Stronglight BB Confusion
Confused on whether this is right or left threaded. On a 1977 PX10LE, so thinking it's french threaded. But it won't budge. Going to return the 38mm wrench I bought, this is something like 37.5. Going to try the Sheldon method next but want to be sure I'm turning it the correct direction.
Normally I would just leave it and use as is, but already bought a french threaded sealed bb with longer spindle for a triple crank. Maybe I should forget it or look for a longer spindle.
The fixed cup has three circles in it. These indicate something but I haven't been able to find the info.
Quoted: 898 Post(s)
Liked 995 Times
If you have a good spanner and it's held on with a bolt and a pair of stout washers, just try harder alternating each direction until it shifts. When it does, if it shifts easier, keep going. If it shifts and gets tighter, go the other way.
Likes For oneclick:
Quoted: 3306 Post(s)
Liked 2,281 Times
the cup which is in there exhibits the Stronglight code for BSC/"English"
would expect a 1977 to have a metric/"French" threaded shell
possible someone may have forced that cup in there or rethreaded the shell
Stronglight fixed cup thread codes/markings:
BSC: two rings and eight flats
metric: one ring and eight flats
Italian: one ring and eight flats or one ring and two flats
CH; no rings and eight flats
"nothing can stop you now cause you are the __________"
Likes For juvela:
Ride, Wrench, Swap, Race
Quoted: 1433 Post(s)
Liked 1,058 Times
A 12-point socket in the 1-1/2" size will grip four the octagonal 38mm cup flats solidly, allowing massive torque to be applied in a controlled fashion.
I find such large sockets at thrift stores and pawn shops who inventory boxes of tools and sockets. New ones aren't that expensive either.
Note that I also tried the 1-7/16" size socket but it was far too small to go in the Stronglight cup.
A 12-point 38mm socket is harder to find but is perfect.
Not typically necessary, but it might be good to "square" the end of the socket (using a belt sander, file or grinder) if the there is a deep bevel at the socket's opening.
Some slightly newer Stronglight cups apparently have only 36mm across-flats dimension, but yours looks like the older 38mm across flats.
Liked 2,281 Times
yes, if it is BSC it would unthread clockwise
when you get it out you can make some measurements of both the fixed and the adjustable side
find it puzzling...
find it puzzling...
Likes For Sierra:
I'm starting to think it's better not to mess with this bb and leave the cup in place. It's likely english based on those circles, which means someone may have forced it in a french threaded bb.
So I either track down a longer spindle that would work for a triple crank or just keep it double. Maybe I'll just have to find another french frame to use this bottom bracket and triple crank on. And I thought I was done with french frames!
Liked 2,281 Times
a) something is clearly not right there. as things sit cup might work loose with use or it may not be properly aligned if for example it were cross threaded.
b) removal will permit examination and measurement
c) if threads have been damaged one solution would be to ream and tap to Italian
d) Stronglight did not offer spindles for 70mm shells so they made the walls of their Italian dimension bottom bracket cups one mm thicker than others
e) in order to preserve the OEM chainline you would want to place a 1.0mm spacer behind the Italian dimension fixed cup prior to mounting
Likes For juvela:
Quoted: 3934 Post(s)
Liked 4,890 Times
Here's my method that has never failed, including a PX-10 awhile back that was the same as here, BSA DS cup forced in, got it out, restored the threads and put a correct Stronglight cup in FTW.
This setup often employs a 2 or 4ft cheater, again, it has never failed and like commented above it can crack it loose both ways, once it does you just make sure you're going the right way and carry on.
And yes the wrench is going the wrong way in the pic.
Nice rig merziac !!! Is there a model number for that wrench that fits these french 37.5mm bb's?
I never would have noticed anything wrong with the bb or even thought of replacing it if I hadn't gotten the idea to install a triple crank, which then led me to get a sealed bb with longer spindle. I probably would have just left the fixed cup in, cleaned and regreased. I'm building up two pugs right now and back to figuring out what goes where. I feel like I've thought about these bikes way too much!
Likes For dukeofearl:
Liked 4,890 Times
A big factor is holding the frame or bracing it against the ground securely so it stays put while you get after it and apply force straight on at right angle without any twisting.
My plan was to use the sealed bb with longer spindle, with this stronglight 99 crankset. However, I did just come in possession of this shimano/takagi triple crank, with this spindle (next to the og ta spindle). I'm guessing that I could not use this spindle/crank with the stronglight bb because of the different length of the center section? Wondering if there's some leeway with this type of bb.
I'm planning now on putting this on an 81 super competition (stronglight swiss bb) that had no original components, will be suntour cyclones, superbe brakes...
Quoted: 1474 Post(s)
Liked 1,872 Times
Back in about 2010, I wanted to remove a fixed cup on my crashed Le Champion.
Tried a number of approaches most listed above.
I added another step, heat. Not on the shell but on the Sheldon brown fastener so the heat propagate from the center out through the cup. That did the trick. No paint was damaged event though the frame was bent up.
Quoted: 147 Post(s)
Liked 120 Times
If you're not sure whether it's a LH or RH thread - can you see the end of the thread in the bracket shell on that side? Otherwise turn it alternately in each direction with increasing force until something happens.
When all else fails, weld a chunk of steel onto the cup, hold it in a vice - the combination of heat and leverage will usually shift even the stubbornest cup.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2042 Post(s)
Liked 3,554 Times
My suggestion would be to use the original spindle with a compact double. That Stronglight 99 or other 86 BDC crankset would work well to make a 48/30 combo or similar.
Here's one I put together for mrs non-fixie. 49/32, I believe. She loves it, and finds it much easier to use than a triple, especially since she prefers friction shifters these days:
I don't think that will work. Unless you can find a substantially thicker/longer NDS cup, it will likely disappear in the shell, and not leave enough threads for the lockring.
Is the cup in reasonable condition? I've seen a cup that partly cracked through under the balls, and the broken edges were digging into the BB shell making it hard to turn.
Liked 1,058 Times
Usually though, their shorter flats induce common tools to "cam" past the flat's corners, only two of which are engaged.
I had entertained the thought of making a box-end, 38mm octagonal wrench out of flat stock, but then had the idea to first try finding a 12-point socket in the right size (which could engage four flats). As luck would have it, a more-common 1-1/2" socket near-duplicated the 38mm size needed.
As it turned out, by taking advantage of my breaker bar's pivoting end, the pushing force on the handle could be made to fall in the plane of the cup's flange, discouraging the socket from to tilting off of the cup and then slipping.
In practice, I immediately was able to apply great torque, without even much pushing inward on the cup.
I am recalling that the socket that I bought (used) already had some squaring done to it's open end, which is important when trying to engage the thin edges of the cup flange.
I got sidetracked with another bike but am back to this one. Now that I've cleaned up the bb, looks like there's some problematic pitting so I'm going to try to get this thing off again.
I plan to buy a 12-point 38mm socket and give it another go. Or might be best to just take it to a bike shop but the one near me couldn't even properly change a tire so don't trust them with something like this. Anyone have a recommendation for a good shop in the Philly area?
And then there's the question of what to replace it with. If this is english threaded, shimano or velo orange sealed bb? And the length - I had purchased a 125mm stronglight spindle for the triple crank, but if I understand correctly, I may need a longer one of the modern design because they're even on both sides?
feros ferio
Quoted: 1272 Post(s)
Liked 989 Times
By 1977, Motobecane switched to Swiss threading, but I think Peugeot was still French-threaded at that point.
I was surprised and gratified to discover that my 1980 Peugeot PKN-10 was Swiss-threaded, meaning that Peugeot eventually got it right (or should I say, "left"?).
Yeah theoretically a 77 Peugeot should be French threaded but seems like it’s English based on the three rings. Kind of a mystery until I can get it off and know for sure.
Old fart
Quoted: 3312 Post(s)
Liked 2,793 Times
But was that a Stronglight octagonal cup? Those measure 38mm across the flats, while Campagnolo/Shimano/Sugino two-flat cups are only 36mm across the flats, so a Sugino fixed cup tool is unlikely to fit the octagonal cup.
Quoted: 3448 Post(s)
Liked 5,371 Times
My approach many years back was to file an extra couple of mm from a Sugino fixed-cup tool, making it a dedicated Stronglight fixed-cup tool (I bought a replacement to work on Sugino/Campy etc.).
