Training Status??? (IV)
Quoted: 693 Post(s)
I think it's more than ash, it's the toxic chemicals released when all the toxic stuff in the 7,500 home or however many that burned to the ground. I guess cigs have "toxic chemicals" in them too, but still.
Anyway, I'm going riding tomorrow. Been laying low all week, good timing for me since I wanted to rest anyway.
lots of stuff in those buildings (and in our homes these days) that is terrible when burned -- and some of it awful when not burned.
some friends do monitoring of particulates in and around the bay area. levels of taxi chemicals in many homes can be astonishing. one tip: if you ever cook with a non-stick pan, make sure you have the fan running!
Quoted: 693 Post(s)
Originally Posted by ttoc6
So I tacked on about 40 minutes of sweetspot ish riding to get close to my assigned tss goal for the day.
Cat 2
I also raced on some carbon reynolds (also tubular) last year as well that were almost as good, but not quite. Even if they weighed like 400g less.
Next year I'll be on tubulars. But for now I bought a new set of (actually tubeless this time) tires. They're 35c which I'm not a huge fan of running "illegal" tires, but I'm in a series that doesn't care and it will be close no matter what is printed on the side wall.
Regarding tss, I just wanted to get some more riding in after a frustrating race and I do not regret it at all! What a gorgeous morning it was!
Quoted: 693 Post(s)
@tommyrod74 @tetonrider I enjoy mountain biking, but not as a racer. I did one MTB race about 4 years ago and pulled out halfway through because I got worried I was going to hurt somebody else.
What's fun about it for me is trying to get technically better. I don't even try to go fast, I try to go slow and work on balance and shifting weight over obstacles. I've gotten way better but still shamefully bad compared to my pro and ex-pro buddies. The gap in skills is just infinitely wide.
holding yourself to the standard of a pro in any sport is a tough comparison.
someone who sucks at sprinting can still work on their sprint; maybe they don't win a field sprint, but they win the sprint out of the break.
that said, bikes these days are super good and roll over so much that it definitely takes less skill compared to years past. sometimes going faster can help a person sail over obstacles; ironically it can be less difficult to go fast in some situations.
the hard part about riding with people that good is that you can't stay behind them and see their lines for very long. it's nice if you can find someone a little bit better.
Originally Posted by globecanvas
But I have absolutely no idea what suspension tuning even is. My bike has the specialized brain thing and I assume that is sort of like automatic suspension for dummies.
i have no idea what bike you are riding or fork and shock, but those parameters control how plush or firm your shock feels, how much it might dive in a hard turn or under braking load, how the bike pedals, whether you can even USE all the travel offered, and whether your suspension gets progressively more stiff the more travel you use or if it is linear.
it can make a significant difference in speed and ride quality. it's usually not hard to get in the ballpark, if you know what you are doing, but getting it perfect takes time.
the other problem is that the terminology is weird. it's why i drew the example of people being totally baffled by RDs: they're just cables pulling a spring, yet many people have NO idea which direction to turn the adjuster.
there's a knob on your fork labeled "rebound". rebound is how fast your fork pops back up after an impact. do you turn it CW or CCW? unfortunately, increasing rebound actually increases rebound DAMPING and makes the shock slower to respond. clear as mud.
some people think going to wide tires (esp the plus craze) reduces the need for suspension, but in reality using tires for suspension is a pretty poor solution. wide tires are great for traction; low pressure in big volume tires is undamped suspension. many of us who have ridden for a while have experienced that in terrible forks and shocks.
Quoted: 693 Post(s)
I had tubulars when I was on rim brakes. I left that bike at home with my parents and brother. I miss those wheels everytime I race. This beautifully built set of Ultegra hubs to some older (very shallow) aluminum rims.
actually, i've got 3.5 sets, which is why i'm getting rid of one. they are super good for cross. the aero isn't such a big deal, but the deeper rims cut through mud.
i'm NOT a reynolds fan, for a variety of reasons. most have to do with knowing too many people who have melted their brake tracks and been handled poorly by the warranty department.
Quoted: 693 Post(s)
The "brain" is an automated lockout (keep suspension from compressing). It's designed to differentiate between rider weight shifts from pedaling etc. and bumps on the trail. It's "lockout for dummies", but it doesn't absolve you from setting up the sag, rebound damping, etc. first.
You use the "brain fade" adjuster to select how big an impact it takes to disengage the lockout and open the suspension. The more you back off the "brain fade", the smaller an impact it takes to get the suspension moving and the more active it is overall.
I'd assume that ideally, you'd set that adjustment up last of all. I'll defer to Tetonrider here as I've ridden brain equipped bikes a fair bit but he seems to have more experience, but I'd assume you'd first back off the fade adjustment all the way (make the suspension as active as possible), set the sag (main air spring pressure), set rebound, then adjust the brain fade to make it as active or firm under pedaling as you prefer.
It would really be worth your time to have someone well versed in the system set it up properly for you, then leave it alone and ride. It will likely be an improvement over what you are used to. It would also be good for you to learn how to do it yourself, and what each adjustment does. It's really not very complicated and, as everyone (even Miyata Man) seems to agree, it will make a very noticeable difference to the ride when done correctly. If not set up to be usable, it's just extra weight to carry around.
some people love the brain, others hate it. i'm equivocal about it.
rode the other day with a buddy, and he's on the latest iteration of it (mine is a 17 but he just got his 18). he felt the responsiveness has improved since his 13/14 version.
i don't like the brain in the fork, so i use a different (fox) fork; i'll sell that RS fork w/ brain immediately when my 18 arrives--won't even bother to test. for my style of riding/racing i like to control the lockout. general consensus is that most riders turn the brain down as low as it can go. IMO, that's time to ditch it.
my buddy feels like the brain in the fork is fine when he's on his FS bike, but for a HT/SS he prefers controlling the lockout.
for the shock, i'm OK with the brain. seems to respond pretty well and gives a solid sprinting/burst platform but is responsive when it needs to be.
i'd NEVER confuse my Epic for my Enduro, descending, though.
Cat 2
i've got a set of 303 FC tubulars....disc. ;-)
Next year when you're back up to 3.5 sets I'll be in touch
Quoted: 693 Post(s)
I think this is the 3rd time you've mentioned them. . I'd jump on them in a heart beat if I had the funds. Just more pressing things. I actually thought about messaging you yesterday about them, but I realized it's a bit ridiculous to buy a whole new set of wheels to fix a tire problem lol.
no biggie.
one thing is you CAN get a set of wheels that is good and transfer it to a new bike down the road (well, depends on what standards one choose with disc).
i won't be back up to 3.5 sets. the reason i have 3.5 in the first place is a funny story, but it's always been too many. i'll probably sell 3 wheels. 2 race sets + 1 training/general riding (tubeless) is more than enough.
Quoted: 693 Post(s)
it gets argued every year by his local region, though, and a few people complain that they show up to nationals with no status. the series in sacramento switched to USAC in order to appease some riders, with nationals in reno.
the other day a friend and are were looking at cross rankings from races as he is going to nationals. he won a race in sacramento and got ~300; he could have finished 15th in a race in the chicago area and gotten a rank of 150. pretty crazy--like racing crits in some regions--lots of riders with great rankings, which helps every rider's ranking.
Cat 2
the reason i did is that with your talent for cross in a brief period of time it's clear you'd benefit from better equipment. there are no guarantees, but in this last one it sounds like it could have kept you in the race if not resulted in a win for you.
no biggie.
no biggie.
Understand the keeping wheels around. That was the plan with last set of carbon tubulars I bought. Raced em 10sp for cross in the fall until I had problems. Rebuilt up to 11 as a set of wheels to keep around and change the tires on and off of for road vs cross. But once I figured out I was moving (and looked around at how many wheels I had + had a bad experience with a tubular in a crit) I sold them. Probably a good thing as I went to disc for cross and I'd like to go to disk for road at some point soon too.
But with the purchase of a TT bike, that move to disc for road will probably get held off. Still need to move some aluminum clinchers. I think once my TT bike gets here I'll be up to 3 sets of aluminum clincher "training" wheels, and 1 set of aluminum training wheels that are absolutely toast. + a set of disc tubeless for my cross bike.
I'll get a set of deep carbon wheels for the tt bike + a disk cover (not doing uci stuff, so it will do) that will double as race wheels for my road bike this year in the mean time. Been really happy with the flo wheels I have, so I'll probably stick in their direction.
When I get around to moving to disc I'll keep the carbon wheels for the tt and get something nice for the new road bike + cross bike in the off season. Especially since risk of damage to rim on disc brake bike is much lower.
Quoted: 1851 Post(s)
Liked 678 Times
lower manhattan in the months following 9/11 was really, really bad.
Ninny
Quoted: 686 Post(s)
My good friend's dad was a 9/11 first responder. He died this year from cancer caused by asbestos exposure, and was added to the FDNY memorial wall. More 9/11 first responders have now died from respiratory illness directly attributable to the event, than died on 9/11.
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2632 Post(s)
Liked 3,147 Times
Backpack trip over, 5 days off the bike, lots of hiking though. Up next: all your base are belong to us!
also it gets pretty damn cold at night >10,000', even in Cali!
"Your beauty is an aeroplane;
Ninny
Quoted: 686 Post(s)
A buddy who is a coach is giving me a sort of free trial of coaching. I am new to the whole training peaks thing. He assigned workouts for the week, but told me I could rearrange them to suit my schedule. So today I did the workout that was on the calendar for tomorrow. I see that I can drag workouts around in the calendar view, but the ride I did today got automatically filled in for the originally scheduled workout. So I guess I needed to rearrange the scheduled workouts before uploading my actual ride? I assume there's no way to rearrange after the fact without literally copying all of the assigned intervals and notes from one workout to the other, and vice versa.
Ninny
Quoted: 686 Post(s)
Also, wow, the training peaks NP and TSS are way different from what I calculate for this ride, by over 25%. FTP is set the same.
I know there are two different commonly used windowing methods that are used for NP, one of which is used by Strava, the other by TP and CA. I know they are most different for rides with a lot of variability, like this one. I guess this is why some people always have ATL numbers that seem crazy high to me.
out walking the earth
Nonsense
Bikes: Affirmative
Quoted: 880 Post(s)
Liked 541 Times
Liked 678 Times
What I find fascinating is if I run a Garmin 500 and PC8 simulataneously, I can get very different TSS, especially doing sprint work at the track. Garmin will give me nearly 300 for a 3 hour workout whereas the PC8 gives me 70.
This was HR-based TSS.
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
What if you have no perceptible effort?
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
Quoted: 2952 Post(s)
Liked 3,106 Times
Gut feels a bit better today so I went for a bit of a ride at lunch time. Meh.
**** that
Quoted: 1099 Post(s)
Liked 104 Times
Quit my old team. Joined a new team. Cat 4 group has started off-season team training for next season. Here's a highlight video of the ride.
Bikes: Ridley Noah fast, Colnago CLX,Giant Propel Advanced, Pinnerello Gogma 65.1, Specialized S-works Venge, CAADX,Cervelo S3
Quoted: 74 Post(s)
Monday: Lunch core workout then 2 hrs ride after work plus 2x12 thresholds. Glad a CAt2 friend once showed me how to pee while on bike and no need to stop.
