is Continental just using "B" and "C" to describe 650 and 700?
The explanation that C = "Crochet" makes zero sense. I think even Continental isn't sure.
Likes For msu2001la:
Quoted: 581 Post(s)
Liked 921 Times
650A is another name for one of the 26x1-3/8 sizes used on city bikes and 3-speeds. 650 A has a BSD of 590mm.
Likes For ClydeClydeson:
Liked 4,806 Times
Just for the other naysayers....
https://en.wikipedia.org/wiki/ISO_57...h%20ISO%205775.
While not in the verbiage in the tire section, the chart clearly shows widths with a C after them in the crochet column. None in the column for straight sided rims. This is from wikipedia and is based on ISO 5775 which covers standards for tires. However even ISO 5775 is out of date for tires today as it doesn't address the abilities of newer tire construction. And ISO 5775 is voluntary and not mandatory.
Scroll down toward the section on rim sizing and you get these references....
Also there is a reference by Schwalbe that suggests as many contend that the C after the width is old french sizing. And maybe it is... for Schwalbe tires. But not necessarily all tire manufacturer's. However I tend to think that it's a mistake by the document writer that didn't do their due diligence as they don't cover the other markings that are sometimes seen. But y'all can find that reference yourself.
https://www.skeppshult.se/media/1140...fo-2015_gb.pdf
Liked 4,806 Times
I scrolled down. They sell a "B" version of this tire that is also ok to use on either hookless or hooked rims.
And do tire manufacturer's even ascribe by that standard or do they just do their own thing? It is a voluntary standard after all so they can make the markings mean whatever they want if they don't tout them as ISO 5775.
Liked 3,469 Times
I have to wonder if "crochet" isn't just a bad translation that no one bothered to repair?
Old fart
Quoted: 3587 Post(s)
Liked 3,398 Times
Likes For JohnDThompson:
Liked 1,477 Times
I've also never seen that "C" in a tire size would designate a tire for use on a hooked rim. Maybe this is because we assume all tires can be used on hooked rims? There are many hookless compatible tires (that could also be used on hooked rims) that are sold as "C" sized. Here's another example:
P Zero™ Race TLR | Pirelli Cycling
Perelli uses the ETRTO size standard 30-622, but they market this tire as 700x30c. It doesn't require a "crochet" rim though - it's hookless compatible, so why the c?
Quoted: 581 Post(s)
Liked 921 Times
Iride01 's confusion seems to be that the chart he listed is the standard for RIM construction, not for labelling tires. When discussing tires, the C (or B or A, or even D) describes which rim diameter from the various sizes called '700' or '650'. On tires, as OP was initially asking about, it most certainly does not refer to crochet bead rims. Even Iride01's own sources are all specifically talking about rims, and not tires.
Liked 1,477 Times
They're also likely, during the course of the transaction, to confirm your wheel size using more common language like 650b, 700c, 26" etc.
Liked 1,477 Times
Confusingly they also include a chart that shows 700 x 38B as 40-635, and 650 x 38B as 40-584, so clearly B does not stand for either 635 or 584.
It's also worth pointing out that if "C" really means 700c diameter, then why does anyone designate any tires as 700? Why not just sell them as 28c or 32c? Everyone would know that a 28c or 32C is a 700 size, right?
Liked 3,469 Times
"We have always done it this way .... "
Liked 4,213 Times
Yup. I had too look it up.
Stuart Black
Stuart Black
Likes For Lombard:
Quoted: 581 Post(s)
Liked 921 Times
I feel the need to point out that Wikipedia isn't a source. The Shwalbe technical doc, and Sheldon Brown are the sources. The Schawlbe tech doc tries to explain that the "C" is a French size designation. The letter at the end indicates the inner diameter of the tire. In this case, C stands for 622 mm.
Simply saying '700 x <width>' in any bike shop will get you a 700c/622mm tire.
Liked 4,213 Times
The whole system is archaic and should be abandoned but, again, “TRADITION!”
Actually, there are other C sizes, although mostly uncommon now. As late as the mid 00s, TT and tri bikes commonly had 650C wheels, especially in front where the smaller diameter was an aerodynamic benefit.
Stuart Black
Stuart Black
Old fart
Liked 3,398 Times
