New STI rubber hoods - fitting?
Old 09-20-21, 01:41 AM
tomgdaly
The Crank
tomgdaly's Avatar
Bikes: I think it's six at the moment, ranging from a Scott Foil to a 1979 TI Raleigh Team Edition
Quoted: 19 Post(s)
Liked 4 Times in 3 Posts
I have replaced the rubber hoods on my Shimano R8020 STIs. However, they seem to remain loose and twist outwards. On the righ-hand side, this seems to lock the little lever that low down on the inboard side, and I have to press it back back to shift.
Am I missing something - is there some method of making them 'stick' or snug?
tomgdaly is offline
Old 09-20-21, 07:56 AM
Iride01
Iride01's Avatar
Quoted: 6193 Post(s)
Liked 4,808 Times in 3,316 Posts
Are they made by Shimano? Though I don't know that I've ever seen Shimano replacements. But I've never had to replace a hood.
Are they specifically for your model and version of STI? I'd think left and right might make a difference, did you mix that up?
Iride01 is offline
Old 09-20-21, 08:04 AM
Crankycrank
Quoted: 836 Post(s)
Liked 1,061 Times in 745 Posts
I don't know for your R8020's but all Shimano hoods I've seen have little nubs on the inside that lock onto the lever body and hold the hood in place. Check the insides of yours and look for matching attachment spots on the bodies.
Crankycrank is offline
Likes For Crankycrank:
Old 09-20-21, 08:46 AM
mikeymichaels
Bonking Enthusiast
mikeymichaels's Avatar
Liked 32 Times in 12 Posts
If you’ve purchased and installed the correct replacement hoods, it may just take some precise massaging to get the hoods to line up perfectly onto the shifter and get all the little nubs lined up.
mikeymichaels is offline
Old 09-20-21, 09:37 AM
tomgdaly
The Crank
tomgdaly's Avatar
Quoted: 19 Post(s)
Thanks - I hadn't notice those 'nubs' and the bar-tape would have prevented one of them from engaging. That should help.
tomgdaly is offline
Likes For tomgdaly:
