Track Racing Frames and Complete Bikes
#201
The fork rake is dependant on the Headtube angle to give you the proper amount of trail for the handling characteristics that you want. Track surface is not important, but the banking is. I'm assuming you're talking about T-town. Alpenrose is concrete as well, but the two tracks are very different. The LOOK 464 front end has road geometry. It should be pretty neutral, but it will make the wheelbase longer. Should be fine for a do it all bike.
#203
Lapped 3x
Larger tracks don't necessarily require the short wheelbases that a steeper track bike affords. You can make almost any bike work on any track, but how well will it work? That's up to you to determine. Your handling preferences will weigh heavily on the geometry that best suits you. 60mm of trail gives you a pretty neutral handling bike. Longer is sluggish, shorter is twitchy. You can achieve any number with either a steeper headtube/less offset, or slacker headtube/more offset (just depends on the how the combinations add up). Although they will behave similarly when travelling in a relatively straight line, there will be some sluggishness when changing direction with the slacker set up because the wheelhub/point of contact is further away from the steering axis, (and) causing the wheelbase to lengthen when you turn the wheel (on an already longer set up). Not a big deal for larger, shallower, wider tracks or TT events. Sprints, keirin, chariot races, and mass start events will benefit from the steeper set up.
It's all relative to perception as well. Some can tell, or need (benefit from) a certain set up, to others, it's a non factor. Best to ride what fits and makes it fun.
#204
Quoted: 4806 Post(s)
Liked 3,928 Times
Ben
#205
Lapped 3x
#206
Liked 3,928 Times
https://www.ridemorebikes.com/wp-cont...d-dropouts.jpg
which one does it look like?
We went 11 degrees on the angle of the dropout; a compromise. Level like a track end means the BB height and pedal clearance stays the same with small cogs for descents, road drop angles mean that moving the wheel doesn't change where the brake track and pads. The slight angle means that the entire range stays on the sidewall of a semi-deep Velocity Aero rim.
Ben
#207
Quoted: 5 Post(s)
does anyone know the geo on the 2015 giant omnium in large? top tube and seat tube lengths. the website doesn't display such information.
Omnium (2015) | Giant Bicycles | United States
#208
Dolan posted the successor of the Track Champion, the Dolan TC1 Aluminium Track Bike
Make: Dolan
Model: TC1 (Frameset and complete available)
MSRP: £699.99 (~1080USD complete), £349.99 (~540USD frameset); UK tax is 20% which will be removed if you ship outside of UK
URL: complete / frameset
Geo seems to be pretty close to the old TC. TC1 has +1deg Head Angle and Seat Angle slightly steeper (+0.5-0.7deg). Cut away and oversized downtube as the TC.
Paintjob looks much more appealing
(I also just saw that Track Bike Frames | Planet X has some Cinelli Mash frames for 33% off)
Make: Dolan
Last edited by rndstr; 02-13-15 at 01:54 PM. Reason: format as advised in first post
#209
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
That's a great find. Thanks for posting.
£349.99 is approximately $533USD + shipping + duties (taxes). That's a great price.
By the way, I have ordered directly from Dolan in the UK shipping to the USA and it arrived within a week. I have a friend that had a similar experience. I'd order from them again.
Regarding geometry: The frame sizes are based on seat tube length, not top tube length.
#210
It's even cheaper since £349.99 includes the tax which they remove once you select a country outside of the UK! It results in £291.66 + shipping. E.g., to LA it is £75 gives a total of roughly $560 + US taxes.
#211
Elitist
Liked 92 Times
The HOY bikes are on sale. Not sure when they went on sale, but they are a great deal.
Evans Cycles | Mountain Bike | Specialized Bikes | UK Online Bike Shop
These are AMAZING prices for great entry to mid-level bikes with great geometry and a really good component set. Buy these complete bikes now and upgrade to fancy wheels, bars, etc... later as you progress.
They even come as large as a proper 60cm TT.
#212
Now I need a fourth track bike!!
I would also add 10-15% for US import duty & associated customs agent fees.
#214
The Hoy bikes were on sale when I got mine. Still pretty happy with mine. As mentioned in thread only issues so far were dubious seatpost head and the rear sprocket wasn't the ss-7600 as promised. But at the price I just replaced them both. Will also need to swap the tyres when I take it indoors.
#215
Bikes: 2015 Fuji Track Elite, 1990-something Steel Fuji Fixie conversion
I just got a 2015 Fuji Track elite Frameset. I've been riding a week and so far the seat tube hasn't slipped nor has the saddle angled on me. I am 6'2" 225 lbs. It's a great bike if you are taller as there aren't as many options.
#217
Bikes: Planet X Pro Carbon, Dolan FXE, Fuji Transonic
Quoted: 5 Post(s)
Thought I would go through and collate every bike I saw into one list along with a few I have added myself.
Stealing your sweet layout carleton.
The List:
Make: Dolan
Model: Forza (Frame Only)
MSRP: £899.99 (~$1360)
URL: https://www.dolan-bikes.com/Dolan-Forza-Frameset
Make: Dolan
Model: Precursa (Complete Bike) Also available as frame set
MSRP: £450 (~$658)
URL: Dolan Bikes - Dolan Pre-Cursa Track Bike
Make: Dolan
Model: TC1 (Complete Bike) Also available as frame set
MSRP: £699.99 (~$1022)
URL: Dolan Bikes - Dolan TC1 Aluminium Track Bike
Make: Dolan
Model: DF4 (Complete Bike) Also available as frame set
MSRP: £1499.99 (~$2194)
URL: Dolan Bikes - Dolan DF4 Track Bikes
Make: Felt
Model: TK1 Sprint (Frame Only)
MSRP: $4,149.00 USD
URL: Felt Bicycles
Make: Felt
Model: TK1 Endurance (Frame Only)
MSRP: $4,649.00 USD
URL: Felt Bicycles
Make: Felt
Model: TK2 (Complete Bike)
MSRP: $1,859 USD
URL: Felt Bicycles
Make: Felt
Model: TK3 (Complete Bike)
MSRP: $979 USD
URL: Felt Bicycles
Make: Planet X
Model: Pro Carbon (Frameset Only)
MSRP: $515 USD
URL: Planet X Pro Carbon Track Frameset | Planet X
Make: Planet X
Model: Track T.O.R (Frameset Only)
MSRP: £599.99 GBP ($878 USD)
URL: Planet X Track T.O.R. Frameset | Planet X
Make: Specialized
Model: Langster Pro
MSRP: $1,650
URL: https://www.specialized.com/us/en/bik...er/langsterpro
Make: Specialized
Model: Langster Pro (frameset)
MSRP: $660
URL: https://www.specialized.com/us/en/bik...terproframeset
Make: Specialized
Model: Langster
MSRP: $720
URL: https://www.specialized.com/us/en/bik...gster/langster
Make: Look
Model: 596 Track (frame only)
Price: $3,000-$7,500
URL: https://www.lookcycle.com/en/us/piste...ack-frame.html
Make: Look
Model: L96 Speed(frame only)
Price: £6999.99 ($10240 USD)
URL: Look Cycle - L96 Speed - Frames - Track
Look L96 Speed Track Frame from Velodrome Shop
Make: Look
Model: L96 Time Trial(frame only)
URL: Look Cycle - L96 TT - Frames - Track
Look L96 Time Trial Track Frame from Velodrome Shop
Make: Look
Model: Look 464
Price: £999.99 GBP ($1463 USD)
URL: Look Cycle - AL 464 P - Frames - Track
Look 464 Track Frame from Velodrome Shop
Make: Koga
Model: Kimera
Price: £1999 ($2924 USD)
URL: Koga Kimera from Velodrome Shop
Make: Cobra
Model: Cobra Track
Price: £714.99 ($1046.14 USD)
URL: Cobra Track Cycling Frameset from Velodrome Shop
Make: Fuji
Model: Track Elite
MSRP: $4749
URL: Fuji Bikes - USA Archive
Make: Fuji
Model: Track 1.1
MSRP: $1269
Make: Giant
Model: Omnium
MSRP: $1600
URL: https://www.giant-bicycles.com/en-us/...m/11492/55804/
Make: Jamis
Model: Sonic
MSRP: $1100
URL: https://www.myjamis.com/SSP%20Applica...at_grp=road_10
Make: Bianchi
Model: Super Pista
MSRP: $800
URL: https://www.bianchiusa.com/bikes/fixe...ista-frameset/
Make: Veloforma
Model: Pista Pro 2.0
MSRP: $2899.00 USD
URL: Veloforma Bicycles - Pista Pro Carbon Track Bike
Make: Bridgestone
Model: Anchor PHM9
MSRP: £2900 ($4243 USD)
URL: Bridgestone Anchor PHM9 Track Frameset from Velodrome Shop
Make: Kalavinka
MSRP: Around $2900 USD
URL: * Kalavinka * Tsukumo Cycle Sports
Make: Hoy Fiorenzuola
Model: .001
MSRP: £750 GBP ($1250 USD)
URL: HOY Fiorenzuola .001 2015 Track Bike | Evans Cycles
Model: .002
MSRP: £1300 GBP ($1902 USD)
URL: HOY Fiorenzuola .002 2015 Track Bike | Evans Cycles
Make: BMC
Model: TR02
MSRP: £2500 GBP ($3657 USD)
URL: BMC Track TR02 2014 Track Bike | Evans Cycles
Make: BMC
Model: TR01
MSRP: £5000 GBP ($7315 USD)
URL: BMC Track TR01 2015 Track Bike | Evans Cycles
Make: Raleigh
Model: Equipe
MSRP: £600 GBP ($878 USD)
URL: Raleigh Equipe 2015 Singlespeed Bike | Evans Cycles
Make: ADR
Model: Capio
MSRP: £899.99 GBP ($1316 USD)
URL: ADR Capio Track Frame | ADR Carbon
Make: Canyon
Model: V-Drome
MSRP: £1099.99 GBP
URL: https://www.canyon.com/en/roadbikes/bike.html?b=2133
Make: Dixie Flyer
Model: BTB Track
MSRP: $1999 USD
URL: Frames
Make: Mekk
Model: Pista T1
MSRP: £749.99 ($1097 USD)
URL: Wiggle | Mekk Pista T1 Aluminium 2015 | Track Bikes
Make: Mekk
Model: Pista C1
MSRP: £1399 ($2046 USD)
URL: Wiggle | Mekk Pista C1 Carbon 2015 | Track Bikes
The List:
Make: Dolan
Make: Dolan
MSRP: £450 (~$658)
Make: Dolan
Make: Dolan
Make: Felt
MSRP: $4,149.00 USD
URL: Felt Bicycles
Make: Felt
MSRP: $4,649.00 USD
URL: Felt Bicycles
Make: Felt
MSRP: $1,859 USD
URL: Felt Bicycles
Make: Felt
MSRP: $979 USD
URL: Felt Bicycles
Make: Planet X
MSRP: $515 USD
Make: Planet X
Make: Specialized
Model: Langster Pro
MSRP: $1,650
Make: Specialized
MSRP: $660
Make: Specialized
Model: Langster
MSRP: $720
Make: Look
Make: Look
Make: Look
Make: Look
Model: Look 464
Make: Koga
Model: Kimera
Make: Cobra
Model: Cobra Track
Make: Fuji
Model: Track Elite
MSRP: $4749
Make: Fuji
Model: Track 1.1
MSRP: $1269
Make: Giant
Model: Omnium
MSRP: $1600
Make: Jamis
Model: Sonic
MSRP: $1100
Make: Bianchi
Model: Super Pista
MSRP: $800
Make: Veloforma
MSRP: $2899.00 USD
Make: Bridgestone
Model: Anchor PHM9
Make: Kalavinka
Model: .001
Model: .002
Make: BMC
Model: TR02
Make: BMC
Model: TR01
Make: Raleigh
Model: Equipe
Make: ADR
Model: Capio
Make: Canyon
Model: V-Drome
MSRP: £1099.99 GBP
Make: Dixie Flyer
Model: BTB Track
MSRP: $1999 USD
URL: Frames
Make: Mekk
Model: Pista T1
Make: Mekk
Model: Pista C1
#219
Seat post slip struggle is real, but I may still attribute it to being a baby for fear of cracked carbon since it hasn't slipped since the last time I put it to the limit of what i was comfortable with.
Jury is out for me. 6ft 2, probably 210 now.
#220
Quoted: 5 Post(s)
Make: Stevens
Model: Pista
MSRP: €1299 ($1457 USD)
URL: Pista - Stevens Bikes 2015
Make: Stevens
Model: Arena
MSRP: €3499 ($3921 USD)
URL: Arena - Stevens Bikes 2015
Make: Elite
Model: Elite Carbon Track
MSRP: £2400 ($3690 USD)
URL: Elite Carbon Track bike
Make: Cinelli
Model: Vigorelli
MSRP: £849 ($1305 USD)
URL: Wiggle | Cinelli Vigorelli 2015 | Track Bikes
Make: Cinelli
Model: Mash Parallax
MSRP: £999 ($1536 USD)
URL: Wiggle | Cinelli Mash Parallax 2015 | Track Bikes
Make: Cinelli
Model: Mash Histogram
MSRP: £1729 ($2658 USD)
URL: Wiggle | Cinelli Mash Histogram 2015 | Track Bikes
Make: Cervelo
Model: T4
URL: https://www.cervelo.com/en/bikes/t-series/t4.html
Make: Pinarello
Model: Pista
URL: https://www.pinarello.com/en/bike-2015/track/pista
Make: Pinarello
Model: XTRACK
URL: https://www.pinarello.com/en/bike-2015/track/xtrack
Make: Pinarello
Model: MAAT 60.1
URL: https://www.pinarello.com/en/bike-2015/track/maat-60.1
Make: Boardman
Model: TK Pro
MSRP: £800 ($1235 USD)
URL: https://www.halfords.com/cycling/bike...-pro-road-bike
Make: Ritte
Model: 8055 Track
URL: https://rittecycles.com/the-8055-track/
Make: 7VRN
Model: 7VRN Carbon Track
MSRP: £849 ($1311 USD)
URL: https://www.brookscycles.co.uk/velodr...k-frame-2.html
Make: Condor
Model: Lavoro
MSRP: £599 ($925 USD)
URL: https://www.condorcycles.com/Single-S...ypage.tpl.html
Make: Moda
Model: Arco
MSRP: £1199 ($1851 USD)
URL: https://www.moda-bikes.com/portfolioentry/arco/
Make: Moda
Model: Senza
MSRP: £1999 ($3087 USD)
URL: https://www.moda-bikes.com/portfolioentry/senza/
Make: Moda
Model: Forte
MSRP: £999 ($1542 USD)
URL: https://www.moda-bikes.com/portfolioentry/forte/
Make: Moda
Model: Fresco
MSRP: £749 ($1156 USD)
URL: https://www.moda-bikes.com/portfolioentry/fresco/
Make: Trigon
Model: TTAA01
MSRP: £899 ($1388 USD)
URL: https://www.trigon-cycles.co.uk/trigon-ttaa01-track-bike
Make: Ponero
Model: Track
URL: https://www.ponero-bikes.com/track_bike
Make: Basso
Model: Pista
URL: https://www.bassobikes.com/en-UK/pista.php
Make: Argon 18
Model: Electron Pro
URL: https://www.argon18bike.com/bikes/tra...ctron-pro.html
Make: Argon 18
Model: Electron
URL: https://www.argon18bike.com/bikes/track/electron.html
Model: Pista
Make: Stevens
Model: Arena
Make: Elite
Make: Cinelli
Model: Vigorelli
Make: Cinelli
Make: Cinelli
Make: Cervelo
Model: T4
Make: Pinarello
Model: Pista
Make: Pinarello
Model: XTRACK
Make: Pinarello
Model: MAAT 60.1
Make: Boardman
Model: TK Pro
Make: Ritte
Model: 8055 Track
Make: 7VRN
Make: Condor
Model: Lavoro
Make: Moda
Model: Arco
Make: Moda
Model: Senza
Make: Moda
Model: Forte
Make: Moda
Model: Fresco
Make: Trigon
Model: TTAA01
Make: Ponero
Model: Track
Make: Basso
Model: Pista
Make: Argon 18
Model: Electron Pro
Make: Argon 18
Model: Electron
#221
Good news for bigger guys in the market for a new bike:
"The 60cm and 62cm BTB are designed and ready for development! Some additions have been made to accommodate for bigger humans. Larger diameter top tube and taller seat tube boom. BRING YOUR POWER! If you are interested, please contact us. We will need some pre-orders, seed money, or whatever to make these two frame sizes a reality. Along with these two sizes, AND our very exciting MINIE-DIXIE (in development too 3D pics soon) our BTB track line will be complete!!!"
[From Dixie Flyer Facebook page]
Dixie Flyer Bicycles
#222
Elitist
Liked 92 Times
#223
Lapped 3x
#224
Bikes: T1, S2, P3
Quoted: 5 Post(s)
The 60 specs look nice, and the price is right (although the exchange rate these days sucks)
Im sure there is something posted already, but could someone give me some feedback on the BTB frameset? Or perhaps the experience of buying from Dixie?
#225
I don't own one of these, but am a friend of Bobby. He is fully rolling on production now so bikes can be had quickly. Up until early this season he was still sorting out that side of things and there were some delays.
As far as the bikes themselves, it seems like everyone loves them and I'm not aware of there being any issues (like weird seat post slippage, etc). They are basically the track bike of reference at Hellyer these days, and catching on elsewhere too.
