Anyone have issues with Muc Off wet lube?
Old 07-04-22, 10:50 PM
Ryan_M
Ryan_M's Avatar
Bikes: 2020 Giant Roam 1... at least it was
Quoted: 98 Post(s)
Liked 73 Times in 37 Posts
I have a new bottle of the stuff and it's getting sticky and gooey, like honey. This is on my road bike and I'm pretty low miles so far so only done 2 cleanings to date. My typical maintenance is put the chain and cassette in the ultrasonic cleaner (citrus based degreaser), then a soak in isopropyl to displace the moisture, a blow off with the compressor, then back on the bike and re-lube.
I've noticed even after one ride the chain is sticky and not sure if the lube is at fault. Logic would dictate to try a different lube, and I likely will, but I'm curious if anyone has experienced the same.
Ryan_M is offline
Old 07-05-22, 11:23 AM
smd4
Bikes: 1989 Cinelli Super Corsa
Quoted: 783 Post(s)
Liked 575 Times in 371 Posts
I don't use Muc-Off, but if it's too thick to work its way inside the chain rollers, what's the point?
smd4 is offline
Old 07-05-22, 11:37 AM
Ryan_M
Ryan_M's Avatar
Quoted: 98 Post(s)
It seems thin and wicks itself well into the rollers when applied. I wonder if I'm not flushing out the degreaser well enough and it's reacting with the lube in some way.... any chemists in the house? Lol
Ryan_M is offline
Old 07-05-22, 01:20 PM
Crankycrank
Quoted: 640 Post(s)
Liked 607 Times in 461 Posts
Only thing I can think of is do you rinse off the citrus cleaner really well with plain water? Could be trapped in the rollers and reacting with the lube.
Crankycrank is offline
Old 07-05-22, 02:48 PM
freeranger
freeranger's Avatar
Quoted: 312 Post(s)
Liked 501 Times in 313 Posts
Maybe try mixing the muc off with your cleaner(s) in a container and see what how it does. Should provide an answer as to what it might not mix well with, if it is a reaction with a cleaner.
freeranger is offline
Likes For freeranger:
Old 07-06-22, 06:53 AM
easyupbug
Quoted: 401 Post(s)
Liked 299 Times in 218 Posts
I know nothing about Muc Off other than a son-in-law loves it with his MTBs, but they should have a tech who should respond.to your question.
easyupbug is offline
Old 07-08-22, 03:11 PM
SkinGriz
Live not by lies.
Bikes: BigBox bikes.
Quoted: 445 Post(s)
Liked 375 Times in 287 Posts
It says biodegradable.
Probably soy or castor bean oil based.
If so, I would completely expect it to get gummy and foul up.
People that are happy with it in the long run probably clean and lube their chains more often.
SkinGriz is offline
Old 07-09-22, 10:37 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4248 Post(s)
Liked 1,219 Times in 801 Posts
FWIW, but probably not too helpful. See page 4 perhaps?
Sy Reene is offline
Old 07-09-22, 11:45 AM
davidad
Quoted: 556 Post(s)
Liked 158 Times in 127 Posts
I used an ultrasonic cleaner and home brew for my chains. The lube is a mix of 1 part chain bar oil to 4 parts unscented mineral spirits. It does well in the rain. I ride 800 miles and repeat.
davidad is offline
