Power meter compatability for old(ish) bike
Hi all. I'm not very clued up on all things bikes / parts - I just get on the saddle, pedal hard and pay a fortune for new stuff every once in a while. After selling my old vector pedals around 4 years ago, I've been powerless for a while and I'm now looking to dive back in. The issue is, I haven't a clue how to determine whether my current bike is compatible with the various options out there. I don't want to go back to pedals (bad memories with the vectors), and like the look of the 4iiii left only crank, and the quarq dzero spider after some desktop research.... I want something pretty cheap and I'm not fussed about super-precise accuracy... just something that works easily (connectivity, durability).
The bike I want to add power to is a Trek Domane Six Series. Think it's a 2015/6 model. Dura Ace (not sure which model exactly, says FC-9000 on inside of the crank), with no mods other than new wheels. Does that give you enough info on the bike to provide me with some recommendations on which power meter I can buy that meets my needs? Any advice greatly appreciated.
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
The simplest (and probably least expensive in the long run) solution would be a 4iii or Stages R9100 LS crank arm. It'll take less than 5 minutes to install, with no special tools other than a crank-arm cap tool.
Likes For Badger6:
Quoted: 4393 Post(s)
Liked 4,836 Times
Bikes: Factor O2, Caad10, Caad2
Quoted: 365 Post(s)
Liked 122 Times
Another possibility is power based pedals. There are still some deals to be had on the Garmin Vectors. These can also be switched to nearly any other bike.
https://www.westernbikeworks.com/search?kw2=vector
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4380 Post(s)
Liked 3,014 Times
Quoted: 479 Post(s)
Liked 277 Times
2014 is old?! ;-) I have a Stages left side PM on my 1998 Klein single speed. The Stages has been great. I actually bought the dual-sided crankset (chainset for you Brits) and move the left side crank around. I've only heard good things about the 4iii too.
Quoted: 2952 Post(s)
Liked 3,106 Times
I have a Stages left arm PM on my old Ridley. See here: https://store.stagescycling.com/STAGES-POWER-L-105-5800
The Shimano ones are cross compatible with all Hollowtech II cranks, including first gen DA 7800, which is what I have. Works great.
Here's the one that matches yours: $250. A total bargain. https://store.stagescycling.com/STAG...DURA-ACE-R9000
Likes For caloso:
Quoted: 532 Post(s)
Liked 621 Times
@millwaj78, the link provided to the stages is indeed a great deal, but since R9000 is now 5(or is it 6) years old, don't dawdle. And At $250, that is a smoking deal!
Likes For Badger6:
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2631 Post(s)
Liked 3,144 Times
I just switched to pedals (Favero Assioma Duo) after being a powertab hub user for about 10 years. Love 'em. I do highly recommend.
The ptap is a great product that met my needs for a long time. I switched b/c I wanted to ride with power using race wheels on my time trial bike, be able to more easily swap the meter between differently configured bikes, and just enjoy some nicer wheels for my daily driver training bike (Giant TCR).
"Your beauty is an aeroplane;
Likes For TMonk:
Liked 3,106 Times
The Shimano-Stages set-up is also super quick and easy to switch between bikes. I will swap it from my TT bike to my road bike that lives on the trainer in about 5 minutes. Just takes a 5mm hex wrench and an end cap tool.
The only limitation is that you'll have to have similar gearing. With pedals, like TMonk has, it could be completely different configurations.
Likes For caloso:
Quoted: 313 Post(s)
Liked 680 Times
Can you even still buy PowerTap hubs?
I've got a PowerTap G3 that has always been solid, more bombproof than the wheel it's built into! Lacing one to a custom rim of your choice would be a solid option if you can find one.
Quoted: 2333 Post(s)
Liked 2,097 Times
SRAM killed Powertap G3
It was probably the cheapest and most accurate PM, plus you get the benefit of a speed sensor
I have eyeballed the Rotor in-power cranks.
Should Be More Popular
Quoted: 22586 Post(s)
Liked 8,924 Times
I "get" that you don't want a pedal-based system based on your previous experience. That said, many of my friends have Assioma pedals are positively LOVE them. That goes for single and double sided.
If you are positive you don't want a pedal system and are on a budget, get a 4iiii or Stages single-sided crank that is compatible with your current setup.
Bikes: Too many.
Quoted: 92 Post(s)
Liked 174 Times
They're out there in used land. I'd assume that they are no longer available new. But when maintained properly they seem to be pretty bulletproof.
