Do consumer grade Walmart bikes need disc brakes?
Liked 2,969 Times
Quoted: 4227 Post(s)
Liked 2,488 Times
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
I suspect that just like suspension frames and forks, disk brakes will eventually find their way into department store level bikes. And just like department store level suspension parts, they'll likely be junk, more for appearance than for performance.
Likes For JohnDThompson:
Quoted: 18414 Post(s)
Liked 15,539 Times
Liked 2,969 Times
flash chromed plastic calipers & elmers school glue used as resin in pads?
-Oh Hey!
-Oh Hey!
Liked 2,488 Times
Likes For wolfchild:
Liked 2,969 Times
Randomhead
Liked 3,696 Times
I hope their disc brakes aren't as bad as their suspensions. If they do end up having hydraulic discs on a $200 mountain bike, I imagine the lawyers will be called in fairly quickly due to them not working.
Quoted: 1561 Post(s)
Liked 1,734 Times
Rim brakes work fine..... as long as you keep your rims trued. Which bikes are least likely to have properly trued rims? Walmart bikes. so it makes perfect sense to equip these with disc brakes. Also a mechanical disk brake is not all that complicated.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Tragically Ignorant
Liked 9,098 Times
I have to disagree with you on that one....A $ 2000 bike is not even close to being elite or very high end.....$2000 today gets you a mid - level bike that is of good quality but far from being high-end or elite....Bikes which cost around $2000 are probably the most common types of bikes sold out there.
There's no way that last sentence is remotely true. 80% of bikes sold in the U.S. are big box store bikes.
Likes For livedarklions:
Well, since you brought it up I will hate you for it.
Tragically Ignorant
Liked 9,098 Times
Quoted: 3951 Post(s)
Liked 7,296 Times
Likes For tomato coupe:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
The problem isn’t with wealth. The problem goes much, much deeper. The objects that are on HelMart bikes that resemble disc brakes are only that...objects. They don’t actually function as brakes. But that problem is endemic of all the bikes and the components offered by HelMart. The bikes are reasonably safe since they can’t go so there is no need for stopping.
Stuart Black
Stuart Black
Quoted: 346 Post(s)
Liked 398 Times
Disc Brakes were available on several models of otherwise ordinary bicycles in the early Seventies.
Some of the Schwinn kids bikes in the stingray like style had them.
Heck, even JC Penney's marketed a line of 10 speeds with disc brakes!
Yes, absolutely, the disc brakes provided much better stopping power than what any other bicycle without them no matter the cost/prestige marque!!
Yes, that is true!
They added a heck of lot of weight, relatively speaking to lightweight bicycles that were striving to become lightweight for the consumers that wanted to reduce weight in grams in any way possible.
The other issue with respect to disc brakes at that time was that the replacement parts channel was limited to maybe the Schwinn store for their bikes with them, or somebody in timbuk2. Many folks already knew how to service and adjust the ordinary caliper brakes, and pads and cables, etc were easily sourced and widely available. It was very simple.
Folks ridiculed those 10 speeds in the 1970's that were disc brake equipped. Added weight was the main factor but also added complexity and unfamiliarity with issues when said disc brakes were not properly adjusted.
Disc brakes aren't a new concept. They improved braking significantly in the 1970's but were not widely adopted as everybody wanted lightweight everything. Today, relative to the 1970's, bicycles are much lighter across the road-bike spectrum so there isn't much an issue with weight today.
I am sure that todays disc brakes are lighter in weight and more refined but the fact remains that the early disc brakes of the seventies did a damn good job of stopping.
Were they needed then or today? Look at it this way, if you're hauling azz, you've got to anticipate your stops when on a bicycle or a motorcycle.......as it is not the same as being seatbelted inside a car which has four wheels on the ground............you can only remain under control at certain limits while extreme braking on a motorcycle or a bicycle.....
You brake too fast and too hard, and the human rider (YOU) will possibly become a soaring projectile, much like a football that has been kicked on a field goal try.
As was mentioned by someone previously, many features are marketed as the most essential, greatest thing since sliced bread. Certainly in some instances for certain bicycle useage, disc brakes might be more beneficial but largely there is probably not a material difference in stopping while cruising along at 11mph or 13mph on a flat bike path, or park paved roadway that is smooth and mostly without hills. This of course assumes that the ordinary brakes are in good order with acceptable condition pads and properly adjusted brake cables.
Any merchant such as Wallyworld or the world's better bike manufacturers would consider anything if it were both cost effective and could hype and booster unit sales. This isn't limited to just the low cost box store econo bikes, as you see oddball gimmicks from time to time at nearly every level. Yes, the better more prestigeous makers are definitely a bit more careful with crazy oddball gimmicks because if the public opinion turns more negative, they have more to lose because they have a prestigeous established reputation of quality that can be seriously tarnished while the low priced, box store bicycles won't lose such respectability across the board. (because they don't have any that they could lose!) People view the box store offerings on a singular case by case, individual bicycle model basis. They largely assume that said Wally bikes are at best, decent for the money and on average a crapshoot where some are awful and some are borderline decent if properly assembled which rarely happens at your Target/Dicks/Wallyworld etc.
If any Wallyworld bike gets decent reviews and amasses large sales over a period of months and years, that bike becomes sort of famous among the inexpensive bicycle offerings of the world. Walmart does have a few of these, which help to bring back bicycle shoppers year after year despite that a few other models that they also carry aren't so great. Not everyone needs an expensive bicycle. Some of Walmart's offerings are perfect basic bicycles at the perfect pricepoint for just how the buyer plans to ride them. Who cares if they weigh 30 pounds or if they are available in only two sizes, one for men and one for women..........or if in some models that they come in just one size, IF THE RIDER CAN COMFORTABLY & SAFELY RIDE SUCH BICYCLE after making seat height adjustment...............
Walmart fills the needs of a great many folks who want to ride a bicycle. Serious "cyclists" and local bike shop owners might dislike that fact. Just listen to the topic of this thread........"CONSUMER GRADE", as in that those that ride bicycles do it differently than the "cyclists"......(Sure some "cyclists" really ride getting to use all the benefits of weight/technology that their bike provides, while others are riding like a 94 year old grandma driving a Ferrari to church one mile away once a week and occasionally to the liquor store, the grocery store, the beauty parlor, and to wednesday night Bingo, which are all within 2 miles from her home.)
One could even make a case that buying a consumer grade Walmart bicycle for approx $200 or less, and then disposing of said bicycle when it needs repair work other than tires/tubes, brake pads etc,, ....disposing of and buying a new approx $200 or less Wallyworld bike is a cost effective strategy for most people!! They don't need anything state of the art or fancy and the bottom of the line new offerings at the local bike shop won't be any better for them at three times the price!
Yes, that is true!
Liked 4,218 Times
Yes, that is true!
Yes, that is true!
...You brake too fast and too hard, and the human rider (YOU) will possibly become a soaring projectile, much like a football that has been kicked on a field goal try...
Untitled by Stuart Black, on Flickr
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 590 Post(s)
Liked 445 Times
IMHO, disc brakes are best for long highspeed downhill descents at 40+ mph. Would I take a Walmart bike (low quality implied) down a 40+ mph highspeed descent? Nope. Therefore disc brakes aren't needed on Walmart bikes.
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
Well this thread has made me loathe the term 'helmart' as much as I loathe 'fleabay'. Strong work, Stewie.
Likes For mstateglfr:
Liked 2,969 Times
Liked 15,539 Times
Liked 2,488 Times
Not even one reply from OP yet.
