Recommended Dry Lubes
Old 05-16-21, 05:10 PM
eduskator
eduskator's Avatar
Bikes: SL8 Pro, TCR beater
Quoted: 980 Post(s)
Liked 578 Times in 436 Posts
Originally Posted by seypat
If you want to step out of the "bicycle use" category, the various hardware stores have lots of options.
https://www.lowes.com/pd/Blaster-Har...E&gclsrc=aw.ds
No need for a ''bicycle specific'' lube, wax is proven to be a lot more effective than any other available lube.
eduskator is offline
Old 05-16-21, 07:27 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
cxwrench is offline
Old 05-17-21, 05:59 AM
eduskator
eduskator's Avatar
Quoted: 980 Post(s)
Originally Posted by cxwrench
You can say all you want, but it's research proven.
Old 05-17-21, 06:47 AM
Snotrub
Snotrub's Avatar
Bikes: 2012 Cannondale Carbon Flash 2; 2017 Cannondale CAADX 105; 2021 Trek Domane SL6; 2021 Trek Top Fuel 9.7
Quoted: 44 Post(s)
Liked 72 Times in 42 Posts
Originally Posted by SoSmellyAir
Left calf? My chain is hardly spotless but both my calves manage to avoid it. But I have skinny calves.
I'm an idiot.
Snotrub is offline
Old 05-17-21, 08:09 AM
Symox
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times in 151 Posts
I haven’t tried many other dry lubes but I’ve been happy with Finish Line Dry Lube for over a decade
Symox is offline
Old 05-17-21, 10:13 AM
WorldIRC
Canadian eh?
Bikes: 2020 Specialized Roubaix Expert
Quoted: 131 Post(s)
Liked 96 Times in 54 Posts
Originally Posted by noodle soup
Ended up ordering this! Hard to find, but actually found it (in Canada) and at a lower cost than the other recommendations.
WorldIRC is offline
Old 05-17-21, 12:04 PM
phrantic09
Fat n slow
Quoted: 3250 Post(s)
Liked 2,075 Times in 975 Posts
I use Muc-Off C3 dry, very quiet, lasts about 130 miles
phrantic09 is offline
Old 05-17-21, 12:17 PM
Doomrider74
Quoted: 141 Post(s)
Liked 100 Times in 55 Posts
I tried that a while back and it left my chain black and gritty after only a few rides. Revolting stuff.
Doomrider74 is offline
Old 05-17-21, 12:46 PM
PeteHski
PeteHski's Avatar
Quoted: 4384 Post(s)
Liked 4,821 Times in 2,979 Posts
This is my go-to resource for chain lube comparisons. Some interesting and sometimes surprising results. Tests measure both efficiency and wear rates.
https://zerofrictioncycling.com.au
PeteHski is offline
Old 05-17-21, 03:03 PM
oris
I like speed
oris's Avatar
Bikes: Cannondale SuperSix Hi Mod, Specialized Allez Sprint, Bottecchia Emme 4 SL
Quoted: 77 Post(s)
Liked 121 Times in 61 Posts
I just finished a bottle of the stuff. You've got to do a good job wiping off the excess to prevent the gunk from collecting. My issue with Muc Off Dry is that it doesn't last very long and washes off easily; I got maybe 100 miles or so before having to clean/relube. I've moved on and trying out Squirt.
oris is offline
Old 05-17-21, 07:29 PM
Jumpski
Bikes: Bianchi Infinito CV disk, and rim brake
Quoted: 29 Post(s)
Liked 89 Times in 60 Posts
Originally Posted by jaxgtr
Squirt
I second that. I’ve tried several other dry lubes, and they don’t compare with the ease of use with Squirt.
Jumpski is offline
Old 05-17-21, 07:38 PM
noodle soup
noodle soup's Avatar
Quoted: 4717 Post(s)
Liked 1,882 Times in 998 Posts
If you ride in the wet(ever), it's crap. In dry Arizona conditions, nothing is better.
noodle soup is offline
Likes For noodle soup:
Old 05-18-21, 05:57 AM
WorldIRC
Canadian eh?
Quoted: 131 Post(s)
The most "wet" I get is if I hit a puddle. Not a fan of riding in the rain
WorldIRC is offline
Old 05-18-21, 06:17 AM
eduskator
eduskator's Avatar
Quoted: 980 Post(s)
+1 on that. Currently using it and it does create gunky / sticky residues. A quick wipe down after every ride does the trick. Regardless, I prefer the regular dry version, which is cheaper. C3 does last longer, but it's not worth the extra hassle IMO.
Who does?
Old 05-18-21, 07:36 AM
cheesesandwich
Quoted: 16 Post(s)
Liked 12 Times in 8 Posts
Used rock n roll gold. Good I have to say but its petroleum by product and application can be abit messy. I clean and re lube my bike in the shower room. Switched to Squirt now. When cleaning I just use rag with warm water over the chain. Gets the dirty stuff removed and because its wax it does not stain the floor. Application is also less messy,
cheesesandwich is offline
Old 05-18-21, 10:38 AM
WorldIRC
Canadian eh?
Quoted: 131 Post(s)
Who does?
Apparently everyone racing overseas right now
WorldIRC is offline
Old 05-18-21, 06:52 PM
seedsbelize
smelling the roses
seedsbelize's Avatar
Quoted: 7081 Post(s)
Liked 901 Times in 612 Posts
I've used Tri-Flow for decades, and haven't been able to get it in Covid times, here in SE Mèxico. Today I bought a dry lube from Zefal, because I needed something. I have yet to use it.
You're welcome.:-)
seedsbelize is offline
Old 05-18-21, 10:33 PM
SoSmellyAir
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1938 Post(s)
Liked 1,460 Times in 1,011 Posts
When you switched from Rock N Roll Gold to Squirt, did you have to do anything like sonic clean the chain or soak it in degreaser, or just wipe off as much as possible then switch to Squirt?
SoSmellyAir is offline
Old 05-19-21, 07:19 AM
eduskator
eduskator's Avatar
Quoted: 980 Post(s)
I would never mix two different products unless they are identical or almost (Giant & Stans tubeless sealant, for instance).
Fuel is a great cleaner. The best IMO. Soak your chain in it overnight, you'll see.
Likes For eduskator:
Old 05-19-21, 09:13 PM
NoWhammies
NoWhammies's Avatar
Quoted: 800 Post(s)
Liked 512 Times in 306 Posts
Originally Posted by fooferdoggie
rock and roll has been good I never have to clean the chain. just apply and wipe it off. I only get a tiny bit of buildup on the jockey wheels and chainring. it lasts around 100 or so miles. the blue does better in rain I like it because it is easy to apply you don't have too go link by link. I wish it lasted longer though.
I am going to use this lube on Mrs. NoWhammies bike when I replace the chain.
Question. Does the factory lube on the Shimano chain need to be removed before applying the Rock n Roll Gold?
Also, did you apply the lube as I've seen done in the video? Which is basically to apply liberally to the rear cog with the chain while spinning the chain backwards? Then stop applying, and run the chain repeatedly though a cloth/towel until all the excess lube is removed?
How can you tell when all the excess is removed? No more lube coming off on/in the cloth?
Thank you.
NoWhammies is offline
Old 05-19-21, 09:20 PM
SoSmellyAir
Originally Posted by NoWhammies
Does the factory lube on the Shimano chani need to be removed before applying the Rock n Roll Gold?
No.
No, the method shown in Rock N Roll's video is wasteful and messy. We discussed this in one of your previous thread:
Muc-Off Hydrodynamic Lube = lots of gunk on chain? - Bike Forums
This is my "good enough" way to apply any lube when I am not washing my bike.
1. Shift chain onto big chain ring and rear cog that gives the straightest chain line.
2. While backpedaling, wipe chain and derailleur pulley wheels with clean old T shirt or top that my son has outgrown.
3. Working with the section of chain extending from the bottom of the big chain ring to the bottom of the tension pulley, drip two drops onto each chain roller. Two drops ensures there is an excess that drips off the roller onto the folded packing paper that lines the ground, thereby serving as a rinse.
4. Slowly back pedal to move the next section of the chain between the bottom of the big chain ring and the bottom of the tension pulley, then repeat Step #3, until entire chain is done.
5. Repeat Steps #2 through #4 once or twice more, depending on how dirty the chain is, by comparing stains on rag; newer stains should be noticeably lighter. For the final application, use only a single drop per roller.
6. Let chain sit overnight.
7. Repeat Step #2 next day.
Bike Forums - View Single Post - Muc-Off Hydrodynamic Lube = lots of gunk on chain?
Likes For SoSmellyAir:
Old 05-19-21, 09:30 PM
NoWhammies
NoWhammies's Avatar
Quoted: 800 Post(s)
Thank you.
Old 05-19-21, 09:38 PM
SoSmellyAir
Thank you.
No problem. Just noticed you are in Vancouver. When I grew up there (almost a quarter century ago, damn that sounds old), it used to rain at least 1 out 3 days on average. Maybe global warming has changed that. But if not, then you may want to try Rock N Roll Extreme (Blue) instead of Gold.
Old 05-20-21, 12:58 AM
canklecat
canklecat's Avatar
Quoted: 4559 Post(s)
Liked 2,802 Times in 1,800 Posts
Ditto, R&R Absolute Dry and Gold. Both are very good, slick, low residue. Absolute Dry needs to be reapplied more often. Gold has a tiny bit of oil.
White Lightning drip wax lubes left a lot of waxy snot boogers on my drivetrain.
canklecat is offline
Old 05-20-21, 07:10 AM
fooferdoggie
Quoted: 680 Post(s)
Liked 947 Times in 554 Posts
Thank you.
I usually take it off with fishishlines fast degreaser. it is so sticky it attracts a lot of stuff. Think the rock and roll will take it off after awhile but then you don't keep the chain as clean. Yes I jut run the chain and squirt it on then wipe it a lot.
fooferdoggie is offline
Likes For fooferdoggie:
