Cinelli 1R Stem
Total Scrounge
Bikes: 71 International 72 Super Course 83 Gap
Quoted: 327 Post(s)
Liked 924 Times
Cinelli 1R Stem
This is a complete Cinelli 1R stem with a few scuffs and gouges. Stamped 105, which I assume indicates that it is about 4" long. Top of clamp shows anodizing worn off a bit, and there are a few gouges up high on the insertion area, but hey, the wedge clamp is there!
How about $40 shipped in the CONUS?
Thanks!
Thanks!
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
Thanks to merziac for noticing that the top of the wedge thingy is broken off! I hadn't spotted it. One of many learning experiences around here! It seems this stem is not complete, and in this case, no longer for sale.
Quoted: 4494 Post(s)
Liked 6,300 Times
DOH!
It could still be for other parts and even a different length stem, if you have a good wedge to use with this.
Likes For merziac:
www.theheadbadge.com
Quoted: 2401 Post(s)
Liked 4,350 Times
Liked 6,300 Times
Standby to advise, I know zero about 3D.
Likes For merziac:
Quoted: 1601 Post(s)
Liked 2,188 Times
My personal opinion is the missing part of the clamp doesn't significantly impact the clamping force. Less area, higher overall impinging force for the given force of the wedge.
The issue I have with the design is the lack of distribution of force between the wedge and the clamp. Note the nearly sharp transition from wedge part of the clamp to the clamping backside surface. This transition should have been much more gradual or like a trapazoid configuration. Given the thickness of the clamp and the fact that it is a casting, make me believe the major portion of the clamping force is behind the wedge feature of the clamp.
Cinelli1RClamp on Flickr
Having said that, 3/8 bikes in the garage that use quill stems have them.
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
That's what I was thinking as I mulled this over last night. Either way, I'm not going to use it, so if anyone wants it for what it is, or if I can help with any 3D wizardry, let me know.
Liked 2,188 Times
BTW, I think I JB welded the one in the picture and am using it.
Liked 4,350 Times
I can probably work with it if you can export the result in an .STL file.
-Kurt
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
Well, turns out you need an iphone 12 pro with lidar scanner to use the really cool functions of polycam. My wife's 13 rendered this:
I wouldn't trust that to hold my handlebars! I don't think I'll be able to hold up my end on the tech support, although I read that the scandy app works well with iphone 13s. Hey wait, I don't even like hidden clamps!
Liked 4,350 Times
I can model this without a scan (and ultimately have to do so regardless), but it's just a lot easier verifying measurements with a direct scan of the part, rather than a fair number of costly test pieces that might not fit right.
-Kurt
Liked 6,300 Times
Whoops, forgot the base 13 doesn't have LiDAR. Anyone out there with the 13 Pro?
-Kurt
-Kurt
Likes For merziac:
Liked 6,300 Times
-Kurt
-Kurt
