Trying to decide on new bike purchase
Quoted: 184 Post(s)
Liked 36 Times
I currently spend most of my gravel riding on a 2016 AC Space Horse with American Classic wheels and RH 42 knobby tires. Mostly, this has been just fine for the majority of needs. Each year I do one particular race that has a 10 mile section of 2-4” sized rock. Even with low tire pressure, it’s a miserable ride, lol. This always makes me wish I had ridden my fat bike instead….which brings me to my current quandary, would something like a Surly Midnight Special, with its bigger tire clearances make those really rough sections more tolerable?
Quoted: 286 Post(s)
Liked 261 Times
I don’t think a bit more tire volume would help much, and all for 10 miles a year...your money!
Likes For Noonievut:
Try things like tire inserts with the lowest possible pressure and a redshock stem to make it more tolerable before buying a whole new bike just for one section of one race. I have to ride my MTB with a good air fork + 2.2" tires @ 18-20 psi over a section of railroad ballast (1.5-2" rocks) on a singletrack I frequent, and it's still pretty rough.
Likes For zen_:
Quoted: 184 Post(s)
Liked 36 Times
Tire inserts
The red shock stem is a good idea, thanks. What would be the purpose of the tire inserts though? I’m already tubeless, and do not have a problem with flats.
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
As others said, buying a bike on account of a 10mi section of riding that you do once a year seems like a bit much. In the moment, its probably a miserable 75min though.
Why not just use your fatbike? What do others use during the race? If everyone is suffering equally on the 10mi because the rest of the race overwhelmingly benefits from a 43 or narrower tire for whatever reason, then just stick with what you have.
Likes For mstateglfr:
Quoted: 425 Post(s)
Liked 454 Times
For that kind of serious chunk you're not going to notice any improvements by going up by just a few mm in tire size. Guessing based on your description, I'm thinking 2.4" or 2.8" tires are needed.
Likes For tFUnK:
Quoted: 184 Post(s)
Liked 36 Times
Tire Size
The MS takes up to 2.35", so definitely on the low end of your suggestion. I probably need another bike like a hole in the head, but..... I do have a vintage rigid mtb that I could throw a Surly Corner Bar on to try. Suspect it maxes out at around 2.35 also. Thanks.
Quoted: 215 Post(s)
Liked 299 Times
Along the lines of the shock absorbing stem, you might consider a carbon seat post. These will tend to have more compliance. Or of course get an actual shock absorbing seat post.
