Gloves For All Around Wear?
Old 03-10-18, 09:29 AM
StarBiker
StarBiker's Avatar
Bikes: Gary Fisher Cobia, Cannondale F700
Quoted: 689 Post(s)
Liked 56 Times in 54 Posts
Since REI has a clearance on the clearance I bought the last pair of North Face E Tip Apex Gloves for $30. I have used them for about 2 hours, and although well made, I don't think they are that warm. I need warm gloves for all around wear that I can cycle in that go in a pocket easy. And I don't want even slightly floppy finger tips. I really like the fabric on the Apex.
I may just keep them but am curious if anybody uses gloves for riding that they also wear around.
StarBiker is offline
Old 03-10-18, 06:42 PM
RonH
Life is good
RonH's Avatar
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 6 Times in 6 Posts
The description on REI says
Soft-shell material at back of hands blocks wind and moisture.
Lightly insulated.
Since they are made for blocking wind and moisture and are lightly insulated it doesn't seem that they would be very warm.
Just my 2 cents.
RonH is offline
Old 03-10-18, 07:24 PM
fixedweasel
Quoted: 92 Post(s)
Commute all year round and understand the different "levels" of gloves we need for light/medium weather. Since money is so tight and a bit hard to come by, I have had great success getting lightweight/medium form fitting gloves from Harbor Freight. I don't use their gloves for winter here but for all other weather where you need full fingered gloves, they are brilliant. From super lightweight with no padding to medium duty with leather padded palms. These damn things are most definitely worth their price and perform without flaw. Just an option. hopethishelps
fixedweasel is offline
Old 03-11-18, 02:34 AM
canklecat
canklecat's Avatar
Quoted: 4185 Post(s)
Liked 2,090 Times in 1,338 Posts
As other folks suggested, different gloves for different uses and temperature ranges.
Add some thin glove liners. Any thin woven or knit poly glove liners will help. I have one set from a ski shop bought 30 years ago, and another bought from Walgreens last winter for $5. Both work great with my Bontrager RXL Thermal gloves which are thinner than those North Face gloves. With the liners my hands are comfortable down into the mid-40s on the bike (lower than the temperate range Bontrager recommends, but it's all personal -- my hands tend to stay warmer than my toes). And the TXL Thermal gloves are comfortable in summer heat when I want to avoid sunburns.
For seriously cold rides or walking I have heavier Thinsulate insulated wind resistant ski gloves (comfortable on the bike down into the 20s), and Thinsulate insulated knit gloves that aren't wind resistant but offer more hand dexterity. The knit gloves were comfortable on my motorcycle in winter if I added windproof Gore Tex mitten shells.
canklecat is offline
Old 03-11-18, 07:32 AM
Hoopdriver
On Holiday
Hoopdriver's Avatar
Bikes: A bunch of old steel bikes
Quoted: 393 Post(s)
Liked 10 Times in 9 Posts
I have 5 permutations of handwear depending on weather.
1. Regular cycling gloves: temps over 60F
2. Wind block fleece gloves: temps between 40 and 60
3. Same, but with nylon shell over-mitts: temps between 30 and 40
4. Ski gloves: temps between 20 and 30
5. Wind block fleece gloves with bar mounted pogies: Temps below 20F
Bottom line is that there is no perfect all weather glove.
Hoopdriver is offline
Old 03-11-18, 08:23 AM
pesty
Master Sarcaster
pesty's Avatar
Bikes: 2018 Allez Sprint, 2016 Trek Crockett Canti
Quoted: 190 Post(s)
I have some old Giro Blaze gloves, before they started adding padding, that I use for this purpose. Good enough for down into the mid-40s (F) on bike or around the freezing point off bike. When it gets up into the 50's I switch to Giro DND's.
I've also found that light/mid weight cross country skiing gloves make excellent cycling gloves if you're looking for something unpadded. I ride road, but I hate padded gloves, so I frequently look at ski and mountain bike gloves to see what might work better.
pesty is offline
Old 03-13-18, 07:18 PM
martianone
Bikes: recumbent & upright
Quoted: 64 Post(s)
Liked 16 Times in 13 Posts
Wear the yellow jersey gloves from a hardware store for cycling when temp is in 30s F. Then wear them snow shoveling or piling wood or what ever outside task. Same with a pair of material handling gloves, also from the hardware, cycle with them, then go mow the lawn or split wood.
Utility gloves are usually longer lasting and a better value than cycling specific items.
martianone is offline
Old 03-13-18, 09:23 PM
BBassett
BBassett's Avatar
Bikes: Tout Terrain, Panamericana
Quoted: 196 Post(s)
Liked 15 Times in 8 Posts
Good luck finding the perfect glove. If they keep my hands warm they are too bulky. And regardless of everything else, most gloves will soak through when you ride for hours in the rain. No one likes carrying multiple pairs of gloves on a ride. So I learned to use leather cowhide cowboy gloves. Wear then in really well and they fit tight in the fingertips. A heavy load of sno-seal keeps them as dry as any other glove I have worn. Maybe the new thin electric gloves will do the trick nothing up till now has for me. I have used disposable cotton gloves, with disposable latex stretched over them and then a pair of riding gloves a few times. Too much a pain in my ass.
File Type: jpg
File Type: jpg
File Type: jpg
BBassett is offline
Old 03-14-18, 01:43 AM
bigsky109
bigsky109's Avatar
Bikes: Kestrel Talon w/carbon fiber 88mm wheelset, Trek 820MTB
Quoted: 7 Post(s)
I have half gloves for warm summer and just bought some full gloves for a little colder weather. The winter up here can be brutal and I do not ride in the snow or ice.
bigsky109 is offline
Old 03-14-18, 05:26 AM
hyhuu
Bikes: Specialized Allez Sport
Quoted: 12 Post(s)
Year round gloves??? So it can go with your year round clothes?
hyhuu is offline
Likes For hyhuu:
Old 03-14-18, 06:17 PM
Dirt Farmer
Dirt Farmer's Avatar
Bikes: Jamis Quest Elite; Fuji Sagres; Trek Fuel EX 8
Quoted: 324 Post(s)
Liked 68 Times in 48 Posts
Lobster mitts
Dirt Farmer is offline
Old 03-14-18, 06:25 PM
providencebikes
Quoted: 68 Post(s)
I use muliple types of gloves i have used rothco gloves from the army surplus store 20$ us 3m gloves for real cold days mechanics gloves for warm- er times i like the wells lemont cold weather grippers too . you could alway buy insulation material and a water proof layer and make your own...
providencebikes is offline
Old 03-15-18, 11:28 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,320 Times in 830 Posts
ski gloves are cheap~free, but in the summer , around town , I don't wear gloves.. .
fietsbob is offline
WonderMonkey
General Cycling Discussion
23
11-06-15 07:03 AM
chefisaac
Winter Cycling
17
10-31-15 06:06 PM
chefisaac
Commuting
24
10-28-15 08:10 PM
Colorado Kid
Winter Cycling
22
02-27-15 08:54 PM
techman
Commuting
8
10-31-12 02:16 AM
