Gearing change?
OM boy
Bikes: a bunch
Quoted: 356 Post(s)
Liked 389 Times
Yes it does, or at least, it does in my experience. Gearing bottom-out puts a lower bound on the amount of force you need to pedal at in order to keep going; lower gears decrease this bound. Plenty of the hills around me force me to go at least somewhat hard if I'm on a bike with typical road gearing, but if I'm on my gravel bike (which has a 19" bottom gear), I have the option to take it easy if I want to.
You only go slower if you use the lower gears to go easier. For the most part, in my experience, gearing bottom-out is bad for power: the lower your cadence has been kicked, the more dramatic this is. Although it's sometimes easier to produce more pedaling force at lower cadences, there are harsh limits to this. If I'm fighting to keep the pedals turning over at 50rpm, changing to a higher gear that sends me down to 40rpm is unlikely to facilitate the corresponding 5/4ths increase in pedaling force that would allow me to maintain the same power.
My '83 Miyata has a 42-28 low gear, while my Emonda has a 34-28. On moderate climbs, the Emonda has a speed advantage of a couple percent, which is in agreement with basic kinematic differences between the bikes (i.e. the Emonda's 5-pound weight advantage). But on climbs where I start feeling bottomed out even on the Emonda, its advantage over the Miyata can quickly rise to over 10%.
Ok, 5-6% grade isn't much, but I was trying to put into a frame work which I see a lot of riders struggling. But let's make it 'real' 8-9%+ and, for whatever reason, you're barely turning 55/60, on a current bike with 34/28, 25mm rubber - you're goin about 9 kph (6ish mph) - you drop into a 30 or 32 - I would put big money that, after about a 20 yd surge, you will again be doing 8 kph.... and happy that you haven't put a foot down. WHy do I say that?
Well, if you're at 65-70 rpm, you're getting into a new, lower effort comfort zone. If you're at 55 rpm, you're already DONE/cooked and 30/32/34 isn;t going to save you - you'd need 40/42/48 to find relief... Reality is a *****.
Ride On
Yuri
Quoted: 4792 Post(s)
Liked 4,213 Times
I'd ignore all these people and put easier gearing on the bike if you need easier gearing. I don't know what it is with roadies and their HTFU attitudes. Get a Wolf tooth roadlink and stick an 11-36 or even 11-40 cassette on the back of that thing. Won't cost much and you can always swap back when you get your climbing legs.
It might help him to hear that experienced climbers who are older, heavier, and in questionable condition (me) climb and descend hundreds of thousands of feet each year with more limited gearing than he already has. Or maybe not.
Likes For big john:
I once thought that using my lowest gear of 21 gear inches was more effictive for me to climb a steep hill with soft gravel on my comfort bike. Certianly for the steepest parts of the climb this is true, But on less steep but still challanging sections I found shifting up a cog or two (to 30 gear inches) to be best. For me keeping a cadance of about 60 rpm seems to work best climbing. Its Strange that on a flat 70 - 75 rpm seems to work well at medium high effort.
Regardless, I want the right gear for the job. IMO if a gear change to a 46/30 chainring gives the op the gearing that works best for him, Then it is a smart move.
OM boy
Bikes: a bunch
Quoted: 356 Post(s)
Liked 389 Times
For all those bringing up his maximum HR - please be aware that some of us DO have medical / heart conditions and/or take medications that will limit your maximum HR.
OP - when in doubt, consult a cardiologist. Possibly request a stress test, and ask an actual medical professional (rather than internet forum posters) what is best for you.
I know of one cyclist, many years younger than I, who pushed his HR on a hard climb, and suffered a full blown heart attack on the descent.
If you want to check your gearing, go here: Sheldon Brown's Bicycle Gear Calculator
If I keel over on Gibraltar some day, c'est la guerre...
BUT, we can only comment on what info the OP puts in his Q.
Truthfully at 40 rpm, dropping into the next lower gear is not gonna do it.
... Get the 11/32 or 34 cassette, but then go put the work in.
Ride On
Yuri
For instance, if a bike+rider is 167lbs, a 5lb increase represents a 3% increase in resistance from gravity. So for example, on a steep climb where you're going slow and bottlenecked by gearing, that 42T chainring on the Miyata would be like using a chainring slightly larger than 43T on the Emonda.
Klaatu..Verata..Necktie?
Quoted: 6193 Post(s)
Liked 6,552 Times
Over the hill
Bikes: Giant Defy, Specialized Allez, Raleigh Pursuit tandem
Quoted: 431 Post(s)
Liked 475 Times
You could probably throw on an 11-34 cassette without any other changes, but it would be a tiny difference.
It's like riding a bicycle
Liked 4,213 Times
This might require that the OP buy a subcompact crankset. Not super cheap, but it would be effective (assuming you take the above advice and just coast down fast descents).
40 rpm indeed a point of great struggle. It may feel significantly easier if you can spin at least 60 rpm which likely means a gearing change.
Another option is just buy a gravel bike with super low gearing, 46 to 30t chainring and 42-11t cassette. Gravel bikes also have endurance geometry like your Giant Defy.
I don't really pedal on a 5% gradient descent or more. If you have tight fitting clothes, just tuck it in and it will get you to 60 kph.
Beyond Bogus
Quoted: 18222 Post(s)
Liked 5,208 Times
Likes For datlas:
Likes For seypat:
I wouldn't change the gearing. Try to expand your cadence by spinning smoother at 100 rpm or more. Above 35mph I bring my knees and elbows in tight and try to hold a more horizontal position. I can usually pull away from other riders without pedaling.
Also learn to develop power at low rpms while you climb. Flatlanders need to change their habits and skills when the route becomes dominated by hills.
I am nearly 69 and no paragon of fitness or training knowledge, but in the past year I’ve decreased my weight from 207 to 197, reduced BMI from 32% to below 28, and increased lean mass to 138# from 125#. Before this I had burning legs on our local hills (Midwest USA is pretty flat compared to the Rocky Mountains, but still pretty flat), and now my 50/34 11/29 lets me ascend it with about 60 rpm, 7 mph without going anaerobic. The breathing performance alone is aerobic endurance, but adding the load of climbing makes it muscular endurance. The improvement was based on more and harder yoga, more indoor pedaling, a lot of housework and home rearrangement in a house with three flights of stairs.
When I tell my doc I want to kick up my cycle training, she thinks not about my max HR, but about whether my heart is functioning well under physical stress. While I use an HRM, I’m not oriented at the moment to zones and levels. Pushing your heart rate might be ok for you, but if you are using a number just calculated from a simple formula or chart based on age as a firm limit, that is probably not a good practical (or productive!) limit for you.
Liked 6,552 Times
"I'm building a C&V bike with a carbon fiber frame and first-generation 105 Di2, but the only 12 speed cassette I can find is 11-34. Can I fit a 48t cog to go with my 20t small ring? Will the derailleur work? And can I use my 15 speed chain with it?"
We could use a wide range cassette and new proper derailuer that might cost the same. But I really like the closer ratios on the stock cassette.
Likes For xroadcharlie:
Low intensity efforts gets you into fat-burning mode if carbs are running short and you'll be able to last much longer if burning body fat. Higher intensity efforts will get you into protein-burning mode, if carbs are low. Burning protein will cause early fatigue and hamper recovery post-ride. Strictly in terms of fuel economy, low intensity efforts are better and if fuel is limited, you'll get farther with lower intensity efforts.
That is one reason why the majority of the training time allotted for polarized training is at low intensity effort. Mainly for endurance adaptions without imposing too much on recovery.
On long 6 hr rides in the mountains without stopping, I "carbo-load" the day before and shortly before the ride and bring a fixed amount of fuel. If I work hard enough, I'll bonk the ride mid way and be forced to stop to refuel like ice cream and pepsi. But if I take it easy enough. I'll make the 6 hr ride non-stop and still have plenty of energy left for a sprint on the last 200 m distance from home.
200 pounds, plus say 20 pounds of bicycle, means that a ten pound difference is something like 230 vs 220. That's a 4.5% difference in gravitational resistance on the climb. In reality, the total resistance is going to change by a bit less than that because not all resistance while climbing is gravitational (i.e. there's still some stuff like aero drag).
Meanwhile the difference between a 24T cog and 25T cog is ~4.2%, or the difference between a 27T cog and 28T cog is 3.7%. So these 1-tooth gear ratio changes are in the same neighborhood as the difference in resistance caused by adding 10 pounds on a climb.
The approximation will break down with less traditional arrangements, like if the road bike in question is running a 1x setup with an 11-50 cassette. Then a 1-tooth difference is a 2% change to gear ratio, for instance.
Likes For HTupolev:
Over the hill
Quoted: 431 Post(s)
Liked 475 Times
It makes sense as a very rough approximation across some common road cassette sizes.
And we’re only talking to Clydesdales? Because 10lb to a 120lb rider is more like 8%
I don't think Seypat was intending for the formula to be generalized.
Likes For HTupolev:
Quoted: 2442 Post(s)
Liked 1,501 Times
Seypat's comment about "big cogs", plus the reference to weight, made it sound like they were referring to what their bottom-end gears were worth on a climb.
Yeah, the comment referred to a 200lb rider weight.
BTW, that's 5'8" 200, so I really can't give recommendations on "ride or feel." Something like tires or frames are going to feel completely different to me than to a 5'8" 130 or a 6'3" 200 rider.
Likes For seypat:
My bike weighs in at 40 lbs with one bottle of drink and the tools and panniers and fenders and all that but had easier gears for climbing loaded on mountains.
Then a I tried a friend's bike weighing only 20 lbs, what a world of difference!! I climbed the same hill at higher gear, higher speed and didn't even feel like I'm climbing! Fu** is the word for it!! Only wished I can afford the same bike he had!
Actually, the % difference in performance can be a lot higher if the effort is above lactate threshold just to get things moving like a in a steep climb and then goes below with equipment changes. It allows you to do intervals to alternate pushing or getting rid of lactic acid build up or maintain constant effort around lactate threshold with a lot less suffering. It can mean a large improvement in average speed in a climb, well beyond the % difference in equipment offered like the weight or gear ratio. In my experience, reducing bike weight is more straightforward approach because it directly translates to reduced power requirements. Switching to easier gears may not. Power requirement would be the same but the easier gears would allow you to ride slower or strain your legs less but you can still blow it up if not used to the power level.
Liked 1,501 Times
I think koala legs stated in one of these threads that he's around 173cm/68inches tall. If you were to give us the same bike to ride and evaluate, you'd get 2 totally different opinions. That's what makes the world interesting.
Yeah, that would be the case! At GCN they talked about it in one of their videos with Emma Pooley on it. Because she only weighed 106 lbs, they commented how the bike's weight would make a much bigger impact to riders like her. You can't go cheap if you are that light! Or go cheap and heavy and limit yourself to slow speeds like I do!
