Simplex Dropout Screws
I bought some velo orange drop out screws for my 1977 px10le, but the hole is too large. And then i realized these holes aren't even threaded. I was putting the wheel all the way back previously (large tires). Should I tap these and get a larger screw? If so, what size? Or just use those peugeot dropout little spacer thingies? There must have been some on there a long time ago. I probably have some around here somewhere. Wondering why they made that hole in the first place.
Quoted: 897 Post(s)
Liked 990 Times
There are wee little plastic (it's Simplex) bits that fit in the holes and have a threaded cross-hole for the adjuster.
Except for you there aren't.
Don't drill or tap anything, that area is fragile enough as it is.
Likes For oneclick:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 812 Post(s)
Liked 437 Times
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
saddle angle optimizer
the inserts are plastic of some sort. the screws are 3 x .5 x 30. the cap nuts are hexagonal.
the plastic inserts fit in the holes, the screws thread through them snugly, almost as if the screws were "self tapping" in them (even though the screws are not self tapping type). you can see the slight plastic deformation around the threads in the pics below.
there are no tension springs, all of the screw position retention relies on the tight fit of the screw in the plastic insert. if the threads in the plastic were to strip out, the inserts would be useless and there would be no screw adjustment.
while i haven't tried it, i don't think it should be too difficult to manufacture a similar insert.
i would not tap the dropout for a larger screw.
originals from my Super Competition.
Likes For hazetguy:
Friendship is Magic
Bikes: old ones
Quoted: 24796 Post(s)
Liked 8,582 Times
...if it were me, I would use the little dropout spacer thingies. I have some in a parts drawer that I saved.
Likes For 3alarmer:
Old fart
Quoted: 3304 Post(s)
Liked 2,786 Times
The hole is 5mm diameter. If you can source a 5mm plastic rod, you could drill a 2.5mm hole across the rod, tap 3 x 0.5mm thread in the hole, and slice it off to fit the hole.
Likes For JohnDThompson:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4423 Post(s)
Liked 4,776 Times
My solution is to use an M3 screw and two M3 nylok nuts, and sandwich them in for those that can't find the standard part.
Quoted: 163 Post(s)
Liked 376 Times
This situation would warrant at least an email to Wayne Bingham at Mel Pinto Imports. I never cease to be amazed at the old French small parts that he still has on hand….
Quoted: 1491 Post(s)
Liked 629 Times
Those little plastic pucks were most likely made from Delrin.....Simplex was literally addicted to this wonder plastic of that time.....It actually worked very well for retaining those adjustment screws.
