Cycliq Fly6 - LED flashes blue - what does it mean?
I've purchased a Fly6 from Cycliq some months ago and it worked just fine until Sunday when I did a long ride in the rain. At the last break (it had stopped raining) I wasn't able to switch the device off. The red LEDs flashed erraticelly. The buttons didn't respond anymore. After getting home and reading the SD I found out that it recorded just fine until the break but then (probably when I tried to switch it off) only produced ten consecutive photos and then stopped recording. I suppose it got wet since I could see water inside the lens. Anybody has had this too or something similar and can explain?
Now, after two days, no change: Both reset options don't work, and the LED flases blue every three seconds. No reaction whatsoever.
Quoted: 6193 Post(s)
Liked 4,808 Times
I would think it means you need to ask Cycliq what to do and if your warranty covers anything that might be wrong. Still got the sales receipt or did you register it with them?
You might assume it got wet inside something and put it in a bag of rice or a better desiccant and hope for the best.
Likes For Iride01:
