Can a Huret Jubile front derailleur shift a triple crank?
Old 11-25-22, 02:22 PM
cstar
Quoted: 26 Post(s)
Liked 41 Times in 14 Posts
Assuming I use the minimum possible spindle length, is a Hurry Jubile front derailleur capable of shifting across a triple crankset? I wasn't sure if it had enough swing.
I have one I could try out but before I go disassembling two bikes to try it I just thought I'd see if anyone has done it successfully.
Thanks
cstar is offline
Old 11-25-22, 02:25 PM
52telecaster
ambulatory senior
52telecaster's Avatar
Quoted: 1692 Post(s)
Liked 2,485 Times in 1,196 Posts
I used one that way for a while. I can't remember if it was near it's limit. It did seem pretty flimsy, which is why I don't use it now. Old suntours work better for half step and granny.
52telecaster is offline
Likes For 52telecaster:
Old 11-25-22, 03:01 PM
juvela
juvela's Avatar
Quoted: 3179 Post(s)
Liked 2,038 Times in 1,425 Posts
alignment of cage to chainwheels is particularly critical as gear mech less robust than some others...
juvela is offline
Likes For juvela:
Old 11-25-22, 03:03 PM
52telecaster
ambulatory senior
alignment of cage to chainwheels is particularly critical and gear mech less robust than some others...
I concur!
Old 11-25-22, 05:03 PM
obrentharris
obrentharris's Avatar
Bikes: Indeed!
Quoted: 1297 Post(s)
Liked 2,622 Times in 876 Posts
Some would say it can't even shift a double... for long!
Brent
obrentharris is online now
Likes For obrentharris:
Old 11-25-22, 07:14 PM
gugie
Bike Butcher of Portland
gugie's Avatar
Bikes: It's complicated.
Quoted: 4336 Post(s)
Liked 4,428 Times in 1,881 Posts
Get a Duopar if you want to stay French
The front of the cage is stiffer than a Jubilee
I have one on my Eroica bike, shifts a triple fine
gugie is offline
Likes For gugie:
Old 11-25-22, 09:04 PM
bbbob
Bikes: Bianco porteur
Quoted: 54 Post(s)
Liked 104 Times in 46 Posts
Huret made a triple specific jubilee also.
bbbob is offline
Likes For bbbob:
Old 11-26-22, 06:15 AM
smontanaro
Bikes: many
Quoted: 1229 Post(s)
Liked 1,012 Times in 560 Posts
Jubilee front derailleurs frequently cracked at the pivot pins. I wonder if they were made for metric and English seat tube diameters. (Seems likely.) If so, installing a metric derailleur on an English seat tube would likely hasten its demise. Worth investigating before mounting it.
Contact me about helping Doug Fattic's Ukraine Bicycle Project
smontanaro is offline
Old 11-26-22, 09:06 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3245 Post(s)
Liked 2,648 Times in 1,539 Posts
The Jubilee front was initially spec'ed for the Trek 720 loaded touring bike, with a triple crank. It works fine with that, but Trek eventually chaged the spec to a Huret Success front or Simplex Super LJ, not because the Jubilee couldn't handle the triple, but because too many of the clamps were breaking on the assembly line.
If you do decide to use the Jubilee front, be careful when mounting it, to prevent breaking the clamp.
JohnDThompson is offline
Likes For JohnDThompson:
