Naming and Scope?
Quoted: 1856 Post(s)
Liked 664 Times
Naming and Scope?
I'm copying this from a post I just made impulsively in Mechanics. I think it's better placed here. Hopefully the Mods (Siu and friends) will agree or resolve it some way that works.
I would suggest a title change to "Early Brifter and Egopower bikes - 7, 8, and 9 speed" to make it clear that Campagnolo is included in the discussion. Often the work "Brifter" is used to describe Shimano hand controls and not Campagnolo ones. The Campy ones are rather different and are not interchangeable with Shimanos, SRAMs, or Microshift for nearly all of their functions. Campagnolo named their controllers "Ergopower," and I think this distinction should be recognized, if the scope is intended to ctually include Campagnolo. If not, I would request a separate sub-forum intended for Campagnolo, or to implement a name change or scope clarification. As far as I can see the other three companies have not given their similarly-functioning products specific names beyond the group level labels (i.e. "Ultegra").
My text from the Bicycle Mechanics forum:
"Just to try to set some nomenclature straight, the Campagnolo combined shift and brake controllers are named "Ergopower," and until a day or two agoI only rarely saw them canned "brifters." I usually saw the Shimano, SRAM, and Microshift devices of a similar nature called "brifters." It really feels wrong to call the Campy versions brifters since there are really a lot ow ways they are not the same as the other brands. And Ergopowers are almost completely not interchangeable with Shimano and SRAM brifters.
I don't want to be the names-police, but I'm sure I'm gonna see people confusing them or lumping them all together, and making it harder than it currently is to know exactly what someone with a problem to be solved is talking about, so I/we can actually give some help.
Maybe this should be moved to the new forum? My current assumption is that it is not intended to discuss Campagnolo, at least if I interpret the name."
They're all different from each other. There are large differences in the internal mechanism and the ergonomics between SRAM's DoubleTap and Shimano's STI as well.
Likes For HTupolev:
Quoted: 634 Post(s)
Liked 444 Times
First of all, brifter is a seriously bike nerd (and not in a cool way, ha), bordering on curmudgeon term. And I use curmudgeon in the most endearing way possible. Most people just call these "shifters" since downtube shifters or any vintage or lesser used options are called "downtube shifters", "stem shifters" or "thumbies/thumb shifters" as appropriate.
But, if you are going use the term (and it probably makes sense in the context of a forum name here since most users here know the term, though newbies might struggle with it), IMO it's generic like @HTupolev said above, not brand specific.
Likes For tricky:
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
So is this forum specific to groupsets from a 3-4 period in manufacturing history? 1998 seems so far to be the focal point.
Liked 664 Times
If you’re looking for a cutoff, it’s not 1998.
Likes For Road Fan:
Liked 664 Times
That isn't my experience. "Brifter" is a portmanteau of "brake" and "shifter", and its popularity - despite many people hating how it sounds - is specifically because it's brand-agnostic. The eponymous phrase which originated as Shimano branding, but occasionally gets applied to other brands, is "STI."
Liked 664 Times
That's a totally different category. Indexed shifting predates brifters*, and although indexing is necessary for most forms of brifter, I'd argue that integration had a significantly larger impact on how bikes are ridden.
*By six years if you're talking SIS, about a decade and a half if you're talking about the late-20th-century Japanese derailleur indexing race in general, or considerably longer if you're talking about all forms of indexing in bicycle drivetrains.
They share common characteristics that separate them from non-integrated road shifters in both placement and functional consequence (of particular note being the ability to easily shift while riding out of the saddle), and so it's often useful to have a non-brand-specific term to refer to them in general. Obviously you could also use a descriptive phrase like "integrated brake/shift lever", but these are a mouthful compared with the simple portmanteau "brifter."
Based on what? Can you point me to an example of a discussion where someone is using "brifter" in a manner that clearly excludes Ergo?
I feel like we're speaking different languages.
IME “brifter” does not refer to Ergopowers.
Likes For HTupolev:
Quoted: 2432 Post(s)
Liked 638 Times
Dura Ace 7400 STI came out in 1990 so the year range is pretty much the 1990's and early 2000's. A little too new for the vintage section and nobody in the road section would be interested. Should have called it the "grunge" era
Likes For Lazyass:
Advocatus Diaboli
Liked 1,532 Times
Genuine curiosity, but what happened in the early 2000s that marks the end of 'early brifters' ?
Likes For Lazyass:
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,897 Times
I find it interesting that when the Eroica rides started in 1997, they just went back 10 years to 1987 for the division. But then rather than sticking with "> 10 years old" as the definition, they stuck with "Older than 1987". So, every year, the bikes ridden there are another year older.
Likes For genejockey:
Quoted: 1528 Post(s)
Liked 718 Times
Here's your milestone to mark the end of the early brifter era - ubiquitous carbon and no more steel.
Likes For Kimmo:
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Humans always try to categorize things, events, eras, etc, because that's how our minds work. And then we like to think the divisions between the categories are logical, but mostly they're based more on emotion. I think it's easy to argue that the advent of brifters was a watershed, and recent enough that the bikes are merely OLD rather than Vintage, but drawing the other line when 10 speeds became available? Much murkier. There was no technological innovation that suddenly allowed Shimano and Campagnolo to suddenly put another cog on there. They just made them thinner with less space between them and added another click in the shift mechanism. Same with 11, 12, and now 13 speeds. Has there even been a similar watershed moment since brifters?
I'll go you one better on the "it's a weird line" thing--technically, a bike built yesterday with Sora or Claris would qualify as an early brifter bike.
Obviously, we need an arbitrary year cutoff, but I think it's safe to say that we're all talking about roughly the same era, barely into the 21st century at the latest.
Tragically Ignorant
Liked 9,098 Times
Quoted: 1104 Post(s)
Liked 1,825 Times
One day, they will simply known as "shifters" because no one will remember anything else before them.
Is it really important what they're called now? Even if it is, I don't like the chances of anyone's groundswell effort on the internet to create a universal term for them.
Tragically Ignorant
Liked 9,098 Times
The problem for people who want to campaign against the term is they haven't come up with a useable alternative.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Who do people who don’t like the term “brifter” want to call them “shifters” and not “brake levers”?
Tragically Ignorant
Liked 9,098 Times
Advanced Slacker
Liked 2,537 Times
Quoted: 1944 Post(s)
Liked 2,164 Times
Not to be too negative, but I'm trying to figure out why there is a subforum named after the shifting mechanism.
The issue I see is that there is a gap between the "revered" classic and vintage bikes and "dump that old piece of..." bike and get something new.
I agree that there should be a subforum for those "not-quite-classic-but-not-new" bikes. But calling it after a shifting mechanism is like having a "26er Suspension Fork" subforum.
And where do non-early brifter people go? Everyone knows that one day there will no longer be early brifter bikes as when the shifters wear out, few can be repaired and donors will be gone. Maybe an "Early and Microshift Brifter Bikes 7, 8 and 9 Speed, But You 2003 10 Speeders Can Go to..." subforum. I am being sarcastic about that title.
John
Edit Added: Why not call it "90's and Newer Bikes", or something like that.
John
Tragically Ignorant
Liked 9,098 Times
I get that, but even the anti-cromulationists can't justify using a longer phrase that describes only one of the functions. And they can't call them levers because that could be the QRs.
Tragically Ignorant
Liked 9,098 Times
John
John
Tragically Ignorant
Liked 9,098 Times
Likes For livedarklions:
