Old Shimano front+rear derailleur shifter?
Old 07-22-21, 10:09 AM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Liked 118 Times in 99 Posts
Hello,
On a mountain bike from the 80/90's, a friend of mine is having a slight problem operating the seven-speed "SRAM Centera" rear derailleur with a "Shimano ST-EF510-7R" right-hand shifter that's also operating the triple chairing front derailleur and has a brake lever built in (!).
Google returned no hits about that unusual but very practical combo that operates both derailleurs with one shifter. It might be a custom order from the bicycle manufacturer.
The issue is that the chain on the rear derailleur sometimes drops, usually when in any of the middle gears.
Couple of questions:
1. Can the SRAM derailleur be fine-tuned to solve the problem, or might it simply be incompatible with that Shimano shifter — in which case: What seven-speed rear derailleur should he get instead?
2. Have you alreay seen that kind of combo shifter? Why wasn't it successfull?
Thank you.
Winfried is offline
Old 07-22-21, 11:19 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
Some SRAM shifters/DER's are compatible with Shimano and some aren't.
Bill Kapaun is offline
Old 07-22-21, 12:30 PM
70sSanO
70sSanO's Avatar
Quoted: 1944 Post(s)
Liked 2,164 Times in 1,323 Posts
I have never heard of SRAM making derailleurs compatible with Shimano shifters. They made shifters that were compatible with Shimano derialleurs. This makes sense since SRAM started out with Grip Shift.
I would just replace the SRAM rear derailleur with a Shimano mountain bike rear derailleur.
You don't have to get a 7 speed, my choice has been 9 speed rear derailleurs. I use them on nearly everything and they work great. I'm partial to older ones, but something like a new Shimano Altus or Acera is fine.
John
70sSanO is offline
Old 07-22-21, 01:26 PM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Thanks for the infos.
Winfried is offline
Old 07-22-21, 01:35 PM
Bill Kapaun
John
Teach me to assume they worked both ways.
Good to know-
Old 07-22-21, 01:48 PM
70sSanO
70sSanO's Avatar
Good to know-
Not so fast, that doesn’t mean I’m right. I just never heard of that compatibility.
John
70sSanO is offline
