Lightweight vintage triple cranksets
I have a question that I realize is probably an oxymoron.
Among vintage triple cranksets, are there any that are notably lightweight compared to other vintage triple cranks? I'm thinking square taper only, 90s or older. I like 110/74 BCD but it does not necessarily have to be that.
Normally I'm not a weight weenie but I am planning a build with a steel frame that's lighter and nicer than what I'm used to, so I'm trying to minimize weight where I can while still maintaining features that I like, such as a triple crank.
Thanks in advance.
Thanks in advance.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
The classic Spécialités T.A. Pro-5-Vis comes to mind as well as the Stronglight 107?
But I'm not much of a weight weeny myself so perhaps others can come up with some better options.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
I'm a fan of the Stronglight 99, but could not tell you its weight.
Quoted: 18373 Post(s)
Liked 4,508 Times
Did Shimano incorporate Hollowtech in their octalink cranksets? Perhaps I should weigh one.
Quoted: 1829 Post(s)
Liked 3,374 Times
here's a little weight info on the T.A. Cyclotouriste and Stronglight 99...
Any interest in a Sugino AT? It is a fine 110/74 crank that can be set up as a double or triple. I happen to have a set of bare crank arms sitting out at this time, and could toss them on the scale.
Steve in Peoria
Steve in Peoria
Likes For steelbikeguy:
Quoted: 767 Post(s)
Liked 1,898 Times
Velobase lists this Deore XT set at 698 grams.
VeloBase.com - Component: Shimano FC-M737, Deore XT M737
The same site lists the TA Cyclotouriste at 611 grams.
Quoted: 1943 Post(s)
Liked 2,164 Times
For a 90’s triple crank with 110-74 I would think an XTR M900 would be pretty light. Couple it to a titanium BB and your in business.
I’d guess the M950 with the spider system might be lighter, but I’m not a pure C&Ver and even I have a tough time looking at it, especially after a few years of riding.
John
John
Likes For 70sSanO:
Quoted: 3241 Post(s)
Liked 2,512 Times
I only ride triples and have a lot of them. Mostly 110/74, but a Stronglight 99 as well. Also have a 130/86 Takagi AD. I've got Suginos, Sakae/SRs, Shimanos, etc. Weight wise, not enough differences to matter. What does matter these days is finding the correct BB spindle. If you prefer a spindle that uses bolts, a 3U bolted spindle is very hard to find. You can find cheap, nutted 3U spindles if you can use those.
To summarize, make sure you can get a spindle that works before you get the crank. Otherwise, you might be looking for a long time.
Friendship is Magic
Bikes: old ones
Quoted: 26410 Post(s)
Liked 10,376 Times
...the old Avocet square taper cranks from the '70's were infamously light, but they were drilled in the crank spider to mount the small ring, so they had a tendency to self destruct after a while, I think they were made by Ofmega, maybe. Remember the old adage about light and durable being on two sides of a fine line. Build yourself some nice wheels, with lightweight modern rims and equip them with decent lightweight tyres (that have at least some puncture resistance and will inflate to 120 or 130). You won't notice whatever ounces you add on there for crank durability.
Quoted: 500 Post(s)
Liked 466 Times
FWIW, since I’m certainly not a weight weenie, I weighed these three 110/74 cranks, all weighed as just the arms (length as noted), no rings or BB
Sugino AT, 170 arms: 480gm. BTW, I suspect 175’s would weigh the same, the pedal hole would just be 5mm farther out
Ritchey Logic (early 90’s version, made by Sugino) with “hidden fifth arm”, 175 arms: 475gm
Specialized “flag”, 170 arms: 465gm
If one is counting grams, the AT takes the longest BB at 127.5. Lots of steel there.
Might not be considered sufficiently “vintage” - wife’s custom ‘96 Erickson had a very light and pretty set with “”ball-shaped” ends at both the pedal and spindle, but the brand name escapes me. DS crank was swaged to the spider, which was a weak point, but never a problem for her. Also, the pedal threads were blind, so some pedals couldn’t be used. Photo below:
Liked 2,512 Times
The Sugino AT mentioned above is a very attractive crank. This one takes a 3U spindle. It took me a long time to find a bolted one. The Shimano 600 FC-6206 is a high quality, attractive crank. Somewhat hard to find in 170 crankarm size.
Liked 2,512 Times
The majority of Japanese JIS triples I have take a spindle in the 121-122.5 range.
Quoted: 1163 Post(s)
Liked 442 Times
Any 110 bcd 5 bolt double (square taper) crank can be outfitted with an IRD triplizer mid ring (36 or 34 tooth I believe) to accept a 74 bcd inner ring. I'm sure there are high quality, lightweight 110 bcd doubles that are very lightweight that would be a trick set up with the IRD triplizer middle ring.
WGB
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times
I have a Takagi Tourney GS set in box 50-45-30 IIRC. Very nice and seems light, though don't have a scale and can't see a weight recorded online. If you can find one you'll be pleased.
Quoted: 4510 Post(s)
Liked 6,377 Times
Liked 3,374 Times
I'm guessing Topline cranks....
but my second guess is Cook cranks....
Steve in Peoria
(haven't looked at the Bike Pro catalog in a looong time!)
Bikes: Bike Friday PRP, Bike Friday NWT, Bromton M6R, 1991 Miyata 914, 1991 Miyata 1000, 1986 Raleigh Portage, many more frames
Quoted: 215 Post(s)
Liked 347 Times
Specialized "flag" triple?
Quoted: 5888 Post(s)
Liked 3,471 Times
I would have think that the lightest triple would be a cold forged crank given that's the strongest way to make alloy parts. The 1992 Bridgestone catalog has a good description of the various ways to make alloy parts. This is from that catalog:
"Cold-forged parts are typically thinner, lighter, stronger, more accurately made, and more expensive than cast parts."
Death fork? Naaaah!!
Liked 2,512 Times
Liked 2,512 Times
I had to have a black crank for the latest build. This one is part of the Suntour X1 MTB group. It was made by Sakae or Sugino, though. I did some weight weenieing before I got it. It beat out some of the other black cranks, including some Shimanos. All of the ID marks on the components have been blacked out with a Sharpie.
Liked 2,512 Times
The Shimano FC-1057 is a good crank with a relatively short spindle. Ramped/pinned also. The finish can look yea or nea depending on the bike.
Quoted: 500 Post(s)
Liked 466 Times
Here it is - note the small engraved flag marking near the crank bolt, hence the nickname. It’s a nice crank set. I’m using it on a 113mm UN-55 BB with a 3.0mm DS spacer for proper chainline.
And here’s the Velobase listing:
VeloBase.com - Component: Specialized Touring triple (flag emblem)
Thanks @merziac and @steelbikeguy for the memory jogs. Pretty sure hers was a Topline, but Cook Brothers was a good thought, too. Good idea to look in my old Bike Pro catalog next time! It’s a great resource for questions like this.
Bikes: '72 Raleigh Super Course; '90 Cannondale ST1000; '98/99 Cannondale T700; 2002 Cannondale CAAD5 R700; 2022 Cannondale Topstone 2L
Quoted: 166 Post(s)
Liked 348 Times
They’re not vintage, but I believe the SunXCD cranks are lighter-weight.
Quoted: 576 Post(s)
Liked 1,001 Times
RaceFace Turbine LPs came in at about 460g for the arms IIRC. I used to have Toplines but they cracked on me twice. After swapping to these, my feet hurt at first from the improved stiffness. I still have them and many sets are still alive. Pictured is my red microdrive model, my black 110/74 is still in action.
Last edited by DorkDisk; 07-27-21 at 06:09 AM. Reason: Uses 113 spindle, is very Low Profile
Likes For DorkDisk:
