Cycling shoes
Quoted: 5 Post(s)
Cycling shoes
I get hot spots on the bottom of my feet. I am looking for a new pair of cycling shoes. I bought some relatively inexpensive Bontrager shoes. They have proven to be horrible for my feet. My old pair were made by Specialized. They are heavier with a thicker base. Any suggestions from any of you? I plan to do a long ride in August. I am asking this especially to those of you who have trouble with foot pain.
Over the hill
Bikes: Giant Defy, Specialized Allez, Raleigh Pursuit tandem
Quoted: 439 Post(s)
Liked 478 Times
My understanding is that hot spots can be caused by various types of shoe fit issues. Mine were due to the sole being too narrow. I'm not familiar with Bontrager, but I believe Specialized runs a tad wider than most other brands in the toe box area.
It's like riding a bicycle
Likes For urbanknight:
Quoted: 166 Post(s)
Liked 291 Times
I get that too but hugely helped by a G8 insole and Shimano S-Phyre's; I don't get it at all now unless on a hot day and I keep my shoes tightened too long.
I have a pair of the new Specialized S-Works Torch since they claim to be good for dealing with hot spots but I haven't tried them yet.
Quoted: 2356 Post(s)
Liked 1,169 Times
What kind of hotspots and where ?. I get them under the smallest toe in the joint. In my case it's an inflammation caused by lack of support to the middle of the foot, seems as you age (my podiatrist tells me) the ligaments and tendons in the middle of the foot where the toes meet the main foot, stretch and thus provide less support, thus the pressure migrates to the outer toe area. I found using a shoe with a carbon mid sole (or a full carbon sole) provides the support I needed and my inflammation went away mostly.
So one solution is a sole with better support as found on a carbon shoe. I use Shimano XC-7's, in wide, very comfortable. Not cheap but worth it.
I agree with urbanknight (there are many factors that can lead to hot spots, shoe fit being a big one, especially tightness in the toebox, instep and forefoot areas) and AlgarveCycling (some fit issues can be helped with a good quality footbed, most of the ones sold with cycling shoes are minimal at best - I am convinced that Sidi fully intends their footbeds to be replaced with a footbed that works for the purchaser).
Also, hot weather can make hotspots appear earlier in the ride, and can make them worse. My feet can swell during a hot ride, especially later in the day when the pavement heats up and you get heat radiating from the road affecting your feet. Pay attention during a hot ride and loosen shoe straps/buckles before your hotspots start.
Likes For noimagination:
On all my foot wear I use to ride, they're a bit more loose than snug, I removed the insoles, and use thin socks. No discomfort whatsoever on the feet on nonstop 6 hr rides.
The irony is I only get "hot spots" when there's too much cushion under my feet like a soft insole and thick socks.
Likes For koala logs:
Quoted: 458 Post(s)
Liked 191 Times
My suggestion would be to try as many as you can. Unlike saddles, you can go to store and put on the shoes. Go for a pair that is if anything a little too large, like me you can always add professional insoles that will have a bigger volume than the flimsy default ones. Also, always better to be too big than too narrow.
I have a stand-up desk at work, I stand on thin industrial carpet on a concrete slab. I tried a cushion pad to stand on, and I hated it. I have good shoes with a good after-market footbed, and with the cushion pad I was getting extra pressure on my arches. I gave the pad away, and my feet are much happier.
Quoted: 411 Post(s)
Liked 308 Times
In my experience Steve B. nailed it. Both the sole and Wide version in my size.
Over the hill
Quoted: 439 Post(s)
Liked 478 Times
Some shops have test saddles that you can borrow with a deposit. They're often wildly decorated with something like "test" emblazoned across them to make sure you bring them back, but it's a great way to try them out properly.
Quoted: 458 Post(s)
Liked 191 Times
In general I think it can be hard to find many saddles you can just test. Because the shops that do do this, won't have every model.
I did find an online retailer that said if there are no mounting marks, they take it back, if there are, they do but keep some of the money. So I will tape the crap out of those rails to test a few saddles.
Likes For ZHVelo:
Old fart
Quoted: 3003 Post(s)
Liked 2,105 Times
I've found arch support to be helpful in alleviating "hot foot" issues.
