Go Back  Bike Forums > Bike Forums > Recumbent
Considering Upgrading to a Different eTrike?
Recumbent What IS that thing?! Recumbents may be odd looking, but they have many advantages over a "wedgie" bicycle. Discuss the in's and out's recumbent lifestyle in the recumbent forum.
Old 08-01-22, 01:57 PM
newbert
Quoted: 47 Post(s)
Liked 17 Times in 16 Posts
I've only been triking since early this spring,and find that I love it even more than I expected. It also helps that it's a fun way to get exercise, which has been prescribed for me to deal with a few health issues.
That said -- I have a Catrike Villager with a cadence-based e-motor and throttle. TBH, while shopping for it, my first trike, I didn't take the time to test ride multiple models/configurations because I was "hot to trot" but had no experience to compare it to. Now I'm wondering that I may have "jumped in" too soon because I don't even know what I might be missing compared to other trikes. So I already have the itch to test ride other models but have a few questions.
NOTE: For sake of argument, let's not consider budget for now:
First, are there any eTrikes that have both a torque-based motor and a throttle override? I've been told that torque-based is a more "natural" feeling than cadence-based, but I do like to have a throttle available for emergency situations.
Second, I have far from the smoothest or consistent pedal stroke, so would "torque-based" be better for me? I plan to test ride a torque-based system,but figured that I would also ask here.
Finally, are bike/trike shops generally open to "trade-ins" of (slightly) used trikes?
I'm sure that I'll have other questions, but that's all that comes to mind now.
Any thoughts on these questions would be greatly appreciated!
Bert
newbert is offline
Old 08-02-22, 09:31 AM
linberl
linberl's Avatar
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times in 288 Posts
I'm not super familiar with the Catrike model but have you considered whether it makes sense financially to just replace the e-assist system? I'm sure you can get a cadence based mid-drive system installed pretty easily. You might be able to sell your existing e-assist components to offset the cost of a new system. That's assuming you like the trike itself and the way it rides.
linberl is offline
Old 08-02-22, 09:42 AM
newbert
Quoted: 47 Post(s)
That's a good thought, linberl - Thanks!
But to clarify - I'm considering a switch away from cadence-based to torque-based. If it's possible, would that make sense for me? And do torque-based symptoms also have a throttle? (FWIW, the one offered by my LBS at time of trike purchase did not.)
Thanks again.
newbert is offline
Old 08-02-22, 10:42 AM
linberl
linberl's Avatar
Thanks again.
I mistyped - meant to say torque, not cadence. this one has very good reviews - you can buy thru Amazon or thru several ebike/trike shops. Universal Retrofitting Torque Sensi - Eco Cycles. Has a throttle option as well.
linberl is offline
Old 08-02-22, 11:33 AM
VegasTriker
Quoted: 522 Post(s)
Liked 227 Times in 179 Posts
What exactly were you looking for in a trike when you first went to test ride them? Did you purchase the Catrike Villager e-version (eCAT) with the Bosch e-assist?
I'm not a user of e-assist on my Catrike 700 so what I say here comes from looking at the Catrike website. First, the Villager was designed as a high seating trike for those who can not get up out of a low seating trike. The big sacrifice I see with going to the eCAT is a great reduction in the gear range. The standard Villager with 20" drive wheel, 30/39/52 chainring, and 10 speed 11/36 cassette has a 15.9 to90.1 gear inch range. The eCAT has a single 44 tooth chainring and a wider range 11//42 tooth cassette. The specs do not list a gear range but you can calculate one at https://www.sheldonbrown.com/gear-calc.html. It is going to be different and with many fewer choices to get a comfortable cadence. I guess the electric motor makes up for that. The standard villager with shipping is $2825. The eCAT is $5,500 with shipping. It is definitely not an entry level trike. Unfortunately shipping a trike is not cheap, especially as an individual rather than as a business. That means you will probably be looking for a local buyer. The more expensive the trike, the harder it is to resell. Second owners don't get a warranty so getting back what you put in to it will not be likely. Test riding other models is a great idea. Don't feel bad about maybe not getting the right trike on the first try. I bought an expensive trike (at the time) from a well known manufacturer and realized after a few months that it was a big and costly mistake. The second trike, a used Greenspeed GTO, was exactly what I wanted and needed. I used it for 9 years and many thousands of miles. Live and learn.
VegasTriker is offline
Old 08-04-22, 10:16 AM
newbert
Quoted: 47 Post(s)
Well, to answer your questions: I was pretty sure that I would do a lot of triking when I was shopping for my first trike. I definitely wanted e-assist because I live in a pretty hilly area. Didn't want to sit too low because of the start of some mobility issues. (Exercise was prescribed for me and triking seemed to fit the bill nicely since I have some mild balance issues.) All-in-all, the Villager has met my needs, but perhaps not all my wants (which I didn't know Iad).. My choice of e-assist at the trike shop was Bosch or eBikeKit. Thet are very different. As you said, with Bosch you lose some gearing, there's no throttle, and it was quite a bit more expensive. With eBikeKit, the motor is on the rear hub and I retained all of my gearing and got a throttle and saved some $$$.
AFter buying the Villager, I read about torque-based e-motors and thought that might be better for someone like me who was an inconsistent, less-than-smooth pedal stroke. With the cadence based eBikeKit, I just often find myself between gears and power levels. So I thought that a torque-based motor might be better for me. Is my assumption correct?
Another option I'm considering is changing out the front gearing to something larger. I'm finding that I'm almost always in the largest front gear and only occasionally in the middle gear. I never use the smallest gear. - But I'll leave my specific questions about gearing in a separate thread.
Thanks for your thoughts.
newbert is offline
Likes For newbert:
