Go Back  Bike Forums > Bike Forums > Beach Cruisers
Coaster brake on Huffy's vs. Kents.
Beach Cruisers Do you love balloon tires and fenders? Do you love riding the simplicity of a single gear and coaster brakes or a single gear cluster? Do you love the classic curves in the tubing of a cruiser that takes you back to the 1950's and 1960's, stylistically? Here's your home! Welcome to the Beach Cruisers and Cruisers forum!
Old 10-30-21, 12:47 AM
birdmove
Quoted: 20 Post(s)
Liked 25 Times in 15 Posts
I have owned a Huffy Cranbrook cruiser, which I gave to my adult daughter a while back. It used a rather fragile little metal clamp to anchor the arm for the coaster to the frame of the bike. The one on that bike broke at the first flat repair. I just installed a stout hose clamp. While at WM today, I was looking at the mens and lady's Kent Sea change cruisers, and I noticed these bikes have a much better setup to anchor that arm. They have a welded on bracket with a slotted hole for the screw, which should last forever. The slot to allow the bolt to slide for and aft for chain adjustments. No need for a clamp. The Kent's just have a a much nicer arrangement, and the welds are good. The Huffy's are known to often have very bad looking welds, though the ones on my Cranbrook looked good.
birdmove is offline
Old 10-31-21, 07:04 AM
rhenning
Quoted: 374 Post(s)
Liked 102 Times in 76 Posts
I used to use pipe strapping for bikes with strap this missing. Always worked good. Roger
rhenning is offline
Old 11-01-21, 11:59 AM
restlessswind
restlessswind's Avatar
Bikes: 2017 Surly Cross-Check. 2020 Specialized Turbo Vado 3.0, 2002 GT Dyno Roadster, 2002 Rans Stratus, 2020 Giant Fathom 2, 2011 Trek Pure Sport
Quoted: 171 Post(s)
Liked 83 Times in 61 Posts
I have come across those chainstay bosses that are out of alignment and need an array of washers to keep the arm from binding. The loose clamps are a better design, and have been used since the inception of coaster hubs. ACE hardware sells a rubberized P clamp that will fit without scratching the paint for $.59. I like to use a button type hex bolt and self-locking flanged nut instead of a standard bolt with a nylon lock nut. Easier for roadside repair and looks great.
restlessswind is offline
Old 11-07-21, 07:34 PM
birdmove
Quoted: 20 Post(s)
Thanks for that. I haven't owned or worked on a Kent with the welded on bracket. I'll take your word for it on that.
birdmove is offline
Old 11-09-21, 10:09 AM
Rolla
Victimless Criminal
Rolla's Avatar
Quoted: 1125 Post(s)
Liked 2,722 Times in 1,212 Posts
I had a coaster bike with the welded-on bracket, and found that the slot wasn't long enough to accommodate for the change in wheel position when I changed the size of the rear cog. I much prefer the Wald coaster brake strap.
Rolla is offline
Old 11-23-21, 07:50 AM
seanppower
Recomedations on beach bikes?
seanppower is offline
Old 11-23-21, 08:03 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 889 Post(s)
Liked 683 Times in 413 Posts
I've worked on a lot of coaster brake bikes in my volunteer work and have never seen a broken strap, though most of them are beat up a bit. Like others have mentioned, the welded tabs sometimes have an alignment problem. It really doesn't take much to hold the coaster brake arm in place, the thin metal straps work well for the most part.
I recall, as a kid, replacing a broken brake arm strap with a lashing of shoelace. This held up until I rode the wheels off of that J.C. Higgins.
Moe Zhoost is offline
Likes For Moe Zhoost:
Old 11-23-21, 11:19 AM
canopus
canopus's Avatar
Bikes: Road, Touring, BMX, Cruisers...
Quoted: 133 Post(s)
Liked 168 Times in 107 Posts
I always bent the coaster arm to land in the middle of the chain stay, drill the arm so it could handle a 5mm bolt and then use some bar tape and an old Dia-Compe hinged seat post clamp instead of the skimpy band. The arm needs to be kept from moving and that was a very sturdy setup for doing small ramp tricks.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
canopus is offline
