Shimano Dura-Ace 9 Speed Replacement
I have a 2001 Lemond with a rear cassette CS-7700 that I believe needs replacing. Obviously can’t find a new one of these. Is there a good new replacement I could use without changing my other components?
Any help would really be appreciated!
Bikes: Cannondale - Gary Fisher - Litespeed - Schwinn Paramount - Schwinn (lugged steel) - Trek OCLV
Quoted: 668 Post(s)
Liked 624 Times
a number of CS7700 cassettes are currently listed on eBay - including a few new
but don't know if they are the exact cassette you are looking for
a 9 spd Ultegra cassette should also work ... possibly 9 spd XT cassette also
there are some other Shimano compatible replacements that I'm not familiar with ... ? ... Sunrace ? ... Miche ? ...
don't forget to also get a new chain
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 196 Post(s)
Liked 110 Times
Any Shimano compatible 9 speed cassette - Shimano, SRAM, Sunrace, Microshift, IRD, ...
If the largest cog is not bigger than what you have now you should be good, otherwise you may need a longer chain.
OTOH it is a good idea to install a new chain with a new cassette, then you can size the new chain correctly. You will need to check that the RD can handle it (chain wrap capacity and the largest cog).
Likes For csport:
Really Old Senior Member
Largest cog is rated @ 27T You "might" be able to exceed that by a couple teeth??
Quoted: 442 Post(s)
Liked 96 Times
What ratios do you currently have? Getting a 9-speed cassette with just about any ratio should be easy, but not at Dura Ace level, as long as you can take a lower spec, it should be easy to find
Likes For jimc101:
Thank you all for this information. Very helpful. I have a 12-23 cog and also did just put on a new chain. I will check out the eBay suggestions and others. Thank you again!
Quoted: 1805 Post(s)
Liked 1,359 Times
I got two NOS Dura Ace 7700 cassettes from eBay within the last year. They're definitely available, sometimes even for a good price. 12-23 and 12-25.
Liked 1,359 Times
"NOS" means "New Old Stock." A new item, usually in the box, never used, that's been sitting on a shelf somewhere or in someone's closet.
FWIW, I paid $100 for my 12-23 and $157 for my 12-25.
You can filter eBay to show only "sold items," which should give you an idea of what other similar items are selling for.
Clark W. Griswold
Quoted: 3550 Post(s)
Liked 2,874 Times
Probably would just buy a 9 speed cassette in the right ratio? Nothing special about the Dura Ace Cassette or chain other than maybe being lighter or having a bit more titanium cogs loads of cassettes on the market you just need to match what you have and make sure it is s-group compatible.
Likes For veganbikes:
Liked 1,359 Times
Sure, you’ll pay a premium for DA. But that “lightness” and “more titanium” is worth every penny for many of us! It is in fact what does make DA “special.”
Clark W. Griswold
Liked 2,874 Times
Sure but in terms of a cassette it is another cassette so long as the ratios are correct. Yes Dura-Ace is the top of the line for Shimano and really great stuff but in the context of the question being asked it is just a cassette.
Thanks all again. By replacing my chain (was confirmed stretched by my Park measuring tool) with a new Shimano chain my shifting is actually back to perfect! No new cassette required! However I am toying with taking the cassette up to a 12-30. Is that doable within the specs of the 7700 group I have?
Quoted: 1973 Post(s)
Liked 984 Times
As noted above, the maximum Shimano speced cog is 27T but Shimano is pretty conservative with specifications their so going to 30T may work but there is no guarantee it will. You will probably have to adjust the "B-screw" to clear the largest cog and are likely to need to add a few chain links if going from a 23T largest cog.
Also, any Shimano or Shimano compatible 9-speed cassette will work. Shimano Dura Ace, Ultegra, 105, Tiagra, and SRAM 9-speed will all be fine
Quoted: 1579 Post(s)
Liked 1,281 Times
I use a 28 tooth large cog cassette on my 7700 bike no problem.
edit: more info— 53/39 Cranks.
Quoted: 1815 Post(s)
Liked 1,960 Times
Going to a 30t is dependent on the derailleur hanger and the B screw. Some bikes will allow a push to 30t and some won't.
If you go with a 12-30 and have a 52/42, or other 10t difference crank, you will have a chain wrap of 28t and will be within the RD's max of 29t. If you are running a 53/39 crankset, you might ("probably") be able to push it to 32t chain wrap.
John
SE Wis
Quoted: 2406 Post(s)
Liked 2,738 Times
And your Derailleur probably won't work with a 30 t 1st gear cassette. Is the Der. a "short cage"? if so, a 27 is just about max. The front Chainring combo info will also be required for anyone to make the call for you here...
Liked 1,359 Times
You’re allowed to say your chain stretched. We (well, most of us) know what you mean.
You can also call a sprocket a cog, or call a seat a saddle, or a saddle a seat.
