Presta valve caps
Quoted: 2700 Post(s)
Liked 486 Times
Presta valve caps
You know those plastic valve caps that everyone throws away? Well my presta valve is leaking and I have to throw the tube away. It looks kind of bent. Think I should have kept the valve cap? Has anyone else had a presta valve leak, and think its because you didn't keep the protector on it?
Quoted: 18411 Post(s)
Liked 15,531 Times
No. But I have metal valve caps. They are red, so they are the fastest.
Likes For indyfabz:
Quoted: 624 Post(s)
Liked 396 Times
Some presta valves can be unscrewed so check the tightness. You can also use a pair of plyers to straighten the presta valve stem. I have florescent green valve caps.
Quoted: 6193 Post(s)
Liked 4,808 Times
I always use the plastic caps on both presta and Schrader. I've always felt they are another layer of protection for keeping dirt out that might cause a valve to leak. Maybe it only happens once every other blue moon but once anytime is probably going to be the worst time for it to happen.
I don't look at other peoples wheels to see what they do for their valve stems. I don't know why they should be looking at mine and care whether I do or don't.
I even use the little nut that goes on the presta stem too. I guess I'm a maverick?!
Likes For Iride01:
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
It was bent by the pump head.
Just replace the core with a new one.
Likes For GlennR:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I don't use the cap because it's inconvenient to unscrew them every time I inflate the tires, and I rarely get a bent valve, but it does happen. As mentioned above, you can just swap the core out. You could even start collecting cores from tubes you're about to throw away, giving you a stash of spares.
These are very useful for when the tube goes completely flat and the pump head tries to push the whole valve inside the rim before engaging fully.
It's like riding a bicycle
Liked 15,531 Times
Likes For indyfabz:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
The only use I have for a presta cap is as an emergency shraeder adapter. Cut off the tip, turn it upside down, and screw it on. You can then use a shraeder pump or gas station compressor.
https://www.purecycles.com/blogs/bic...hrader-adapter
On Your Left
Liked 2,433 Times
Likes For GlennR:
Quoted: 763 Post(s)
Liked 1,732 Times
Likes For jaxgtr:
Quoted: 6963 Post(s)
Liked 10,961 Times
Likes For Koyote:
Yeah, bent presta valves are user-induced, usually by being rough when putting the pump chuck on or taking it off. Presta valve caps are strictly for style.
Likes For BlazingPedals:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
I use the caps like I give a damn until I lose one or break one, Then I remove it from the other wheel and ride like I don't give a damn.
Quoted: 896 Post(s)
Liked 2,063 Times
I was sure Sheldon Brown argued they were useless once the tube was unfurled, but I can no longer find that quote. Lacking Sheldon's backing, I may have to reconsider my position as a Presta valve cap denier.
With a sharp instrument you can modify a (plastic) Presta cap to be a functional Schrader adapter, thus fill your fancy bike tire at a gas station. So I guess that's an argument to carry a sharp knife and mount your Presta caps.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I no longer throw away valve caps, though -- I patched up a bunch of old tubes a year or two ago and wasn't able to roll them up properly since I was short on caps.
Liked 486 Times
So it was damaged by the pump and the cap didn't matter.. got it, makes sense. I wish I could just use shrader but I don't think my wheels allow it.
On Your Left
Liked 2,433 Times
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
Don't do that. Just take care when using your pump. Presta valves without caps look way sexier than Schrader valves without caps.
Bikes: Surly SteamRoller
Quoted: 42 Post(s)
Liked 53 Times
Likes For TomM:
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 258 Post(s)
Liked 378 Times
I use metal caps myself, but my cycling son doesn't use caps. He says he doesn't want to carry the extra weight.
On Your Left
Liked 2,433 Times
Likes For GlennR:
Quoted: 1943 Post(s)
Liked 2,164 Times
Likes For 70sSanO:
Quoted: 4806 Post(s)
Liked 3,928 Times
You're not crazy; I remember reading Sheldon (or maybe Jobst Brandt) saying that the only purpose of the cap was to keep from poking a hole in the tube while it was rolled up.
