Trek Domane SL6 vs Checkpoint SL6
#101
Quoted: 9653 Post(s)
Liked 6,365 Times
Good point but it was in the 20s at the golden hour, and at that time I was otherwise engaged in warmer activities.
Likes For Mojo31:
#102
Quoted: 236 Post(s)
Liked 196 Times
https://www.amazon.com/TUSITA-Seatpo.../dp/B097XS7SFF
#103
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
FWIW, this Varia mount fits the seat post fine. I use it on my SL5. Didn't know about the reflector, didn't get one with the bike.
#104
Quoted: 236 Post(s)
Liked 196 Times
Especially when riding.
Likes For gpburdell:
#105
Quoted: 2975 Post(s)
Liked 1,180 Times
Domane comes with 32 tires. Not sure why people are recommending 25, 28 or 30. You don't gain any speed with a smaller tire and you lose comfort.
#106
Quoted: 270 Post(s)
Liked 447 Times
The R2s that came with my SL6 were slow and stiff. I tried them. Had on hand a 25 and a 28 Conti 5000. Softer ride. The 25mm measures 27.5mm and the 28mm measures 29mm. A little wider than marked while the R2s are true to size. I do switch back and forth and use the R2s when there is more soft ground that needs the wider foot print. 32mm
#107
Quoted: 236 Post(s)
Liked 196 Times
#108
Quoted: 270 Post(s)
Liked 447 Times
My plan for the next set of road biased tires is 28 or 30mm tubeless. Then a second set of wheels for road. Use the stock wheels for the rail trail gravel bias and go with 35 to 38mm also tubeless. I may chicken out and keep running tubes though. Need more road time to wear out tires.
Likes For biker128pedal:
#109
Quoted: 236 Post(s)
Liked 196 Times
Tires are consumables - no reason not to try it yourself when your current tires need replacing. For myself, moving to 28s (from slightly oversized 30s, by current standards) was a slight, but noticeable, difference in handling and comfort. I preferred the feel of a bit of increased agility, though some might think it increased "twitchiness" and not like it. The small decrease in comfort wasn't an issue for me.
#110
Quoted: 20810 Post(s)
Liked 9,456 Times
#111
Liked 9,456 Times
Oh, I'm sure I'll try it myself in due time. Just curious as to what extent the size vs tire made the difference @biker128pedal observed since I haven't a lot of road tire experience.
#112
Quoted: 270 Post(s)
Liked 447 Times
I have Conti 5000 25mm on front and 28mm rear mainly because that’s what I had. The 28 was on the shelf I bought and did not fit the Madone 5.0 I used to have. The 25mm was a spare for the Madone. Also the 25mm is more aero on the Domane stoke wheels. The 28mm on the front was just too wide. I even tried a 23mm I had on hand.
#113
Liked 1,180 Times
Try the conti 5000 32's.
Likes For prj71:
#114
Liked 2,966 Times
I've yet to have a new bicycle come with factory tires that were satisfactory to my riding needs. Just like a seat, the tires are expected to be immediately changed out.
-Oh Hey!
-Oh Hey!
#115
Quoted: 270 Post(s)
Liked 447 Times
They are rim protectors there for shipping purposes. Also to be used as spares when one gets a cut in one’s tire that cannot be repaired. Fold then up and out them away. Oh another use is on the stationary trainer.
