Suntour Superbe brake stuck
Old 11-11-22, 09:49 AM
dukeofearl
Quoted: 61 Post(s)
Liked 82 Times in 39 Posts
rear brake is gummed up. i tried pb blaster, wd40, triflow. not budging. it's the one on the left, stays shut if you squeeze it. see how the spring is doing something strange.
i was going to dissemble the whole thing, clean and see if that helps. unless someone has a better idea?
idiot check: to dissassemble, would i unscrew those two front bolts in the second pic?
dukeofearl is offline
Old 11-11-22, 09:53 AM
Kabuki12
Quoted: 663 Post(s)
Liked 1,573 Times in 910 Posts
Yes , at this point disassembly would be your best bet. You may find that after loosening the front nuts that it moves freely. I would still take it apart and clean/ reassemble. I have not put any lube in my brakes when I put them back together , just don't over tighten the first nut prior to locking in the second(front) nut. They should modulate freely if assembled correctly.
Kabuki12 is offline
Likes For Kabuki12:
Old 11-11-22, 12:32 PM
SurferRosa
señor miembro
SurferRosa's Avatar
Quoted: 3174 Post(s)
Liked 4,756 Times in 2,473 Posts
Originally Posted by dukeofearl
The use of the zip tie in this fashion for too long seems to be asking for trouble.
SurferRosa is offline
Old 11-11-22, 12:39 PM
SurferRosa
señor miembro
SurferRosa's Avatar
to dissassemble, would i unscrew those two front bolts?
The conical nut and the flat nut right behind it lock together after the caliper is perfectly adjusted. To do this, you use two wrenches at the same time, one on each nut. You can often use a cone wrench on that flat locknut and a socket driver on the conical nut. Park also makes a tool to do this and also to adjust the brakes:
Park Tool "4-in-one" obw-4 for $10.95 shipped on eBay
Old 11-11-22, 12:45 PM
dukeofearl
Quoted: 61 Post(s)
just did it for a minute to show what's going on
thanks, i was planning on buying some cone wrenches anyways, so hopefully they'll do the trick
Old 11-12-22, 06:54 AM
Bianchigirll
Bianchi Goddess
Bianchigirll's Avatar
Quoted: 2757 Post(s)
Liked 2,358 Times in 1,279 Posts
Quick thread hijack! Does anyone know a source for those super thin brass washers usually found in single pivot brakes?
Sugar "Kane" Kowalczyk
Bianchigirll is offline
Old 11-12-22, 07:15 AM
Schweinhund
Captain Dorkdisk
Bikes: More than I need, less than I want.
Quoted: 358 Post(s)
Liked 546 Times in 290 Posts
I believe you're looking for a shim washer in brass. These guys have a bunch if you know your size:
https://www.bokers.com/washers/custo...s/brass-shims/
Schweinhund is offline
Likes For Schweinhund:
Old 11-12-22, 07:28 AM
dukeofearl
Quoted: 61 Post(s)
Turned out to be pretty easy to take these apart. One of the springs was bent so just bent it back. Cheers
Likes For dukeofearl:
