Freewheel lubricant
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 459 Times
Freewheel lubricant
On my 85 Univega Gran Turismo I notice a slight amount of play and clunk after I am coasting and start to pedal again.
When I regreased the bottom bracket I sprayed the freewheel with WD40 to clean it out and after drying it added some
chain lubricant. Is there something else I should ues on it? Thanks
Likes For Riveting:
Quoted: 6186 Post(s)
Liked 4,803 Times
Just make sure the wheel bearings are greased.
If you don't coast much, then nothing in the freewheel really needs lube. Other than some very light something or other for corrosion protection.
Quoted: 1943 Post(s)
Liked 2,164 Times
I use Phil’s Tenacious Oil on freewheel bodies and cassette freehub bodies.
I use bike grease on the bearings.
John
John
Likes For 70sSanO:
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
I used 30wt oil on the keys and springs and then packed the bearings with grease just to hold them in place while reassembling. Like mentioned earlier, the only time there's movement inside a freewheel is when you're coasting and it's engaging.
Quoted: 405 Post(s)
Liked 430 Times
Phil Wood Tenacious Oil is the most correct answer to your question. Best to take the freewheel off the bike, so you can get it really clean, but also works with it still on the hub.
Slowly drip the Tenaciousness into the gap between the part that moves and the part that don't while spinning the freewheel. If freewheel is off the hub, do both sides. You'll feel when the oil gets drawn down into where it goes. When it stops feeling better, wipe off the excess and put the freewheel back on. Grease the hub threads before doing the last bit. The sanity you save may be your own.
Making this a part of your winter screwing-around-with-the-bike routine is wise.
--Shannon
--Shannon
