V-O french-thread BB....
Bikes: '38 Schwinn New World, '72 Peugeot PX-10, '97 Cannondale T900, '98 Peugeot Appalaches, ?? Raleigh Sports, ?? Raleigh Superbe, ?? Hercules 3sp (x2)...
Quoted: 285 Post(s)
Liked 489 Times
OK, I just want to make sure I'm not missing something here...... Recently got a V-O French BB for a build. Labeled French on the box, on the body of the BB, the flange of the drive side says "FRENCH 35x1 REMOVE COUNTER CLOCKWISE", but....... the threading on that side of the BB is left-handed. It should be right-hand threaded on both sides, right? Will contact V-O, but just want to be sure I'm not somehow confused...
Quoted: 990 Post(s)
Liked 966 Times
Yes, French is right-hand threaded on both drive and non-drive side, and it should be removed by turning counter clockwise. Which bike is this for? Are you sure the bike is French threaded?
Likes For noobinsf:
Quoted: 285 Post(s)
Liked 489 Times
Yup, Valgan Vitus 971 frame. The Stronglight BB that came out of it (tragically very pitted...) is right-handed on both sides. Seems like maybe there's been a factory error with the BB.....
Quoted: 285 Post(s)
Liked 489 Times
Threading in the BB shell is right-handed on both sides, so yes, the right-hand-threaded NDS/adjustable cup fits (both sides). Problem is the labeled-as French BB from V-O is left-hand-threaded on the drive side.
Wrench Savant
You might be the only person in history to "mistakenly" get a Swiss-threaded bottom bracket. One of the 17 people on the planet with Swiss-threaded frames may hunt you down.
Likes For balindamood:
Quoted: 285 Post(s)
Liked 489 Times
Wrench Savant
Quoted: 2463 Post(s)
Liked 1,389 Times
The VO French threaded BB I bought a while ago was correct, "RH" thread both sides.
I tried to use it but on TA cranks - the cranks walked in too much. The spindle is polished and plated on mine. I prefer coarser machined.
I never took it up to torque, 45 nm
Quoted: 285 Post(s)
Liked 489 Times
As a follow up- contacted V-O and they sent a correct BB & return shipping label for the mis-marked, wrong one.
In both cases, however, the bearings seem really stiff. Like, really stiff... Is that normal for sealed bearings in a BB?
Old fart
Quoted: 3004 Post(s)
Liked 2,110 Times
Not unusual for new bearing cartridges. Until the seals wear in, they can feel stiff. But unloaded stiffness from seal drag really has no effect on loaded performance.
Likes For JohnDThompson:
Quoted: 285 Post(s)
Liked 489 Times
Liked 1,389 Times
Señor Member
Quoted: 2454 Post(s)
Liked 3,285 Times
