Catapulting Disc Brakes
#101
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,528 Times
I'm not knocking coaster brakes, I've got them on one of my bikes. Great for casual rides.
But I really like disc brakes when riding in rain, snow, slush, mud, gravel, .... The disc brakes make it easier to control the bike when rim brakes can struggle. And this makes disc brakes less "pro jock" and safer for the average dork on a bike in non-sunny conditions.
I really don't like the idea of braking the front wheel on a slippery surface, especially in a turn.
I am sure disc brakes are good but I wouldn't want one on the front wheel.
#103
Clark W. Griswold
Quoted: 4330 Post(s)
Liked 3,955 Times
Likes For veganbikes:
#104
Some Weirdo
Bikes: '86 Schwinn Prelude, '91 Scott Sawtooth, '73 Raleigh "Grand 3"
Quoted: 223 Post(s)
Liked 141 Times
Another problem (at least for non "pro jocks) is that controlled modulation and/or proper sequencing of front/rear brake application, as well as other enthusiast recommended techniques sometimes suggested on BF like shifting body weight to the rear prior to application of front brakes is easier said (or performed in practice drills in an empty parking lot) than done suddenly in traffic during an unplanned emergency/panic braking situation.
#106
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3862 Post(s)
Liked 6,450 Times
The standard bearer had been with us since Agincourt. He carried the gift of tongues and in the whisper of a holy ghost wished me caution. Their deaths are small reminders that faith & absolution are short lived. Alas, I am now a knight without sword or shield... Learnath my lesson friends, know how to stop and how to slow and never risk a catapult's blow.
Ecclesiastes 13:1 Learn to slide, skid upon thy rear, and thou shall inherit the kingdom of heaven.
God be praised!
Likes For SurferRosa:
#107
Quoted: 4242 Post(s)
Liked 1,343 Times
Perhaps sales of bicycles with brakes that require lessons from pros like Greg Lemond to be used safely should be limited to "pro jocks."
Selling bicycles as safe, normal and ready for general use by the public that in fact may require special techniques and training to be used safely sounds like a page out of the Corvair chapter of Unsafe at Any Speed by Ralph Nadar.
The vague "general public" typically aren't going that fast ("emergency" braking is kind of moot for them). People often have very little idea of how to use the gears on the bicycles they buy. Some of them will avoid using the front brake due to concerns about "catapulting" and have little idea that it's the front brake that is really what is stopping the bike.
So, the notion that some of them wouldn't benefit from work on understanding and technique is bizarre. (There are certainly some who ride infrequently or slowly that it doesn't really matter.)
It's not that hard or time consuming to practice braking some.
Likes For njkayaker:
#108
I really like a rear coaster brake especially when riding in rain, snow, slush; I don't ride gravel or mud. Always reliable, no adjustment or maintenance required, ever.
All of that means that there's no sudden change in braking force as the wheel rotates. What throws people over the bars is when the brakes suddenly grab. Variation in braking force is a bad thing, always, and rim brakes are much more prone to that variation.
Also, sizing of the brake disc is a good way to change the braking forces. With a standard 160mm disc, it takes a very firm grip to go OTB.
Likes For gsa103:
#109
Dovetailing this thread with the "Are there any decent Walmart bikes?" thread: Some cheap bikes have a disk brake in front and rim brakes in the rear.
Just imagine the consternation those might cause the OP!
#110
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,850 Times
I keep seeing recommendations on how much force to use on front or rear, but what I'm not seeing is the simplest way to do that - 2 fingers on the front lever, 1 finger on the rear.
#111
Liked 11,850 Times
Like how disc front, drum rear was standard on a lot of cars for a long time.
#112
Likes For Reflector Guy:
#113
Quoted: 3942 Post(s)
Liked 7,279 Times
Likes For tomato coupe:
#114
Liked 11,850 Times
By doing one of those slight nods that leaves the recipient wondering whether I actually nodded at them, and thus unsure whether they should respond, of course.
Likes For genejockey:
#115
Liked 11,850 Times
Right. Keeps me from locking up the rear without having to think about how much pressure I'm applying to each lever.
#116
Quoted: 365 Post(s)
Liked 418 Times
I've been riding for over 30 years and have yet to try out the relatively new Disc Brakes. In the early years I catapulted over the handlebars on at least two occasions and nearly catapulted at least two other times, before it became instinct for me to squeeze the rear brake first.
I'm curious how easy is it to catapult using front disc brakes (compared to traditional brakes)? I'm wondering if my current methodical use of traditional brakes, where I brake first with rear brakes, then employ the front brakes would smoothly cross over to use of disc brakes.
(I guess this question is best for riders that rode many years with traditional brakes, that recently have transitioned over to discs). .
I agree that it sounds like your concern that using disk brakes could make it easier to "catapult" yourself over the bars (OTB) if you grab too much brake is a valid one. I would suggest that you break the habit of grabbing too much brake before you switch to disk brakes because, as you say, all things being equal disk brakes stop the wheel more quickly with less effort in most conditions. If you're used to applying a certain amount of pressure during hard braking using a caliper brake (just an example) and then apply the same pressure on a disk brake during hard braking your risk of going OTB would increase. As to "how easy is it to go OTB using disk brakes?", that is not answerable, as it is impossible for me or anyone else to know what "easy" and "hard" mean to you. Easier than with calipers/cantis/v-brakes, that's all I can say.
The only way to break a bad habit, AFAIK, is to practice good habits so that they supplant the bad habits. Since you've been riding for 30 years this may take some time. Maybe practice hard stops at stop signs and lights during a ride (when safe, obviously)? Practice sessions where you work exclusively on hard braking would help with technique, but it sounds like you already know the technique, you just have trouble applying it in an emergency, so from what you're saying it would seem that this wouldn't help you as much as practicing in the "real world". Not that an occasional session working specifically on hard braking would hurt, maybe throw in a couple if you haven't done any hard braking in an while just as a refresher. Of course, once you have ingrained good braking habits and you've switched to disk brakes, you WILL be doing specific hard braking drills until you learn how much pressure to apply to the lever in an emergency.
I'm puzzled as to why you apply the back brake first in a panic stop situation. Yes, the back brake will slow you down with no risk of going OTB, and with less risk of washing out a wheel and going down if the wheel locks. But in a situation where the back brake is not enough to slow you down sufficiently, applying the back brake first just wastes time that you could use towards getting your body into the proper position and applying (and modulating) the front brake. This makes it more likely that either (a) you'll have to brake even harder, increasing the risk of going OTB, or (b) you'll run out of time/distance and hit what you were trying to avoid. On dry pavement, I don't know why you would apply the rear first in a panic stop situation. If you're on a low-friction surface (wet, gravel, snow), then sure, it is best to use the back brake first and then apply the front judiciously, but that's to avoid washing out the front wheel, it has nothing to do with going OTB.
Hope I've helped.
Likes For noimagination:
#117
Liked 11,850 Times
Thank you, oh wise one, for yet another pearl of your own personal opinion, stated as if it were immutable law.
#118
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
#119
Bikes: lots
Liked 2,932 Times
Well, you, and the other poor guy can start out by making sure that you're using quality brakes.
After that, you can spend as much time as you need shedding yourself of the need to rely on two fingers on the brakes.
If countless newbie high school kids can learn to successfully brake with only one finger, I have great hope for both of you guys!
#120
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2562 Post(s)
Liked 5,594 Times
There is no rule people have to be nice, but going out of their way to be rude is so unnecessary. It’s bad enough we have to listen to it in politics that we have to see it here. Please be kind.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
#121
Liked 11,850 Times
That was exactly my thinking. Hence the sarcastic reply.
#122
Liked 11,850 Times
And a quick review of videos of pros indicates they apparently have much to learn from this guy, since so many of them use two fingers. Indeed, I saw some using 2 for the front and 1 for the back, as I do. Pity we're all so inexperienced, eh?
#123
It's purely by dumb blind luck we haven't all snapped our necks in crashes by now!
#124
Liked 1,343 Times
Whatever people say in a forum, they aren't not letting you do anything.
#125
Quoted: 338 Post(s)
Liked 408 Times
Quite honestly, it has never occurred to me to count the number of fingers I have on the brakes, but to the best of my recollection, it varies between one and four. I never realized it was something to even think about. Seriously, as long as you don't grab a fistful of brake and then *squeeze*, I don't see how road discs could catapult you. There's no honed over the years superhuman amount of fine motor control required... or else I couldn't do it, heh.
They simply work well. For what it's worth, I don't personally know anyone who switched back, although I do live in a rather hilly area with occasional steep descents which does make them attractive.
