Stiffness Does Not Matter
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
There's a meme (in the original sense of the word, a unit of cultural heredity, not the modern stupid-picture-of-a-cat-with-a-stupid-saying-in-white-letters sense,) that has been replicating in the brains of humans who ride bicycles for many, many years... and it's nonsense.
That meme is this:
Flex in the bicycle dissipates some fraction of the force generated by the rider's muscles.
This is simply, physically, not true. The thing that it's describing does not actually happen. Numerous attempts have been made to measure this "power loss." So far as I'm aware, nobody has ever been able to repeatably detect any power loss due to bicycle flex that is above the noise floor of the equipment used to do the measuring.
And, because the meme isn't actually true, this statement is true:
Unless the bicycle and/or its components are so flexible as to have negative effects on handling, alignment, or durability, the stiffness of any part of the bicycle or the bicycle as a whole is utterly irrelevant to the performance of the bicycle.
Stop caring about the stiffness of your frame, cranks, wheels, stem, handlebar, pedals, brake levers, (yes, I've seen stiffness referred to in brake lever reviews,) or any other part of your bicycle with the possible exception of racks. (And even they're not much of an exception... any rack strong enough for the load you're putting on it will be stiff enough for that load... if it wasn't, it'd break.)
Stiffness does not matter.
--Shannon
That meme is this:
--Shannon
The phrase 'laterally stiff and vertically compliant' is rightfully made fun of, given how often it is used in marketing, but its legit.
I have never heard someone say 'man, I wish this bike twisted more when I pedal' because that isnt a thing.
Old fart
Quoted: 3582 Post(s)
Liked 3,395 Times
In general, the benefit of "stiffness" in a bicycle increases with rider weight and decreases with road/trail roughness. A heavy rider on smooth pavement gets the most benefit from a stiff bicycle; a light rider on rough pavement, the least.
Likes For JohnDThompson:
52psi
Quoted: 790 Post(s)
Liked 801 Times
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 564 Times
Experienced plenty of, um, noise / vibration / harshness when we were growing up, riding in the fields. More vibration when barreling down the bluffs to the jump we'd made at the bottom ... but more harshness when landing over the tracks and in the cactus patch on the other side. (Heavy or light didn't seem to matter, picking ourselves up from the cactus patch. But, boy! were we stiff ... )
Quoted: 1065 Post(s)
Liked 780 Times
r.e. -- droopy , might also need to consider a possible Peyronie's disease syndrome when extrapolating.
Randomhead
Liked 3,686 Times
I know it's invited by the OP, but could we just avoid the obvious juvenile double entendres for once?
Quoted: 1943 Post(s)
Liked 2,164 Times
It’s pretty easy…
The more flexible you are, the less flexible your bike needs to be.
The less flexible you are, the more flexible your bike needs to be.
Some mornings I wish I had a Vitus.
John
John
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 463 Post(s)
Liked 546 Times
The OP is speaking of force which is played into an undamped spring and which is overwhelmingly played back.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
I look forward to OP's new bike made of pad thai
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Quoted: 2599 Post(s)
Liked 1,924 Times
Likes For pdlamb:
I call BS. Frame flex matters a great deal for my recumbents. My stiffest bent is also the best climber of the bunch, likewise my flexiest one is the worst climber. (Climbing relies less on aerodynamics and more on power input.) Even if we're talking about traditional 'double diamond' frames, there is a difference. Power lost deforming the frame is never recovered for propulsion.
Likes For BlazingPedals:
Disco Infiltrator
Liked 2,102 Times
Not their money, no, but they’ll keep us wasting ours as long as people on the Internet tell other people on the Internet that suspension forks are “inefficient”
Genesis 49:16-17
Genesis 49:16-17
With a mighty wind
Quoted: 1086 Post(s)
Liked 858 Times
So really, this is just another “my saddle makes my junk go numb” thread.
There are a few suggestions to add to the quality here.
-Sildenafil has shown promise among high altitude mountaineers and theoretically could be helpful as a performance enhancing drug for endurance athletes.
-Has anyone ever experienced the unexpected diamond cutter when waking the nethers back up? My current seats don’t cause this but I have experienced it in the past.
Carry on
Carry on
Quoted: 2281 Post(s)
Liked 1,710 Times
Seriously, I'm no physics expert, but it's only logical that if the exertion you're putting into moving your bike across the ground is also causing some flex in the frame, then part of your effort is wasted in bending the frame back & forth. Or, the frame is absorbing some of the force instead of putting it fully into the pedals. I'm sure someone might show some science to prove me wrong, so have at it...
Quoted: 1218 Post(s)
Liked 298 Times
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Likes For cxwrench:
Quoted: 1273 Post(s)
Liked 1,384 Times
it would be pretty surprising if the difference between a noodly frame and a worlds-stiffest would be measurable, or above the margin of error of the experiment. but it would probably feel totally different to the rider, which is what’s actually important for most of us.
ri alene
Quoted: 51 Post(s)
Liked 60 Times
Here’s a good video covering stiffness and Young’s Modulus, he shows some good modeling and decent figures also mentions some studies.
Further reading about bike engineering, and materials analysis in some studies about frame types, geometries, and materials specifically referencing FEA (which is method for numerically solving differential equations arising in engineering and mathematical modeling)
Enjoy.
Derek Covilla, 2014. “Parametric finite element analysis of bicycle frame geometries”, the conference of the International Sports Engineering Association 2014, Elsevier Procedia Engineering 72 (2014) 441 – 446
Bharati A. Tayade, 2015. “A study on structural health of bicycle frame using Finite Element Analysis”, International Journal of Innovative and Emerging Research in Engineering Volume 2, Issue 4
Joachim Vanwalleghema, 2014. “Development of a multi- directional rating test method for bicycle stiffness”, the conference of the International Sports Engineering Association, 2014, Elsevier Procedia Engineering 72 (2014) 321 – 326
M.A. Maleque, 2010. “Materials Selection Of A Bicycle Frame Using Cost Per Unit Property And Digital Logic Methods”, International Journal Of Mechanical And Materials Engineering (Ijmme), Vol.5, No. 1, 95-100
M.V.Pazare, 2014. “Stress analysis of bicycle frame”, International Journal of Engineering Science and Technology (IJEST), ISSN: 0975=5462, vol. 6, No. 6
Aparna Deshpande, 2016. “Design and Optimization of Bicycle Frame for the Cyclist's Comfort”, International Journal on Recent and Innovation Trends in Computing and Communication, ISSN: 2321-8169, Volume: 4 Issue: 5 220 – 224
Enjoy.
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,855 Times
Likes For genejockey:
Quoted: 12 Post(s)
Well, a bicycle that wiggles on turn-in has a weak frame but the poster allowed for that.
Now, aluminum that flexs then cracks. So aluminum is used in larger cross-sections than steel. Allowing for the larger cross-sections then the weight advantage of aluminum over steel is only about 5%. However, current aluminum frames have smaller cross-sections than the original aluminum frames. Now the forks can be carbon-fiber and that helps.
Presently, carbon-fiber frames often have seat or handlebar compliance systems.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I thought the current theory is that a flexy frame doesn't keep the rear wheel inline with the frame during hammer time, and that is a source of energy waste.
Quoted: 3942 Post(s)
Liked 7,284 Times
Liked 7,284 Times
Even if all the energy that goes into flexing the frame is returned, it may not be returned in a way that propels the bike forward. You have to look at the whole system and where the losses are.
Likes For tomato coupe:
