KMC chain on sram
KMC chain on sram
Old 05-09-21, 09:11 AM
oujeep1
Bikes: Trek Emonda SLR, Colnago CX1 EVO
Quoted: 23 Post(s)
Liked 4 Times in 4 Posts
KMC chain on sram
I recently took my Tarmac on which I have SRAM Red Etap 11 sp compact crank in for routine servicing, took it to local REI store, the best wrench I know of had moved there from the LBS I frequented when they were bought out by TREK. He wasn't there when I dropped off the bike, dude checked it told me, as I suspected already, it needed a new chain, they don't have SRAM but would put on KMC which was compatible. He was there when I picked it up didn't say anything about chain.
So ever since I got it back drive train is really noisy, I thought while riding it was front derailleur rubbing but putting the bike up on the work stand that is not the case, the noise is mainly coming from the rear derailleur, worse under load ie going up hill and worse in certain gears. Is this just something the KMC chains do? Anyone else with similar issues? Thanks in advance
oujeep1 is offline
Old 05-09-21, 09:50 AM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
You may have needed to change the cassette too. It has nothing to do with the brand of chain.
caloso is offline
Likes For caloso:
Old 05-09-21, 10:10 AM
Iride01
Iride01's Avatar
Quoted: 6193 Post(s)
Liked 4,808 Times in 3,316 Posts
Might be everything is nice and clean now and no gunk to muffle the noise. But as @caloso mentioned, might be time to change cassettes.
I'd think that you'd only hear the noise in a few particular cogs if that is true. But if your cassette has many thousands of miles on it and you went beyond the first time you should have changed it, then maybe all the cogs are worn out.
It's also possible that something came out of adjustment. Maybe the mechanic thought something wrong and tweaked it without double checking the result.
Iride01 is offline
Old 05-09-21, 11:48 AM
ls01
he said member
ls01's Avatar
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times in 1,207 Posts
Ask if it was the stretch proof type chain. I had one on my 11 speed red and same thing, noisy as heck. Swapped it out for a regular 11 speed light weight chain. All is right again.
ls01 is offline
Old 05-31-21, 12:22 AM
Papa Ado
almost like new
Papa Ado's Avatar
Quoted: 26 Post(s)
Liked 57 Times in 24 Posts
KMC here. Our chains have been proven to be as good as or better than Sram chains so it's likely another culprit. Good advice above to check the cassette wear or other drivetrain adjustments.
Papa Ado is offline
Likes For Papa Ado:
Old 05-31-21, 04:35 AM
ARider2
Quoted: 94 Post(s)
Liked 151 Times in 105 Posts
I concur it might be time for a new cassette. I use KMC chains all the time on SRAM and Shimano cassettes but I always check the old chain first to see if it is stretched before swapping. If your cassette is worn you can usually tell by putting the chain on the smaller cogs in the rear and pushing hard on the pedals (say going up hill) to test whether it skips. Be prepared for the chain to skip so you don't get caught off balance.
ARider2 is offline
Old 05-31-21, 06:05 AM
oujeep1
Quoted: 23 Post(s)
Just a quick update- replaced the cassette, fixed the problem. Bad on me for not checking it before, but also something I would have expected the shop to catch- I took it to an REI store, the guy who was the wrench at my local bike store moved to REI when the store sold to TREK. He wasn't there when I checked the bike in don't know if he did the work or not. Anyway problem solved. Thanks for the advice to all
oujeep1 is offline
Old 06-02-21, 09:04 AM
Bob Ross
your god hates me
Bob Ross's Avatar
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1252 Post(s)
Liked 1,277 Times in 707 Posts
No.
I use KMC 11-speed chains on my SRAM eTap-equipped bike with no noise issues whatsoever. Same with my Campy Record and Shimano Ultegra & 105 bikes. Those chains just work.
Bob Ross is offline
Old 06-02-21, 11:33 AM
zatopek
Bikes: Neilpryde Nazare, Storck Scenero G3, Colnago Extreme Power, CAAD 10, Bowman Palace R, Strong Custom Foco Steel, BMC SLR01, BMC ALR01
Quoted: 96 Post(s)
Liked 114 Times in 53 Posts
I run all my 8 SRAM equipped bikes with KMC 10 and 11 speed chains and have no noise problems.
zatopek is offline
Old 06-02-21, 01:46 PM
Iride01
Iride01's Avatar
So what was wrong with the cassette?
Or did he just put a cassette on there that is made of different material? My Ultegra cassette is much lighter than my 105 cassette because it is made from different material. They have a distinctively different sound. Though I'd have trouble saying that either is noisy.
Iride01 is offline
Old 06-02-21, 07:52 PM
oujeep1
Quoted: 23 Post(s)
It was just worn out it wasn't a cassette they put on but the one that was already on it.
oujeep1 is offline
Old 06-02-21, 08:05 PM
BCDrums
Recreational Road Cyclist
BCDrums's Avatar
Quoted: 257 Post(s)
Liked 252 Times in 134 Posts
Papa, who/what proved KMC chains to be as good or better than SRAM chains? Please provide a link. My experience was the opposite, but I’d like to be well-informed.
Thanks.
BCDrums is offline
Old 06-02-21, 08:32 PM
Papa Ado
almost like new
Papa Ado's Avatar
Quoted: 26 Post(s)
Thanks.
We have internal test reports showing results, but this could be viewed as biased. So in real life, I primarily deal with all of the bike brands for the OME side of things. Unfortunately we've been blocked from Sram 12 speed specs but all of my customers have tested our 12s chains on all Sram systems and love them....but can't use them. As for 11 speed and below, we dominate chain specs here so this speaks for itself. In regards, to aftermarket, you could see many comments on this forum and some above with the KMC love.
Papa Ado is offline
Old 06-03-21, 10:09 AM
BCDrums
BCDrums's Avatar
Quoted: 257 Post(s)
Yes, certainly.
From reading the many threads and comments on Bike Forum about KMC vs. [Drivetrain maker's chain], I have surmised that riders choose KMC because they are less expensive than Shimano, SRAM & Campy. These comments describe KMC as just as good as the three drivetrain makers' chains, but I haven't seen anyone describe KMC as better than the other three. They're cheapest.
Other riders who have tried KMC chains found them inferior in performance to Shimano and SRAM. I found a KMC chain to perform less well than both a Shimano chain and a SRAM chain; the KMC was noisy and shifted less quickly. I had never "heard" the chain before I tried KMC, so I went back to Shimano and blessed silence. But the KMC was adequate, and it did shift!
I don't know what "dominate chain specs" means, KMC sell the most? Because they're less expensive?
Looking about for a more neutral assessment of chains, I found this article on CyclingTips.com. It is a report on research done by Zero Friction Cycling. It's pretty nerdy, focussing on durability and efficiency (loss of watts to friction). It doesn't really address the concerns of someone choosing between a $12 KMC chain and a $22 Shimano, but in general, KMC does less well than Shimano, SRAM and Campy.
But again, if the criterion is least expensive, KMC wins every time.
Good luck!
BCDrums is offline
Old 06-03-21, 11:38 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4733 Post(s)
Liked 1,532 Times in 1,003 Posts
Good luck!
A couple things that I'd point out.
First, you curiously referenced the cyclingtips article which exhibits this chart below. If this thread is about 11sp chains, then SRAM is not looking as great as the others, right?
As for $12 KMC chains, at least for 11 speed, there is no such thing AFAIK. The lowest cost one is this (kinda ugly IMO) one at $25, and aside from KMC's own site, I can't seem to find anyone actually selling these gray ones.
And re: the frictionfacts testing, I believe the lowest cost KMC chain in that test is the X11 SL, which is a $70 chain. (not sure, but perhaps the X11 TT chain is discontinued but I believe was even more expensive). Anyway SRAM Red22 chains seem to MSRP at $45. So, not sure even about KMC winning every time if just looking at cost.
Sy Reene is offline
Old 06-03-21, 12:21 PM
BCDrums
BCDrums's Avatar
Quoted: 257 Post(s)
Hi Sy!
I was not thinking that this was a thread about 11sp chains so much as the OP's question about the KMC chain being noisy vs. a SRAM chain that was not. I had that experience too, but on a 9sp chain.
I'm sure you're correct. Again, I wasn't thinking about 11sp.
Really, I got interested when a KMC rep stated that "Our chains have been proven to be as good as or better than Sram chains so it's likely another culprit." When asked about the "proof," he cited KMC's own testing. So I was looking for other, neutral data on KMC vs. other chains. The CyclingTips article is only generally applicable to the original poster's question, but it does indicate that KMC chains may not be "as good or better" than SRAM chains.
If I were the OP, I'd get myself a SRAM chain for my SRAM drivetrain. KMC is perhaps compatible, but not likely optimized for SRAM, eh?
All best!
BCDrums is offline
Old 06-04-21, 01:55 AM
Papa Ado
almost like new
Papa Ado's Avatar
Quoted: 26 Post(s)
Yes, certainly.
Good luck!
Thanks for your opinion! I hope you're not calling ALL of KMC's customers cheapskates. JK Some people prefer other brands (including our Shimano chains) and I've found that many of those people can't be swayed. I personally put faith in customer feedback who not only value price but also performance and compatibility and the vast majority of what I hear are that KMC chains perform better, are quieter, and depending on the level of chain you choose, are more durable. We have a lot of time to focus on chains.
As for Cyclingtips testing, Adam Kerin from Zero Friction is the real deal so I can't argue with his results. Our results show differently so it's definitely frustrating. I've been in talks with him to redo the tests as we aren't sure about the chains he tested as they were purchased through unknown channels. Unfortunately he's too busy, but hopefully can get an update on that soon.
Papa Ado is offline
Likes For Papa Ado:
Old 06-04-21, 06:05 AM
primov8
primov8's Avatar
Bikes: State Bicycle Co. Undefeated Track SS/FG, Lynskey Helix-Bronze
Quoted: 115 Post(s)
Liked 204 Times in 95 Posts
caloso recommended to change the cassette as it was likely the culprit to the noisy drivetrain. The OP updated his thread as he had a new cassette installed and problem solved. It wasn’t the chain.
For me personally, I made the switch to KMC X11SL chains over 10 years ago; their black DLC chains once it became available about 7 years ago. These chains just work as advertised. On every build I’ve done for the last 10 years, it’s always been with a hybrid of a drivetrain. Whether with a Rotor 3D+, Praxis crankset mated to a Sram Red, Sram Red etap components or Campy 11, Campy 11 EPS, Campy H11; even the last 3 Campy builds with Sun Race cassettes, I’ve never run into any issues with the KMC chains. Always smooth shifting with a quiet drivetrain. Plus, I’m also fan of the “bling” factor.
primov8 is offline
Likes For primov8:
