Rear derailleurs for 1974 bikes with 2x5 friction shifting?
Quoted: 1856 Post(s)
Liked 664 Times
My restoration of a pair of 1974 Witcomb bikes continues. I'm looking into selecting rear derailleurs. The old ones are mismatched and badly trashed, so they're not usable and do not reflect the original equipment. The bikes are low-end, between a Raleigh Super Course and a Raleigh Record of the day. The gearing is 2x5, DT friction, 14-28 rear and 52 / 42 front. Total wrap is 24 teeth, rear cog is 28. To accommodate the 1983 chainsets I'll try to use 7-speed SRAM chains, but we'll see.
What vintage rear derailleurs would you guys suggest? I'd like to put on something reliable, like a Svelto, but could a short-cage SunTour V work here? I have a few spare Huret front mechs I can use. With 52/42 about anything should work.
Oh, the dropouts do not have derailleur hangers, so I would use claws for installation.
Any ideas? The owners intend to get a lot of use out of these bikes so I don't think I'd give them Simplex Prestige (or similar, unless they are really special) or Huret Allvit.
Quoted: 930 Post(s)
Liked 1,291 Times
Suntour V, Vx, VLuxe, etc would be your best bet for indestructibility and excellent shifting.
Bikes: Bike Friday PRP, Bike Friday NWT, Bromton M6R, 1991 Miyata 914, 1991 Miyata 1000, 1986 Raleigh Portage, many more frames
Quoted: 215 Post(s)
Liked 347 Times
Ditto on the Suntour V-series. Bombproof quick shifting, and can be had for not much money.
Likes For philpeugeot:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
yep. nothing to add to that
Quoted: 1088 Post(s)
Liked 1,205 Times
Also Suntour Blue Line, or BL. Same geometry, same internals, great derailleurs.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
totally underrated line from suntour. i shoulda though of that. lighter than the V series, but just as bomb proof. to me, they're cosmetically like the "woodie" of the suntour options...if that makes sense.
Likes For thook:
If you want to try something that might have appeared on a bike like that in 1974, the Huret Challenger will accommodate the chainwheels/sprockets you mentioned. They are robust and shift well. Suntours are a sure thing, but didn't really appear as standard equipment on British or European bikes until the mid to late '70s
Quoted: 3810 Post(s)
Liked 6,690 Times
OEM rear derailleur to several Brit bikes I’ve had from that era was the Shimano Crane. Long cage version will deal with lots and lots of wrap. Short cage works just fine, too.
Quoted: 478 Post(s)
Liked 634 Times
My limited experience with Svelto on the same gearing on a different bike was that it was adequate but no where near either Suntour or Shimano (or even TBH Simplex).
Likes For markk900:
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 697 Times
With the Suntour, the VX version I like best is the S. It will be marked as such on the cage. Suntour had a mid length cage on a few derailleurs and the VXs was one of these. It is beautiful, light, durable, and just seems to be made for the application you speak of. I am running at least 3 of them. They came stock on quite a few bikes so there are lots out there. The easy chain removal of the open cage is so convenient also.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Late too the thread, but I would echo the SunTour recommendations. Second choice would be Huret. I really don't like Shimano of that vintage and the lower end Campy is not all that great.
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
Since it's claw mount I would recommend the suntour 7. They were slightly heavier than the pricier suntour and worked well. Also indestructible.
Likes For 52telecaster:
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
Gear ratio suggestion: 52-40 would work best with 14-17-20-24-28, but you need a 135mm or smaller BCD to take advantage of that. 52-42 works well with 14-16-18-21-24 or a 14-16-18-21-24-28 6-speed. You want the percentage step in front to be 1.5 times the average step in back.
Quoted: 5888 Post(s)
Liked 3,471 Times
https://velobase.com/ViewComponent.a...c-afdca097103d
Likes For bikemig:
Quoted: 604 Post(s)
Liked 1,063 Times
You could splurge on a Suntour Cyclone, stock RD on the late 70s Supercourse. Is a Supercourse really considered low end, certainly doesn’t ride like it.
Tim
My 78 Supercourse
Tim
My 78 Supercourse
Likes For tkamd73:
ambulatory senior
Liked 3,661 Times
Quoted: 965 Post(s)
Liked 1,629 Times
Question 1: Is there a modern day long cage retro available? Can you buy a new, late model, long cage derailuer that looks and fits with a 5-6 speed vintage bike?
Question 2: Are there any decent looking late model Friction Shifters being made?
Nice bike.. Basket fulla groceries... In Texas that would be a brisket and not bread... Ha
The search goes on...
Likes For zandoval:
Quoted: 2338 Post(s)
Liked 2,822 Times
another vote +1
Likes For BTinNYC:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Be careful what you wish for!
https://www.universalcycles.com/shop....php?id=108562
Likes For ThermionicScott:
Liked 2,822 Times
New components vintage looking
dia compe shifters $59
https://velo-orange.com/collections/...-w-dt-shifters
micro shift derailler $46
https://www.incycle.com/products/mic...oaAu4OEALw_wcB
shimano acera $33
https://www.biketiresdirect.com/prod...IaAp0wEALw_wcB
shimano acera $33
Likes For squirtdad:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Somewhat unbelievably, Shimano still makes turds like this:
ambulatory senior
Liked 3,661 Times
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
[QUOTE=bikemig;22337558]These are lower end bikes. I was going to suggest a Shimano titlist which also comes in short and long cage versions. The short cage ones tend to be inexpensive. They are not as good as suntour RDs but they are work well.
I'll second bikemig's Titlist recommendation, the short-cage version with it's non-adjustable b-tension is pre-set optimized for any 28t freewheel and gives fantastically-responsive shifting.
Older short-cage Suntours won't do 28t at all.
The Allvit is one that is really designed for the 14-28t 5s freewheel with a typical 52-40t crankset. It will shift as responsively as the shifter and cable perform, but does feature a somewhat regressive actuation ratio going up to the 28t (so with a little extra lever throw). Indestructible ball-bearing pulleys are a very nice feature of these.
Factory settings on a Simplex prestige are also optimal for use on the 14-28t freewheel so performs really well (but good luck keeping a matching front mech in one piece on your bike).
I cheated on this one. But I did achieve fantastic shifting over a 13-28t 6s Uniglide freewheel after routing the cable to the wrong side of the pinch bolt for "faster" action with less lever throw (ubiquitous mid-cage Deore MT-60 if I'm not mistaken)...
Allvit modified for greater travel for use with standard 6s cog spacing gives race-quality shifting using modern chain:
I put a Suntour V Luxe on my mid '70s Falcon San Remo. It works quite well.
Likes For rjhammett:
