Pirelli P Zero Smartube - quick review
Quoted: 414 Post(s)
Liked 676 Times
Just thought I'd post my thoughts about these tubes: https://velo.pirelli.com/en/ww/product/p-zero-smartube
First off, they are VERY pricey. I mean, they cost almost as much as my tires! Second, you have to be even more careful than usual when putting them on. But, man, they are SUPER light. And they actually FEEL really nice. I've been riding them for a couple of weeks on my lightweight climbing bike and they seem to make the tires roll better (nothing scientific here; just subjective). And an extra plus is that they never deflate! I haven't had to pump them up again since I installed them two weeks ago. Will I buy them for every bike? No way... too expensive. But it's a nice splurge...
Likes For Caliwild:
Should Be More Popular
Quoted: 22596 Post(s)
Liked 8,925 Times
Liked 8,925 Times
Word is these are lighter than latex but latex has lowest rolling resistance. Neither are cheap.
Bikes: 2023 Cervelo Soloist 2007 Specialized Tricross 2017 Colnago CRS 2001 Schwinn Homegrown
Quoted: 10 Post(s)
Liked 65 Times
Found them online for $37. Repair is possible with a TPU patch kit.
Liked 8,925 Times
One of my cycling buddies tried the Tubolito which is similar. He got a flat and the tube was literally shredded, not repairable. I don't know if that's typically how these things get flats, but be aware.
p.s. he does like the light weight and road feel of the tube
Likes For datlas:
Quoted: 338 Post(s)
Liked 408 Times
Before I switched to tubeless I rode very lightweight latex tubes (Vredestein race something - they are featherweight). I could swear they rolled a slight bit better than butyl which might have been placebo but what I could definitely notice is improved road feel and comfort.
Tubeless 25mm GP5000 S is my waaah sexy tire. The older generation GP5000 TL which I have on my "workhorse" wheelset is also good but hard to get on and a bit wider and heavier/stiffer.
Quoted: 10 Post(s)
Liked 65 Times
https://road.cc/content/review/pirel...martube-286887
From the article:
The tubes are from the first batch produced and have "Do not repair" printed on them, but this advice has since changed. Pirelli now says that TPU patches, such as the Tubolito patch kit, are effective and safe. One thing to bear in mind, though, is that a patch can take up to 30 minutes to cure and the process is different to a standard tube – best done at home rather than out on a ride. It isn't possible to use either a normal vulcanised rubber patch or a self-adhesive patch.
From the article:
Quoted: 414 Post(s)
Liked 676 Times
From the article:
From the article:
Quoted: 6963 Post(s)
Liked 10,961 Times
A $37 inner tube that may (or may not) be patch-able?
Hard pass.
Hard pass.
Likes For Koyote:
Thread Killer
Quoted: 3136 Post(s)
Liked 1,704 Times
I run Schwalbe Aerothan on two setups which I tired of futzing with tubeless, and as the OP found with the Pirelli TPU tubes, the Aerothan have proven to be excellent for me, too. They feel like they almost disappear inside supple casing tires— in my case, Herse and Ultradynamico— and hold air great. I did have a puncture in one tube, just a clean hole (as expected; TPU is elastic in all directions and should not rip or shred), which patched easily with a Lezyne self-adhesive patch.
Yeah, they’re fairly expensive, but as an alternative to finicky, leaky, supple casing tubeless tires which need constant sealant topping up, they’re a great alternative which delivers advantages in lower weight, puncture resistance, and improved rolling resistance compared to butyl, as well as improved ease of installation, lighter weight, and greater durability (i.e. puncture and snake bite resistance) than latex.
For my particular mix of needs, TPU is almost the perfect solution, with the only mark against it being the high cost of entry. I’m three pairs deep now (a set is waiting to go on the Racelight’s winter GravelKing slicks) which is probably all I need to get my mulit-bike maintenance routine under control. My other main three bikes are running tubeless either acceptably (650b Herse standards on WTB i23) or perfectly (2 pairs Schwalbe Pro One on American Classic Argent), and the rest can run butyl.
Likes For Racing Dan:
Of course, no worries :-)
Id even be inclined to try myself, if wasn't for the steep price, the iffy patchability (is that a word?) and rolling resistance tests showing only the very lightest 25g TPU tubes being "faster" than a mid weight butyl tube - by 1 (one) watt .. Normal weight TPUs at ~40g or so even test slightly -slower- that a basic conti race light. Im sorry, at that point, what IS the point? :-)
https://www.bicyclerollingresistance...pu-inner-tubes
Thread Killer
Liked 1,704 Times
So what’s the point? TPU delivers more of what you want and less of don’t want. It really should be no surprise that better costs more, but I certainly understand when it’s the case that better simply costs too much.
I believe you are the dishonest one. It says "Schwalbe SV15 which probably is the benchmark for a standard butyl tube. The 102 grams Continental Race 28 simply is the fastest rolling ~ 100 grams butyl tube.".
Now I simply said. In other words than before. To get a TPU that is "faster" than a Conti race light, a mid weight butyl tube, not fragile ultra light, you need to get a ultra light TPU, that is all of 1 (one) watt, per wheel, faster If you get the normal Tubolito it is actually slower and the other normal weight TPUs test the same as the conti. They are a bit lighter for sure. About 30g a wheel. Factoring in weight you "save" 0.2W total, if you ascend 3300 ft/hr. except if you get the standard tubolito, in which case you still loose ~0.5W total, even if you are ascending briskly and factor in the weight saving
As I said before: Nothing but faff and expense to not run perfectly fine clinchers and butyl tubes, or to get tiny perceived "gains".
Thread Killer
Liked 1,704 Times
Again, compare like for like, and TPU is better in every performance category. If you cannot afford to run better tubes than Conti Race28 Light, it’s okay…no one cares or is judging you for that, so drop the defensiveness, it’s just an innertube.
The aerothan is exactly the same as the conti 28 light at 80 psi and all of 0.1w (zero point one) faster at 60psi .. lol
Sorry, thats the very definition faff and expense for nothing :-)
Seems to me you are the one being "defensive" and trying to paint me as butt hurt cos you think I cant afford a bicycle tube. Give me a break, haha!
Late last year I put carbon wheels on the Bianchi. The shop had P Zero race tires and the P Zero tubes. He gave me a nice discount so I thought to go all in. That set up gives a quick, smooth and nimble ride. Considering what the bike, kit, accessories run these days in cost I figured why not. I have never patched a tube. carry a new one with me. Not comfortable with a patch.
There’s not much faff involved. It’s an inner tube. You install it the same way you would install any other inner tube. They reliably hold air and are easily and reliably patched with the right patch kit. I have used the Tubolito patch kit to successfully patch both Schwalbe and Pirelli branded TPU inner tubes. As far as cost goes….a few years of use out of them easily justifies the expense, Dollar per gram, there aren’t many cheaper ways to remove grams from your bike.
Thread Killer
Liked 1,704 Times
If you simply don’t believe the benefits of TPU tubes are worth the price for you, just say as much and leave it there. You won’t get an argument from me for that. I think they’re expensive, too, but it’s not a something-for-nothing deal, so $80 for a pair actually seems like getting a lot compared to other stuff on the bike. I mean, what on the bike am I gonna spend $80 on and get more? Saddle? Bars? Tires? Grip tape? Seatpost? Wheels? No way.
Quoted: 414 Post(s)
Liked 676 Times
PSA: They're on sale at 365 Cycles for $30.03. After my morning ride on them, I decided to get a couple more for another bike. I will say that subjectively they FEEL lovely. Not sure the science backs it up, but I really love how they ride.
https://365cycles.com/collections/co...m-presta-valve
