Suntour Roller Cam Brakes
Quoted: 482 Post(s)
Liked 744 Times
Are these things a solution looking for a problem or under appreciated engineering?
Quoted: 800 Post(s)
Liked 2,060 Times
Yes.
All kidding aside, I had a set on a long-departed early mountain bike. They were fine stoppers and tended to be a bit fussy to set up and adjust, not unlike MAFAC Racers. Not game changers but I wouldn't kick 'em to the curb.
Likes For ascherer:
Quoted: 3930 Post(s)
Liked 4,876 Times
Quoted: 482 Post(s)
Liked 744 Times
Good feedback, thanks gents. I’m always looking for unusual bits and I was thinking these might be a good choice for my early mountain bike even though cantis work fine.
Quoted: 1088 Post(s)
Liked 2,005 Times
The pivot mounts aren't in the same place as cantis (they're above the rim), so you can't swap between the two. Roller Cams collect mud a lot easier than cantis. Cantis are easier to disconnect so you can remove the wheel.
Likes For Clang:
Quoted: 482 Post(s)
Liked 744 Times
Ahh, good to know about the mounts. The market for roller cams must have been rather small? There is a Schwinn-something MTB frame for sale locally that has roller cams which is why I became curious.
Bikes: Davidson ’81
Quoted: 120 Post(s)
Liked 222 Times
I have them on an ‘87 High Sierra.
Power and modulation are spectacular. My High Sierra sees baby seat, trailer and grocery duty (sometimes all at once) and they are very confidence inspiring.
They can go out of adjustment but it’s an easy fix. I don’t think they are as hard to set up as common wisdom suggests.
IMO their only real downside is that the cam for the front brake is in the way of the fork crown hole which prevents mounting some racks.
Bikes: N+1
Quoted: 163 Post(s)
Liked 424 Times
When set up properly they worked well except for mud collection -- exacerbated by under chain stay placement. They were an under-appreciated evolutionary dead end on the path of braking evolution.
Likes For JulesCW:
Quoted: 203 Post(s)
Liked 260 Times
Rollercams on 1985 Cannondale SM600
I vote: "under-appreciated engineering", they Rule!
(Along with Pedersen Self Energized brakes on front with Odyssey Straddle Rods instead of cable).
Likes For Bianchi84:
Quoted: 203 Post(s)
Liked 260 Times
oops... just saw previous post with same information.
Quoted: 2153 Post(s)
Liked 1,350 Times
Extraordinary Magnitude
Quoted: 2503 Post(s)
Liked 1,396 Times
I'm not a fan of the roller cam brakes. Yeah, they were licensed/manufactured by Suntour, and I'm a total Suntour homer- and I love nifty little oddball bits- but I don't like them. I don't seem to have problems adjusting any brakes that I've had- except the roller cams. They're cool, and unique looking... maybe even over-imposing than a brake needs to be... but I just don't like 'em.
As has been mentioned- the bosses are at a different height than cantis- however, U-brakes share the same boss location. HOWEVER... your choices for the model of roller cam brake is pretty narrow and the choices for quality U-brakes are even smaller.
If you've got cantis, there's a whole world of nifty and cool looking canti brakes that all work well. I tend to like the "medium profile" triangle guys- with the arms out level. Generally.
Here's a thread to start you off:
Grail Brakes by Dave The Golden Boy, on Flickr
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
Quoted: 482 Post(s)
Liked 744 Times
madpogue Indeed it was a High Sierra frame that I saw them on.
Obviously a lot of thought went into the design so the fine people at Suntour must have had good results during testing.
Liked 1,396 Times
Here's my 87 High Sierra:
feros ferio
Quoted: 1270 Post(s)
Liked 986 Times
My KOM-10 can take only RollerCams or U-brakes, and I got it with a RollerCam in front and an under chainstay U-brake in back. I have absolutely no complaints whatsoever about braking force or modulation. I use 4-finger motorcycle-style Shimano brake levers, KoolStop pads (accept no substitutes), and modern low-compression, low-friction cable housings.
My sole (minor) gripe is that I have to deflate the front tire to remove or replace the wheel. I don't have this problem with the U-brake in back.
Quoted: 550 Post(s)
Liked 1,015 Times
While we're on the subject is there anything I can do to line mine up better? I tore them completely apart to clean them and they work great but they're a little cockeyed.
BEFORE
AFTER
BEFORE
AFTER
I remember setting up a few of them and thought that they were very good.As some have said a bit finicky to set up correctly.
Wasn't this a WTB design that was bought by Suntour? I am thinking that Wilderness Trail Bikes had a rollercam before Suntour. Neither lasted long but they were robust good stopping brakes although wont go on canti studs if I recall
Likes For obrentharris:
Liked 1,350 Times
Does anyone know when this version (vis-a-vis the version on the Schwinn below) was out? And/or, what bikes it was typically found on? It definitely has the upper hand in the "looks like beautiful old bridge architecture" department. Not sure how the spring adjustment/balance works with this version.
Smoke that chrome! Looks like a clone of mine (confession - I have two....).
Even after releasing the cam? Never had that experience myself, even with 26x2s. Sometimes one of the arms swings all the way open as I remove the wheel; it's never thrown it out of adjustment, however.
Quoted: 203 Post(s)
Liked 260 Times
feros ferio
Liked 986 Times
The cam pops right out if I squeeze the pads against the rim by hand. The problem is that the tops of the swing arms bump into each other, limiting how far I can spread the pads apart. The quickest solution sometimes is to loosen one of the pads and swing it out of the way -- faster than deflating and re-inflating the tire.
feros ferio
Liked 986 Times
My KOM-10 -- or at least its fork -- is an outlier, because all of the others I have seen take a standard cantilever brake, rather than a RollerCam or U-brake, in front. That is also what the sales brochure cites in the spec. table.
Quoted: 203 Post(s)
Liked 260 Times
the cam seems to have a weird curve, maybe to change pad movement as it is pulled up.
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 175 Post(s)
Liked 172 Times
Is yours an 87? I have an 88 KOM same colors and yes it has cantilevers in front u brake in rear. Great bike.
Last new bike 1991
Last new bike 1991
