Disc brake rotors as spoke protector discs?
Note 1
Added after first 2 responses.
My RD came perfectly setup and with a spoke protector. Chain never slipped while shifting into the lowest gear. Chain slipped twice when going thru potholes and over bumps and the spoke protector saved the rear wheel.
Note 2
This thread is NOT about need for spoke protectors.
Nor about alternatives to using rotors as spoke protectors.
Nor about how to buy spoke protectors from outside India.
Metal (and plastic, as well) spoke protector discs for freehubs are not easily available in India.
Can I use disc brake rotors as spoke protector discs?
If yes, have the following questions.
1. Should I use centerlock or 6-bolt rotors?
2. For a 11-36T cassette, diameter of 36T cog is 150mm (6 inches).
Is it better to use 180mm or 203mm rotors?
3. Should I attach the rotor to the spokes or the 36T cog?
4. How close to the 36T should the rotor be to prevent chain derailment?
Thanks
Note 2
Thanks
Quoted: 6193 Post(s)
Liked 4,808 Times
I suppose you can use anything you can fit on there in the proper position. A old lid off a pail, metal or plastic. Just whatever is pleasing to you for any reason.
However if your bike has the DR limits properly adjusted and nothing else is wrong to make the chain come off the rear cassette or freewheel often, then why do you need spoke protector?
- Which seem easier for you to make fit?
- Don't know, spoke protector design and engineering doesn't get mentioned much. I think you should use your own judgement.
- Either will work. You might not want to have the protector firmly attached to the spokes by bolts or other fasteners that alter the stress points of the spoke. But maybe nylon zip ties or something. Or fasten it to the big cog.
- Protector isn't to prevent chain derailment. It's there to protect the spokes in the event the chain does come off the cog while you are sprinting with all your might from a dead stop. Other times you probably aren't putting out enough power to damage the spokes. Unless you foolishly keep pedaling. Again, the DR low limit are what keeps the chain from coming off the big cog and correct adjustment and condition of everything else. IE, the DR hanger.
Likes For Iride01:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Thanks
Thanks
Likes For tyrion:
Quoted: 1819 Post(s)
Liked 1,693 Times
Spoke protectors are very thin and are contoured to follow the dish of the spokes. A disc rotor is much thicker and perfectly flat. Your derailleur would probably hit the rotor when you shift to your largest cog
Likes For alcjphil:
Liked 2,011 Times
I'd make something out of scrap plastic (e.g. the jug below) before trying to use a rotor. Might need 2 or 3 layers of plastic, depending on thickness. Zip tie them to the spokes.
Likes For tyrion:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
Amazon has more spoke protectors under 10 bucks than you can shake a stick at. If you want something blingier than plastic, chrome ones are about 5 bucks more. I don't know that it would be worth the effort for most people to try to use a disk brake rotor unless they want to aggravate the people the eschew spoke protectors AND disk brakes.
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
I highly recommend this idea to all disc brake-coveters while they hold out for a thru-axle bicycle, rather than buying a QR-disc bicycle that will forever be a lemon. I'm serious. People are better off making their rim-brake bicycle look like it has disc brakes, than to settle with the QR-junk being passed off as disc brakes in the era of thru-axles.
Spoke protector costs $8.64
Delivered to India cost is $28.86
Quoted: 184 Post(s)
Liked 67 Times
You can get them much cheaper here: https://www.aliexpress.com/premium/s...ke.html?dida=y
AliExpress and similar sites cannot ship to India!
Quoted: 327 Post(s)
Liked 736 Times
To the OP, I agree with the above issue raised about a rotor being flat and not contoured, and being relatively thick. I think you’d have issues with your derailleur hitting it when in low gear.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Quoted: 2026 Post(s)
Liked 1,096 Times
Quoted: 2338 Post(s)
Liked 2,822 Times
even easier would be finding a flat plastic lid of suitable thickness
Quoted: 496 Post(s)
Liked 431 Times
Possibly.
I don't think it matters as you'll have to remove the centre anyway.
I just checked a 32t cassette against a 160 mm rotor and that looked a bit close, so I'd go for the 203 mm on 38t.
Probably more effective bronze welded to the back of the cassette than zip tied to the spokes.
The regular spoke protector doesn't prevent chain drop, it just catches it before it chews the spokes or jams the freewheel. You'll need it far enough back that the derailleur doesn't hit it in normal operation.
Between $10 and 15. Shimano.
Appreciate the useful responses, grumpus.
Inner diameter of centerlock rotors seems to be 35mm and BCD of 6-bolt rotors is 44mm. I was thinking of using bolts, nuts and washers to setoff the 6-bolt rotor from the cassette and then attach to cassette and spokes to maintain position.
Even if the centerlock rotor fits the freehub, it may interfere with the derailleur, as you warned.
Possibly.
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
paint can lid
