Forum Suggestions & User Assistance Have a suggestion for the forums? Need help with the Forums? Post here.
Lost access to forum
Old 03-09-21, 06:50 PM
anga
Quoted: 15 Post(s)
Liked 7 Times in 5 Posts
Hi,
Logging in from Tor network. Got in after several failed attempts.
Cannot access forum. Error message attached.
Please check
Error 1005 Ray ID: 62d896fcc92919f1 2021-03-10 00:57:35 UTC Access denied What happened? The owner of this website (www.bikeforums.net) has banned the autonomous system number (ASN) your IP address is in (55836) from accessing this website
March 3
contactus@bikeforums.net
anga
Attached screenshot shows relevant info. First time this has happened. The ISP is Jio, the largest in India. Can you look into thus?
Further communication with joel.morris@internetbrands.com
March 3
Joel
Thanks for reaching out. What is your username or IP address?
March 4
anga
Username is anga IP address is dynamic.
March 4
Joel
Ah, OK. Well you definitely didn't do anything wrong and weren't banned or intentionally restricted. It's most likely that one of your IP addresses was caught by our 3rd party security software. Are you able to access the site on your primary network now? Or on a different network?
March 4
anga
Tried multiple browsers and changing IP address by disconnecting and reconnecting to network. Same issue. The owner of this website (bikeforums.net) has banned the autonomous system number (ASN) your IP address is in (55836) from accessing this website. You have to whitelist the ASN (55836) I suppose.
March 6
anga
https://community.cloudflare.com/t/access-denied/8601
says action needs to be taken by the website and not by cloudflare
anga is offline
Old 03-09-21, 07:00 PM
anga
Quoted: 15 Post(s)
Mods: please edit title
anga is offline
Likes For anga:
Old 03-11-21, 02:15 AM
anga
Quoted: 15 Post(s)
If it helps, couldn't access from Tor. Here is the error.
Error 1005
Ray ID: 62e34e753945f0d5 2021-03-11 08:10:28 UTC
Access denied
What happened?
The owner of this website (bikeforums.net) has banned the autonomous system number (ASN) your IP address is in (16276) from accessing this website.
Cloudflare Ray ID: 62e34e753945f0d5 Your IP: 51.81.87.50 Performance & security by Cloudflare
anga is offline
Old 03-11-21, 10:25 AM
IBJoel
Administrator
Quoted: 164 Post(s)
Liked 151 Times in 104 Posts
Most likely, your ISP or IP addresses you use were associated with spam by our 3rd-party security software and flagged for blocking. Unfortunately, we cannot unblock your networks.
IBJoel is offline
Likes For IBJoel:
Old 03-12-21, 08:11 AM
anga
Quoted: 15 Post(s)
What do you mean by spam?
anga is offline
Old 03-12-21, 10:04 AM
IBJoel
Administrator
Quoted: 164 Post(s)
There are a lot of spam farms in India. Cloudflare will block entire swaths of IP addresses that they've used or even ISPs that allow them to continue spamming. I know that you are not a spammer, but it's likely spammers used shared IP addresses at some point. Although it looks like Jio has had this problem before with Cloudflare? https://community.cloudflare.com/t/s...n-india/171128
IBJoel is offline
