Question about my new tires
I just received my new Continental 5000’s and mistakenly ordered 23’s instead of 25’s. They are for an older set of Zipp 808’s. Is it worth the trouble to replace them with 25’s or should I just be happy with the 23’s.
Semper fi
Semper fi
Should Be More Popular
Quoted: 22572 Post(s)
Liked 8,918 Times
I think there was an article last year that 75% of the Tour de France riders had moved from 23mm to 25mm, so if you planning on riding that hard and fast there is probably a noticieable difference.
The advantage is lower rolling resistance, increased comfort. But, if you ride at more mortal speeds it may not be noticeable to you and you could just use the 23s until they wear.
I run 32 mm GP 5000s on my Domane road bike - group and solo hilly rides, not racing. I've moved up to wider tires over the years for the above reasons but I've I ordered 28mms by mistake I'd probably just use them until they wore out.
Thread Killer
Quoted: 3129 Post(s)
Liked 1,698 Times
The differences can be noticeable, the gains tiny. I wouldn’t worry about losing performance; 23s will keep you on front of the A group if that’s where you ride…or midpack C if that’s where you ride. In other words, a couple millimeters of tire isn’t doing anything magical, so it’s probably not worth the hassle of return and wait.
Likes For chaadster:
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
I'd say replace them with the 25s, and I'll explain why. With the GP4000s, the 23s measure almost 25 and the 25s measured almost 28, on all my bikes. The 5000s have been "rightsized" (according to the rep I met) so they will be very close to 23 and 25 stated widths. So the 23 is quite narrow and the 25s will be more comfy and possibly quicker in some situations. That's my take.
Likes For Chandne:
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
I have used them both and the 25 are maybe bit easier for comfort it is not a huge difference. They do measure out proper as 23 and 25 but if the difference means that much to you then you are a different rider than myself. Just stay on better roads and you won't know the difference till these wear out.
Liked 8,918 Times
Bikes: SL8 Pro, TCR beater
Quoted: 981 Post(s)
Liked 582 Times
It depends where you ride and how much comfortable you want to be IMO. I ride 28mm @ 70psi on my race bike and wouldn't go back to even 25mm.
A 23mm is no more or no less comfortable than a 28mm, at the same pressure, but you may experience pinch flats if you ride low pressure on an uneven surface.
It’s funny because I raced for years on 23’s with no problems. But since switching to wider tires 23’s have me concerned a little on damaging my carbon wheels, they just so dang skinny. Looks like rubber bands stretched around my wheels.
Semper fi
Semper fi
Bikes: yes, i have one
Quoted: 1136 Post(s)
Liked 1,179 Times
Me thinks you are worrying about nothing. You have used them for years so should be familiar enough with them.
I ride 23s and have absolutely no issues with them.
Likes For spelger:
Likes For Bevo Bill:
Use the larger size, or even 28mm, if your frame will take that size. I went from 23 to 25 on my rim brakes bikes, but now riding disc brake bikes with 28mm tubeless and pressures in the sixties. What a huge improvement in ride.
Quoted: 6177 Post(s)
Liked 4,794 Times
I can't say that I could tell much difference between 23's and 25 mm tires. Though I don't have to be the fastest one out there. Nor do I gripe about bumps.
However, my roads are pretty smooth asphalt for the most part. Just some annoying bumps every now and then that will be annoying on most any size bicycle tire.
Quoted: 4559 Post(s)
Liked 2,802 Times
My road bikes are all older models and won't accept tires wider than 700x25. I ride 700x25 Conti GP Classic skinwalls on one, and 700x23 Soma Supple Vitesse SL skinwalls on another. Hardly a nickel's worth of difference between 'em in ride quality. Both are remarkably good on our increasingly coarse chipseal and neglected infrastructure.
The quality of the tire and latex tubes matter more than the slight difference between 700x23 and x25, at least on my bikes.
Silca latex tubes may be a tight squeeze with some 700x23 tires, but Vittoria makes narrower latex tubes that will fit nicely. I think Vittoria makes the Silca branded tubes anyway. Try 'em. Really improves the ride with skinny tires. And the better the tire, the more improvement I feel.
Likes For canklecat:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1939 Post(s)
Liked 1,463 Times
Likes For SoSmellyAir:
Quoted: 464 Post(s)
Liked 182 Times
I wasn't sure if the GP5K would fit in my older BMC (the 25 4000s do) so when the rep told me about the sizing becoming more accurate to stated width, I stocked up on the 4000s. I'll try the 28 5000 at some point to see it it fits the rear.
Bikes: 2014 Specialized Roubaix, 2020 Trek FX3 Disc
Quoted: 14 Post(s)
Liked 7 Times
FWIW, just mounted some 28 5000's on Mavic Aksium rims -believe they're 18 internal width. They both measure 26.25 mms aired up to 80 PSI.
Liked 1,463 Times
I had the same experience with the 25 mm version! They were visibly narrower than the 25 mm Grand Sport Race they replaced, which is why I measured them.
