Weekly Wedge Issue: Wind Chill is Pointless
meh
Bikes: 21 CoMotion Java; 21 Bianchi Infinito; 17 Breezer Radar Pro; 15 Surly Pugsley; 13 Felt Z85; 11 Globe Daily; 09 Kona Dew Drop; 96 Mondonico
Quoted: 1083 Post(s)
Liked 974 Times
This week's Wedge Issue: Wind Chill Factor is Pointless
Wind chill factor is great for The Weather Channel to hype cold temps and create drama, but it has very little effect when your riding a bike ... unless you're a nudist.
Here's the challenge for those that want to argue for wind chill: With the air temp is 35F/1.5C and the wind is 20 mph/32kph making the wind chill 24F/-5C, you put a glass of tap water on the patio table ... will the water in that glass freeze?
SPOILER ALERT! No, the water will not freeze until the air temp is below 32F/0C.
For rides when it's cold and windy, simply include a wind blocking layer and dress the same as you would for the air temp. Wind chill is about the lose of heat from exposed skin, and I don't know anybody going out with exposed skin when temps are cold enough to consider wind chill.
For reference, yesterday I rode for 90+ minutes with air temp at 0F/ and 6 mph winds, making the wind chill factor -12F/-25C. I dressed for the conditions, and a wind block layer is part of my winter kit any time the temps are below 45F/8C, regardless of the wind speeds (or wind chill factor) because riding a bike is creating a constant 10-20 mph (16-32 kpm) wind.
Likes For Hypno Toad:
Quoted: 4985 Post(s)
Liked 3,111 Times
I agree!
nice new winter photo, but why are you smiling ...? (JK totally rhetorical)
Likes For rumrunn6:
meh
Liked 974 Times
Newbie racer
Bikes: Propel, red is faster
Quoted: 1566 Post(s)
Liked 1,539 Times
It is something I'd pay attention to when I do my lunch runs at work though. Eastern NC can be windy. A run at 35 deg and not much wind is shorts and a long sleeve t-shirt, no hat. A run at 35 deg and solid wind changes things. Hat, gloves, run tights, then depends on run pace the amount of layer/blocking happens on the upper body.
But on the bike, yes. Obviously given the constant drone of wind it's different. Especially different though when I ride slow hilly gravel in winter or take the TT bike out for a roll. That's a delta of nearly 10mph in average pace between the two. So I dress differently there also. Even 50 deg F on the TT bike can feel quite chilly if not well prepared.
Bikes: ...a few.
Quoted: 1988 Post(s)
Liked 388 Times
I agree that windchill on a bike is less relevant. If I you're riding with a tail wind then it negates the windchill factor. However, the wind still works to take heat away from your body even if you are wearing a wind-blocking outer layer. So riding into a headwind you're getting a double dose of windchill. But wind is more of a factor in how hard your riding is going to be.
Likes For mcours2006:
Liked 3,111 Times
Likes For rumrunn6:
Bikes: Cannondale '92 T600 '95 H600 '01 RT1000
Quoted: 70 Post(s)
Liked 74 Times
The wind does make a difference even if you're dressed appropriately, but not as much of an impact as if on bare skin. If you light up a thermal camera while fully dressed, the wind will suck heat away faster than on a calm day. Plus, if your clothing isn't taped together/nice and tight where stuff meets, like my wardrobe, there'll be a little more breeze on the inside. That does help keep the inner stuff a little drier though, so it's not all bad.
But I may not be qualified to speak. I only made it 80+ minutes yesterday in the same conditions.
I had a fender mount give way and after 100 feet of listening to the studs whir on the fender, I managed to temporarily jam the fender into an acceptable position that I wasn't sure was going to hold for the rest of the ride. It did, and new holes and zip ties have been added to that old fender for today's ride. It's a balmy 10F but that wind is gusting past 25mph. I'd take yesterday's 2F and 5mph wind over that...
Likes For MNBikeCommuter:
meh
Liked 974 Times
One problem with wind chill in freezing conditions is you can't stop. If you do, the wind will suck the heat out of you in seconds.
Likes For Thulsadoom:
Sr Member on Sr bikes
Dan
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
Trust me, wind makes a difference. Say I am comfortable at 15°f wearing similar head attire as your photo, ie: glasses, skull cap, helmet, fleece gaiter. I am fine with this attire if the wind is not blowing hard. Take the same exact riding conditions, and factor in a steady 20-25 mph wind and now life is miserable from the neck up. In these windy conditions, I now need a full balaclava head covering and goggles to keep my eyelashes from freezing shut, where as at the same temp and calm conditions, I was perfectly happy with exposed skin.
Drop the temp further, say -10°f. I can usually make my daily commute in these temps using my standard layering of mittens. Throw in a 20 mph headwind at these temps, and now we have to add chemical warmers to keep my fingers and thumbs from losing too much heat before my commute is finished. I would not necessarily want these adjustments without the wind, however, as it would be too easy to start sweating when my hands get too warm, and sweaty mittens can be a recipe for severe discomfort.
I will agree that for some, a windbreaker can solve issues on the torso and legs in windy conditions (although in my experience, this area never gets all that cold anyway, even in windy conditions - with the exception of the crotch), but the extremities will still need to be addressed accordingly to compensate for wind at lower temps.
Likes For SalsaShark:
Quoted: 886 Post(s)
Liked 419 Times
Wind chill is always good for bragging rights!
Likes For sweeks:
meh
Liked 974 Times
meh
Liked 974 Times
That said, wind is a very low priority when dressing for my daily winter rides. After air temp, it's sky conditions that are the next priority, sun versus cloudy or night. Snow plays a role too, but that's more an issue of how "fast" I can get where I'm going ... Unless temps are near freezing and I could end up getting wet. The wind, like snow, slows me down and taking longer to get where I'm going, but no real change in my clothing.
45NRTH Naughtvind shell pant are great alone at warmer temps and layered over wool bibs for colder temps. On the top I love my Podiumwear Arrowhead jacket and for the the wind and colder temps, I layer their wind vest under the jacket
To the point of a mechanical, working with bare hands ... that's exposed skin, and that's when wind chill is a factor. My winter tools include chemical hand warmers and light gloves. Trust me, 10+ years of winter riding, I've had my mechanical issues and know how to manage them.
Quoted: 166 Post(s)
Liked 248 Times
Bikes: 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 3561 Post(s)
Liked 2,535 Times
Well, the other thing is how some people use wind chill (or "feels like") temperature to measure the conditions of their ride, when it's just not comparable.
Sorry, "it felt like -18 °F with the wind chill" is not the same as riding in air temperature of -18 °F.
And on a moving bike, the first statement is meaningless.
So there are two issues really - does wind or moving air speed affect heat loss, particularly from exposed skin? Yes. For a moving cyclist, is that effective temperature that you look up on your weather app meaningful? No.
Likes For MinnMan:
meh
Liked 974 Times
From a detailed history of why wind chill is useless:
... assumptions to determine wind-chill-equivalent temperatures. Namely, they geared their calculations toward people who are 5 feet tall, somewhat portly, and walk at an even clip directly into the wind. They also left out crucial variables that have an important effect on how we experience the weather, like solar radiation. Direct sunlight can make us feel 10 to 15 degrees warmer, even on a frigid winter day. The wind chill equivalent temperature, though, assumes that we’re taking a stroll in the dead of night.
Wind Chill BlowsIt’s time to get rid of a meaningless number.
https://slate-com.cdn.ampproject.org...e-useless.html
don't try this at home.
Quoted: 860 Post(s)
Liked 292 Times
I stepped outside this morning at 10F, 1-2 mph winds. "Feels like 10F". It didn't feel extremely cold.
It's rare to have the winds this calm when it's cold, so just about any cold day includes a bunch of wind chill. That's what most people remember when they are trying to compare temperatures on different days.
I don't ride much below 40F. But even at 40, I dress differently if the winds are 2-4 mph vs 12-15 mph. The brief stops are much colder, climbs are colder, and it probably affects flat road riding, too.
Sunny
It's mostly cloudy here in the winter. My rule of thumb is "8 degrees warmer" on a bright sunny day. That usually works very well for picking layers to wear.
Sunny
Quoted: 2048 Post(s)
Liked 1,709 Times
Heat loss depends on many factors. Outside temperature, Cloud cover, relative humidity, manner of dress, metabolic efficiency of the rider, power output of the rider, cold adaptation of the rider, and yes.....apparent wind speed.
Likes For GhostRider62:
meh
Liked 974 Times
From the linked article:
The language of “equivalent temperatures” creates a fundamental misconception about what wind chill really means. It doesn’t tell you how cold your skin will get; that’s determined by air temperature alone. Wind chill just tells you the rate at which your skin will reach the air temperature. If it were 35 degrees outside with a wind chill of 25, you might think you’re in danger of getting frostbite. But your skin can freeze only if the air temperature is below freezing. At a real temperature of 35 degrees, you’ll never get frostbite no matter how long you stand outside. And despite a popular misconception, a below-32 wind chill can’t freeze our pipes or car radiators by itself, either.
I'll add, once temps are around 20F, my wind blocking layers do not change ... even at temps down to -30F. One wind blocking layer is all you need, OTOH the layers of wool will increase as the mercury falls.
I've been riding a bunch of days this month where in the morning its been -25c and a bit of wind, so feels like -35c+ and using my downhill skiing goggles and even my ski helmet makes a real difference. Ski goggle makes a real difference for not having my eyes water all over the place and keeps some of my old face from freezing too.
And have thrown another wind breaker layer on my legs (old rain pants) and my legs are ok.
I dunno, I find wind chill to make a real difference, but I'm a skinny old guy, so I just add some layers and specifically wind blocking stuff that makes all the difference.
Tightly woven wind block layers bring up the issue of moisture transfer.
Likes For djb:
meh
Liked 974 Times
It's not cheap, but quality materials are good at blocking the wind and venting humidity. Well designed bike specific wind blocking layers have venting panels on the back side of the article of clothing where there's no wind. Additionally, well designed wind block layers include adjustable venting to dump heat when the body warms up. I'm a big fan of Podiumwear, 45NRTH, and Pearl Izumi AmFIB winter gear.
I'll repeat what I've said in earlier posts: while riding a bike, you're creating a 10-20mph wind; therefore, when air temps are cold enough to consider wind chill, wear a wind blocking layer regardless of the wind speed. One quality wind blocking layer is all you need, and adjust the layers of wool for the air temp.
